hi does anyone have a gates no. for m3 3.0 power+alt belt
irish320i
Post Wed Apr 23, 2008 11:52 pm
got the wrong one today so if anyone has the right gates code would be great otherwise ill just have to try a bit of rope and start digging around and try to find the right one
Cheers Alan
jaistanley
Post Thu Apr 24, 2008 1:46 pm
I shall keep my eye out. I have a 3.2 but am removing both the air pump and air-con so I assume I shall need a similar shorter belt to you.
I think most people on here are running the air-con with their S50's annoyingly! Try Johnno. He has a 3.0 litre and no aircon I believe.
Jai
jmc330i
Post Thu Apr 24, 2008 6:44 pm
jaistanley wrote:I shall keep my eye out. I have a 3.2 but am removing both the air pump and air-con so I assume I shall need a similar shorter belt to you.
My 3.0ltr had 2 belts, 1 for the water pump/alt/power steering and another for the aircon/air pump.
I dont remember having to get a shorter belt for anything, just a new standard belt from BMW (for the alt/power steering etc).
Removing the aircon and air pump just left me with a spare pulley on the front of the crank.
James
'91 325i Sport
'93 318i touring 16v
old_skool
Post Thu Apr 24, 2008 6:48 pm
That's right, one belt does the A/C and the Emmissions pump. I kept the A/C and ended up getting the belt from a SA spec car that doesn't have emissions eqpt. So was shorter than the UK belt.
irish320i
Post Thu Apr 24, 2008 8:33 pm
it should be a standard size but i haven't got a bm dealer close so went to the autofactors and he only had a listing for the belt he gave me which was the wrong one so will just have to get a shorter one of him or get one of bmw
Cheers Alan
Al
89 316i s50b30, 00 subaru imperza turbo(gone) 2005 range rover td6,
old_skool
Post Thu Apr 24, 2008 9:00 pm
irish320i wrote:it should be a standard size but i haven't got a bm dealer close so went to the autofactors and he only had a listing for the belt he gave me which was the wrong one so will just have to get a shorter one of him or get one of bmw
Cheers Alan
Alan, be a bit clearer with what you want. Is it just to run the A/C compressor?
Why not deal with Zimmerbimmer1 in the genuine parts section. He'll post to Ireland and he's the main dealer man.
irish320i
Post Thu Apr 24, 2008 9:13 pm
Sorry thought i had it in the heading Its the standard belt that drives the power steering pump, alternator and water pump should be a standard belt but the parts places seem to all have the wrong listing for it. Its no problem really wll just have to call back in tomorrow with it and get a bit shorter one if not i can order a bmw one off zimmerman thanks for he help
Cheers Alan
Al
old_skool
Post Thu Apr 24, 2008 10:31 pm
Alan, the genuine BMW part number for the belt you need is 1128 1404 018, hopefully your supplier can cross reference the number.
Hope that helps :D
