spark plugs for m20 turbo
midnight
Colonel Sanders
- Le Surrender Monkey.
- Location: guernsey.... i mean france munching on garlic and drinking wine with my children.
around 3 degrees colder for over 1 BAR kev.
you far on your build yet?
midnight
Colonel Sanders
Q: What plugs should I use? what should I gap them to?
A: NGK 3923 BPR8ES plugs. Their 3 degrees colder than stock. i gap them to .025". For 1.0 bar or more boost, even colder plugs are recommended (BPR7ES).
I found some more information about NGK spark plugs, and their related part numbers for heat ranges.
http://www.ngksparkplugs.com/techinf...tnumberkey.pdf
Apparently, the lower the number, the hotter the plug. So that would make a BPR7ES Hotter (not colder) than a BPR8ES. Stock would be BPR5ES, or for the v-power series, ZGR5A. Unfortunately they do not make a ZGR7A or something of the sort.
General thumb of rule, every 75-100 hp added, you take 1 step colder.
copy that from another site, im using BPR7ES
midnight
Colonel Sanders
just your standard ngk plugs from your local store mate. just ask for m20b25 fitment as in length
midnight
Colonel Sanders
anytime mate, looks as though your closer to finishing than i am!!
midnight
Colonel Sanders
yeah if its ready il be comin up in it, and if its run in i will take it up the strip with hopefully around 500hp..
yeah using your head and cam still, i got it oringed and had the cooling channels welded up.
next on the list is a custom inlet manifold...
Turbo-Brown
- Boost Junkie
I'd say if you can only gap them to 0.6mm, your sparking system isn't powerful enough!
I ran fractionally under a 1mm gap from the start. Decided to reduce this one day to whatever the book says it should be which I seem to recall is in the region of 0.6mm.
It was like the car had been castrated! It was just so limp after that!
Had them out and re-gapped them and all was well with the world again
midnight
well ive got the gm coil park on there, and as i can recall i think its quite a good dwell timing and ballast for a good spark, so bit of a hit or miss one possibly, 500hp sean thats sounding pretty fierce, i hope to have a race with u at usc then, well im in the middle of making up a sweedish plenum style inlet manifold for my m20, so if it works out well, it mite be a good ideal for yours too
Colonel Sanders
yeah, i doubt il get it this year though, its cost me enough already!!lol i just wanna drive it now...
midnight
