M30 on a budget, transmission questions.
78gizmo
Post Wed May 14, 2008 8:11 pm
Hi, have just had a read of the M30 thread, which was very useful. It says some M10 gearboxes will fit, is there a way of telling which? The reason is i have been offered a 535i very cheap, but it is an auto. The car i want to fit it to is Manual 318i '86 M10. If the engine will fit to my cars existing transmission without too many headaches then i will get stuck in, but i am on a severe budget, so if i need to source an M30 manual box, new prop etc then i will have to give it a miss this time. Any help or ideas on other bits i will need to complete the conversion would be much appreciated! I will have the complete 535i to source bits from.
SPADGE
Post Wed May 14, 2008 8:21 pm
My advice would be to find a cheap e34 manual as a donor car it'll be cheaper in the long run!
Gunni
Post Thu May 15, 2008 12:36 am
Agree.
Buy the 535i part it.
Buy a manual one and us that.
Gunni
@ 2012 VEMS group buy !!
FormerMember
Post Thu May 15, 2008 8:45 am
Yes, you can use M10 gearbox but then you need M30 flywheel, clutch etc etc anyways..
Also, with M10 box the gearing ratio is way too fast to be sensible, so find manual 535 straight away, it'll be lot easier.
E30 Cabrio M-Tech, powered by V8
E34 M5 3.8 x 2
Alpina D10 Touring #33/93
E46 318i Touring
Toyota Hiace 4wd
Gunni
Post Thu May 15, 2008 10:18 am
that´s wrong. m30 flywheel doesn´t fit into the m10 gearbox.
also about the m10 box gearing.
Gunni
johnl320
Post Fri May 16, 2008 7:43 pm
Gunni know, he's done it.
1. M30 engine
2. M10 flywheel/clutch
3. M20 prop
4. Large case diff 3.64 from early 325i
Job done, but make it stop and make it handle first.
Thats my advice
john
Gunni
Post Fri May 16, 2008 8:04 pm
I used a 320i driveshaft.
I have no idea if the m10 prop will fit.
Gunni
johnl320
Post Fri May 16, 2008 10:22 pm
oops typo edited :o:
