m62 obd2 swap?
Dominic49
Post Mon Jun 02, 2008 8:03 pm
is it feasible to keep the obd2ness of the m62 when swapping it into an e30? i love the factory drivability of stock dme but want to be able to have it work in the e30.
I have the ews system and key, came with the motor, but have no idea how to have the ecu disregard its dsc functions and only control the motor.
any tips/ideas would be much appreciated.
suzie650
Post Mon Jun 02, 2008 9:33 pm
glenn got an s62 to work on the original loom and ecu, so it is possible. I also know that some m62 can be switched to normal analogues signals instead of using the bus with the bmw diag' tools (source e30.de)
Dominic49
Post Wed Jun 04, 2008 6:17 am
can i use the dme from a 1995 530i (us spec v8) and have it tuned for the 4.4?
suzie650
Post Wed Jun 04, 2008 4:45 pm
that's unfortunately beyond my limited field of expertise - I only have the wiring diagrams for my engine.
Other people on here should be able to help you out better.
