Tuning Talk(standalone)
chip-3door
Post Mon Jan 23, 2006 4:00 pm
PS
I would view 900 degrees as the utter limit for a road car, i would never allow it to higher than that!
Ant
Retired Team Member
Retired Team Member
Post Mon Jan 23, 2006 4:05 pm
I'm guessing you're using a boost controller then M8 ?
I'm not as yet, still boggo actuator straight off the compressor housing.
you can use boost control on the MS, the code is there but an extra output on the CPU has to be jumpered, you can then set variable boost based on TPS ADC value, ie 10psi above 80% as you've indicated, thats my next logical step, just need the funds for the controller TBH
Budjet constraints are my biggest handicap on this project, I promised myself I'd not spend more than I sold my Tech 1 for last year, so far I've got a few pence left :roll:
chip-3door
Post Mon Jan 23, 2006 4:11 pm
ant wrote:I'm guessing you're using a boost controller then M8 ?
Not a seperate boost controller no, its all built into the ECU, fords have boost control as standard, they are high tech, not like these basic old barges we are all driving around in made by bmw :wink:
Andy335Touring
Post Mon Jan 23, 2006 8:50 pm
ant wrote:
Andy , how you getting on with your LC-1 dude ? and my apologies I got as far as boxing your Corky Bell books then stopped, shoot me your addy again and I'll get them back to you for defo this week
Erm, not had the sensor boss welded on yet but no rush because i'm going to fit a bigger TB(twin 60mm) to my engine so theres no point playing with it til then. It's running really well but too rich is my guess at the mo.
I'll drop you an email ref my ady in a sec.
What sort of AFR's are good to aim for on a N/A engine ?
chip-3door
Post Mon Jan 23, 2006 9:17 pm
Mid 12s when flat out generally, and higher than that for everything else, with around Stoich (14.7) on cruise/idle.
Varies a little from engine to engine though as to what is optimum of course!
lentec
Boost Junkie
Post Mon Jan 23, 2006 10:29 pm
Think ive missed something here. do the MSs have EGT sensor ins or are you running somthing else to mesure that?
chip-3door
Post Mon Jan 23, 2006 10:34 pm
lentec wrote:Think ive missed something here. do the MSs have EGT sensor ins or are you running somthing else to mesure that?
i assumed it was just a seperate gauge
Andy335Touring
Post Mon Jan 23, 2006 10:43 pm
Cheers for the info :thumb:
Ant
Retired Team Member
Retired Team Member
Post Thu Jan 26, 2006 4:39 pm
OK, been playing around with my setup today , pulled 11 logs in 3 hours and consumed a lot of fuel :lol:
however , I had an issue with a tiny bit of pinking.... and using datalogs have found out why
http://img230.imageshack.us/my.php?image=7255psi9jf.jpg
see the 104 figure ?, thats the accel enrich pushing the AFR down to 10 on rising boost, not good!
I now have no accel enrich settings and the car drives sweet as a nut on boost with AFR around 12.5 - 12.0 over 6 psi, all ok, I will add a small accel enrich but not under boosted conditions.
I have to say, without datalogging this would have been very hard to cure, kudos to everyone involved in MS, it really has become more than the sum of its parts
