Hi chaps,
Slowing working on my 325 getting all the MS bits together... one of the main problems I have is not having a lambda sensor fitting on my exhaust. Its a fritz 6 branch (I believe, one of the original 1st ever 6 branch group buys), which is basically 2 seperate systems, so not sure where to put the sensor? Do I need to try and join the pipes?
Cheers,
James
Lambda sensor placement for MS
stonesie
Is there a crossover under the car? or would that be too far back?
Im wanting to know too for when i convert mine to LPG soon, hopefully this month.
Fitting it in one pipe only should be good enough. Whatever is happening in three cylinders should be happening in the other three as well.
e30_Turbo
- Boost Junkie
Try get into number 6 runner, purley as it's the hottest and the first to blow, I can prove this about 5 times over
While your there fit a boss for a EGT gauge into number 6 too, that's all you will need to really fine tune it.....
EGT's are one toy I'll add over the winter when the new manifold is eventually welded up.
HTH, Mark.
HTH, Mark.
FlappySocks
Did mine last weekend.
This was my old Sport. (lots of splatter!)
e30_Turbo
- Boost Junkie
jamesc
So basically somewhere in the upper half of the pipe is ok?
hoshy
- E30 Zone Wiki Guru
What's the benefit of EGT? Allow you to get better spark tuning?
FlappySocks
As fozzymonster says. 10 to 2 is best. Not below 9 or 3. Its so that the sensor tip is not submerged in water left by condensation. Bit tricky to get it 10 to 2 on a standard exhaust.
Gunni
It allows you to monitor the condition of the engine at the current state.hoshy wrote:What's the benefit of EGT? Allow you to get better spark tuning?
When something might fail you´ll see different EGT but might see same boost and same AFR. So it´s to help you notice problems.
EGT sensors are SLOW so they can´t be used in sweeping action only steady state tuning and even then it´s dangerous to keep a hard boosted engine at full chat at one rpm.
hoshy
Interesting - cheers Gunni.Gunni wrote:It allows you to monitor the condition of the engine at the current state.hoshy wrote:What's the benefit of EGT? Allow you to get better spark tuning?
Sorry for the thread spam
Motronic to Megasquirt Plug and Play Guide
