Very similar manifold was in one of Toyota engines (the pipes are not parts of casting, it is not so compicate). It is some kind of variation of M20 manifold, isn't it?Turbo-Brown wrote:Wowzers, that's one complex casting!
Are they one of that ceramic Skyline turbos or ceramic was used later?Turbo-Brown wrote:Jan, the turbos came from a Skyline so I think they're a funny spec of T25 with tiny little hot sides.
You shoudn't exceed 80% duty! They need to cool down (the coils in injectors) and with so lond duty quite big pqrt of fuel are reaching the inlet valve seat when the valve is closed. In that case lots of fuel are condense on port walls. I know that you are now on next project but it needs bigger injectors (minimum 50%).Turbo-Brown wrote:I could perhaps have taken another 3psi if the injectors were larger, but they ended up going to 97% duty as it was.
Quite high CR for two valve per cylinder engine! BTW with new turbo setup try the cam with higher lift (don't go mad with duration). Shoud give more power without destroing flexibility.Turbo-Brown wrote:The engine's a standard early spec M20B25 with a 9.7:1 compression ratio and standard cam.
I must say that I'm very impresed that you are going to do this. My project is a little more complex but I'm not feel enough strong to try sequential (I just hope that with carefully design and selection the components I will have enough good setup).Turbo-Brown wrote:Anyway, all this lot's moving on as I'm working on a twin sequential setup now in the hope of getting boost from idle to the red line
Jan
