Start off with a sketch based on measurement taken from a crank pulley and the water pump which is what the pulley's for:
Machine a rebate for the hub of the pump:
Cut the Vee for the belt:
Drill some mounting holes:
And the finished article:
7.25" crotch measurement... seems adequateTurbo-Brown wrote:I've got a custom flywheel which takes this twin plate Tilton clutch:
It's only a 7.25" one...
the offer is still open mateTurbo-Brown wrote: I keep meaning to send a rocker off to see how hard the pad is as that'd help in the selection.
Maybe Volvo could provide an answer, my mates V70R has an electric oil pump that comes on to keep the turbo supplied with oil if you shut the engine off after giving it some abuse... Just a thought.Turbo-Brown wrote:I'd forgotten about the hotstart things.
Thought about making one years ago using the pump and heating element from a washing machine. Might still do actually.
I know every other engine in the world has to start without any oil pressure, but I like the idea of my engine having a nice easy life
Perhaps to do with noise / clatter? or perhaps designed to give a certain pressure on the lobe and stop any valve train bounce.Turbo-Brown wrote: Had a measure of the follower pad too, does anyone know why it's so narrow?! I've made mine 2mm wider which, whilst adding weight, should reduce wear on the cam and pad by virtue of lower contact pressure.
