3.5 rebuild help
whipsey
Post Fri Jul 20, 2007 6:05 pm
found loads ta :D
Jonah
Post Sat Jul 21, 2007 5:24 pm
Jhonno wrote:so a lata head on e28 lump would be a good move then?
AIUI, the e34 head is a better design than the e28 type, with better ports and 1mm (47mm) larger inlet valves.
However, the e34 head has 65cc combustion chambers compared to 58cc for the e28, so dropping one on an e28 block will lower the compression.
