Im still using more gallons than miles
Today's mapping
lentec
- Boost Junkie
Alex can i scrounge a copy of your new map? still not happy with mine
Turbo-Brown
- Boost Junkie
Yes mate, will copy it across and e-mail it over
EDIT> You have mail Len, hope it works as well for you as it does for me!
Couldn't bung me a copy of your current map could you? Be interested to compare them directly. Found the easiest way (for me anyway) is to just open them up in notepad. Don't even need to rename them to .txt. You can copy and paste as normal then.
That's how I made up the base for the map I sent you, which Ant then tweeked all over the shop to make it work much, much better
Seemed to work reasonably well, although it was rich all over the place.
