another S50 swap! now TURBO
Tue Feb 10, 2009 12:05 am
gazatron wrote:dont really get starvation never run below 1/4 of a tank if it can be helped, got a walbro 255 as low in the tank as possible. When we go past the 550ish bhp with a bigger turbo going to get a swirl pot and a bigger pump maybe a inline one too.
Thank you.
gazatron
Tue Feb 10, 2009 12:08 am
what pump do you have? is it as low as possible? some people put foam in their tanks to help combat this
Tue Feb 10, 2009 12:12 am
gazatron wrote:what pump do you have? is it as low as possible? some people put foam in their tanks to help combat this
I'm in the middle of discussing this problem now. Take a look and see what you think.
http://www.e30zone.net/modules.php?name ... &start=200
gazatron
Tue Feb 10, 2009 12:26 am
my eyes are tired! so are you running are walbro in it now? you said you dont get it with a 325 have you took both pumps out and compared how they are sat in the cradles? perhaps even swaped the two over?
Chuntington101
Tue Feb 10, 2009 12:57 pm
What a build! have you got any pics of the turbo manifold off??
Chris.
Tue Feb 10, 2009 7:03 pm
gazatron wrote:my eyes are tired! so are you running are walbro in it now? you said you dont get it with a 325 have you took both pumps out and compared how they are sat in the cradles? perhaps even swaped the two over?
They sit at the same height. I think i have a solution now.
Gunni
Tue Feb 10, 2009 7:10 pm
You might like to upgrade your turbo as it´s a little bit small for the S50.
The S50 is a heavy breathing engine and does not like backpressure.
Which your turbocharger will do at some boost.
Something like a GT35R would suit it alot better and allow for alot better power with less boost.
Other then that , :)
Great looking setup.
Gunni
@ 2012 VEMS group buy !!
gazatron
Tue Feb 10, 2009 7:37 pm
yeh the turbo is temporary it is just one we had lying about. when its all running correctly and appropriate re inforcements have been done thats when turbo will be finalised. dont know what turbo will be the final one.
orr
Tue Feb 10, 2009 7:43 pm
please can you put up some pictures of the tilton brake set up, is it the 600 bulk head mount one thanks
nickalauski
Tue Feb 10, 2009 9:21 pm
Nice work.
I'm in the process of building an e30 s50 turbo, been on it for about a year now. Not quite as speced up as yours though!
Low comp pistons, forged rods, vanos removed-fixed pulleys, kms management 680cc injectors...ect
Partly mapped on dyno but producing too much torque to hold rpm! eta april....
e30_Turbo
Boost Junkie
Tue Feb 10, 2009 9:25 pm
Very nice, what turbo did you run before? That GT30 will run out of go around 450bhp depending on wheel sizes, what are your goals?
Have you considered a custom intake mani? most s50turbo's run them, with the tb's it's much easier to make, build looks the nuts, good luck, you gotta love e30's with boost!
e30_singh
Tue Feb 10, 2009 9:38 pm
This is crazy!
A masterpeice of engineering!!!
Put that in your ricer pipe and smoke it, BMW purist with turbo power!!![/img]
gazatron
Wed Feb 11, 2009 3:17 pm
the gt30 is the first one we have used, maily just to get it up and running, then decide what turbo to go for when we are bored of that.
the main goal was to do everything else first so it would be a simple case of just uprating the turbo and a few other things when we wanted more power but everything else would be already done. alot of people just bolt big turbos on and then see they need better clutches, bigger brakes and everything else that goes with it.
gazatron
Thu Feb 12, 2009 6:06 pm
done some more work today going to fire it up tonight
nicalauski what did you do about the knock sensors when running your KMS? can they be put into the ecu? im just using a knock meter but hard to keep your eyes on it sometimes
the tiltons are 600 series floor mounts with the twin master cyl on the brakes with the bias adjustement built in, and a remote adjuster unit
GrindCulture
Thu Feb 12, 2009 6:08 pm
:eek: M Power + Boost = Mental!
Not in E30s any more :(
Thu Feb 12, 2009 7:57 pm
That looks totally awesome :cool:
e30bmlover
Ac Schnitzer prophet
Thu Feb 12, 2009 7:58 pm
Mate that build is the bolloks.... we need dyno graphs when you finally get it mapped!
nickalauski
Mon Feb 16, 2009 9:14 am
I'm not using the knock sensors, KMS doesn't have a facitily for knock sensors.
If the engine is mapped correctly you shouldn't have a need for knock detection. KMS has fuel correction for air and exhaust temperature which should help keep things safe.
I've mapped mine upto 5000rpm, with around 7psi boost. I didn't have any trouble with detonation at that stage although that may change as boost increses. It was on boost at 2000rpm making over 200lb/ft, looking forward to driving it!
barryj
Fri Feb 20, 2009 6:42 pm
Gaz did you by any chance buy the E34 M50 sump etc from the dealer you work for? if so could you PM me the part numbers and maybe the costs?
