M10 carbed turbo?
GrindCulture
Post Mon Jun 23, 2008 6:17 pm
Can it be done?
I've been thinking about it for a while, planning on initially building a low cost non-intercooled turbo M10 engine similar to the 2002 turbo engine, however using a carburetter M10 (rather than the early mechanical fuel injection used on the 2002) to save money on mapping a stand alone management system. Not looking for huge power, just a little bit more poke to keep me happy before I go for the MS and intercooler to bring the power up, then adding better pistons and boosting even more.
The BMW 2002 turbo M10 ran 7psi producing 170bhp and about 177lbs/ft of torque if I recall correctly. My thinking was if I set up the carbs and wastegate properly I could achieve similar figures with carbs.
Feel free to correct me and put my mind at ease :D
Aubs
Aka Mr_Gerbic_iS
Post Mon Jun 23, 2008 7:15 pm
Sounds like a cool idea man, Didn't the 2002 turbo use either Bosch L or K Jetronic?
If so, its not too hard to get either of those systems to flow adequate fuel for this kind of power, just with some mods to the regulator.
Post Mon Jun 23, 2008 7:17 pm
will be fine with carbs, you might have to ditch the standard pierburg, the weber replcement might be ok . a set of weber 40s will be good
e21Jason
Post Mon Jun 23, 2008 8:15 pm
Hi
Probaby as easy to turbo a efi model on ms or standard efi than convert to carbs as you need a new manifold and turbo spec carbs that need to be jetted to suit plus a new fuel pump etc. a set of late dell'orto DHLA woudl be fine.
Spend the money on msfirst rather than carbs that you wilswap for ms later.
Jason
GrindCulture
Post Mon Jun 23, 2008 9:37 pm
Mr_Gerbic_iS wrote:Sounds like a cool idea man, Didn't the 2002 turbo use either Bosch L or K Jetronic?
The 2002 used a Schafer fuel system.
I didn't realise the standard efi could be modded to run a turbo, is it a fairly cheap option or will it require quite a hefty re-map? I want to keep the cost down as much as I can whilst still wetting my appetite for turbo charging whilst I'm doing my apprenticeship.
Thanks for all the input guys!
GrindCulture
Post Mon Jun 23, 2008 9:52 pm
I suppose another idea would be to find a second hand MS module and all the bits and pieces I need and to learn to set it all up myself. I'm sure this is what fozzy did with his M20 turbo setup.
Not in E30s any more :(
crazymonk
Post Tue Jun 24, 2008 12:08 am
You can turbo carbs no worries, I've done it before with one of my early cars. If you go for webers or something you need to mod them a bit unless your running really low boost, you may need seals on the spindles that hold the throttle butterflies, and whatever carbs you use, fit nice new gaskets, as the pressure difference on the inside and outside of the carbs can cause the gaskets to split. One way to stop this is to mount the carbs in a selaed box so it equalises the pressure inside and outside the box, but then you've got to get the linkage and fuel pipes through while still keeping the box sealed. Bike carbs are really good, you can make up a manifold for them really easily, even if you can't weld it together, you can cut the metal plate and tubes for it, and get a local engineering shop to tig weld it together, it cost hardly anything and will work and look great. Bike carbs are of a different design to webers and dellorto's, more like su's but they're simple, effective, and really cheap on ebay, even re-jetting them is cheap. I'd fit an intercooler though, you can get some on ebay for £30 and even one thats small will really help compared to not having one. Also have you considered that by the time you've bought a new fuel pump, regulator, the carbs themselves, and made the manifold etc, you're probably not looking at much less than a mega squirt. I hope it all goes well though, sounds like it will be a great laugh when it's done.
dobbie82
Location: Dolgellau, Wales (NOT A TRADER,broken a car,got lots of bits)
Post Tue Jun 24, 2008 7:43 am
would anybody be interested in earning a free manifold? A guy here wants to get in touch with someone doing an m10 turbo conversion as he needs installation pictures to put with the parts he sells. He's jsut down the road from me but i have an m40
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... TQ:GB:1123
e30 related ebay auctions + shop(MY Stuff for Sale), http://tinyurl.com/64aufr
My Feedback on the e30zone: http://tinyurl.com/dobbie82feedback
Post Tue Jun 24, 2008 9:44 am
dobbie82 wrote:would anybody be interested in earning a free manifold? A guy here wants to get in touch with someone doing an m10 turbo conversion as he needs installation pictures to put with the parts he sells. He's jsut down the road from me but i have an m40
GrindCulture
Post Tue Jun 24, 2008 6:09 pm
I saw that on ebay the other day, unfortunately I probably wont be doing it for a little while due to my daily driver being in dire need of attention :( . I don't even have the motor to start on yet, I'm just doing all the research before I get cracking so I know what I need to get etc. It's really annoying that the opportunity to get a free manifold has come up now, and not in a few months time :cry:
Superigorot
Post Sun Jul 06, 2008 5:27 am
I currently have an m10 carbed turbo. It runs great! I have pics and videos if you want...
jaistanley
Post Sun Jul 06, 2008 5:32 am
Isn't the M10 easily converted to injectio though (didn't the 318i E30 have efi??). If so, it'd be very cheap and very worthwhile to use megasquirt. So much easier to tune and get a smooth reliable drive.
Just a thought...
I've always quite fancied a turbo 2 litre M10 for the grunt. Circa 250 brake.. :twisted:
GrindCulture
Post Sun Jul 06, 2008 7:00 am
Superigorot wrote:I currently have an m10 carbed turbo. It runs great! I have pics and videos if you want...
Sure put them up! I'm all up for seeing some more 4pot turbo rightness!
When the summer's over I'm going to try and source an E21 320i/4 motor for the build and not bother with carbs at all. winkeye
fowler
Boost Junkie
Post Sun Jul 06, 2008 8:50 am
easiy to do but you will need trigger wheel etc off M40. for the MS to run properly
EX A-Tech Workshop bitch !!!
gone but not forgotten
GrindCulture
Post Sun Jul 06, 2008 5:12 pm
The guys on bmwe21.net say that an M42 trigger wheel will work fine with a bit of minor adjustment.
Superigorot
Post Tue Jul 08, 2008 10:50 am
Frankly, it would run better with a blow through type.. stay away from the carbs.. :D Im starting a 320i turbo project.
secondtimelucky
Post Tue Jul 08, 2008 10:51 am
Let see some videos then winkeye :D
Wanted: Any old component speakers, complete or separate parts, let me know what you got :D
Superigorot
Post Tue Jul 08, 2008 3:37 pm
secondtimelucky
Post Tue Jul 08, 2008 5:15 pm
You do know both those vids are he same?? :D
GrindCulture
Post Tue Jul 08, 2008 5:26 pm
Nice, liking those wheels too :)
Superigorot
Post Tue Jul 08, 2008 6:18 pm
Fixed the videos..
suzie650
Post Tue Jul 08, 2008 7:25 pm
8500rpm?!?
ShepsEvo3
Master of go faster
Post Tue Jul 08, 2008 7:27 pm
I see the big clock next to the speedo to time 0-60's winkeye :lol:
www.sabre-tuning.co.uk
secondtimelucky
Post Tue Jul 08, 2008 7:41 pm
8500rpm?!?
Thats what I was thinking, thats v-tec territory :mad:
Superigorot
Post Tue Jul 08, 2008 7:52 pm
actually it reaches 9000rpm.. though the meet of the power is from 5500 to 8500...
Superigorot
Post Tue Jul 08, 2008 7:53 pm
ShepsEvo3 wrote:I see the big clock next to the speedo to time 0-60's winkeye :lol:
i didnt want to be redundant with the tach so I kept the stock clock... :D
suzie650
Post Tue Jul 08, 2008 8:07 pm
not worried of lengthening your conrods? :mad:
GrindCulture
Post Tue Jul 08, 2008 9:03 pm
suzie650 wrote:not worried of lengthening your conrods? :mad:
Is that a (or is it an) euphemism? :?
That motor sounds brilliant fun, really really need to hurry up and get rid of my breaker so I can start the M10 magic for myself...
suzie650
Post Tue Jul 08, 2008 10:14 pm
Well, I know that these engines are strong, and I don't know a lot about them, but I doubt that the standard internals were meant to rev that high... especially with more pressure on the piston.
I might be totally wrong, though.
GrindCulture
Post Tue Jul 08, 2008 11:36 pm
All the other M10 turbo buildups I've read about have had a stock rev limit, interesting to see someone chucking more into the equation and really testing the M10's reputation.
Superigorot
Post Wed Jul 09, 2008 2:26 am
I made some internal modifications like double valve springs. But the pistons are new and stock. Valves for the m10 are stainless steel, which are durable. I havent replaced the rocker arms yet. You can get forged pistons and better rockers.
Superigorot
Post Wed Jul 09, 2008 2:33 am
GrindCulture wrote:All the other M10 turbo buildups I've read about have had a stock rev limit, interesting to see someone chucking more into the equation and really testing the M10's reputation.
Hey Buddy. This M10 Kicks ass... its a good base for boosting. It cost mo around $1500 total and I run a 7psi boost only. give me a call if you want to ask any questions. Im sure that this is the only M10 with this type of configuration.
GrindCulture
Post Wed Jul 09, 2008 5:30 pm
$1500 is a good sounding price. Did you machine your own manifolds etc. and map the ECU yourself?
Superigorot
Post Wed Jul 09, 2008 5:55 pm
I used a weber carb and used the stock intake and exhaust manifold. I dont need any ecu because its not F injected, thats why I can rev to the moon. This is a draw through set up contrary to the blow through for FI e30's.
GrindCulture
Post Wed Jul 09, 2008 6:01 pm
Ah right, misread that bit :mad: How much power you making?
