E30 325I TURBO CONVERSION QUESTIONS
messiah
Post Sat May 24, 2008 2:01 pm
Hiya im seriously considering converting my 325 m20 to turbo but i want to know how much boost my engine will take and ecu will be able to control im willing to go full hog with new pistons and rods but if bmw over engerned the engine and it will cope with alot of boost it would save me money im also guessing i would need to use a compression plate to lower my compression aswell
i just wanna know how much bhp i can push before i have to change pistons and rods and will i need to have the ecu mapped or chipped?
cheers
blingsta
Boost Junkie
Post Sat May 24, 2008 2:09 pm
best speak to ant regarding your needs.. my 325 is boosted at 7psi as a standard engine with no need for any mods what so ever, not even the decomp plate.... the main things you need to make this work is a standalone ecu which would get rid of your afm, turbo manifold, bigger injectors.. and other niggly bits n bobs... :D
toby
Post Sat May 24, 2008 3:44 pm
Ant also sells a custom made supercharger - can be done without mods to the internals I think.
http://www.e30zone.net/modules.php?name ... c&t=100363
Gunni
Post Sat May 24, 2008 7:15 pm
stock block figures just keep going up
read these threads many times over before you do anything else.
http://www.e30tech.com/forum/showthread.php?t=3237
http://www.e30tech.com/forum/showthread.php?t=53939
http://www.e30tech.com/forum/showthread.php?t=55729
If these don´t explain things a lot more then you need to read them a few more times.
Gunni
@ 2012 VEMS group buy !!
Post Sat May 24, 2008 7:32 pm
Gunni wrote:If these don´t explain things a lot more then you need to read them a few more times.
What no spoon feeding? :)
Gunni
Post Sat May 24, 2008 7:38 pm
I only have so much good in me per day :)
Gunni
