Which engine transplant?
leeparkes
Post Sun Jan 25, 2009 11:43 pm
I know 'dan the' knows a lot about M50/52, also jhonno,
i think the M50 inlet manifold needs a touch of modding to fit the M52 but its not rocket science!
blackcountrybimmerman
Post Sun Jan 25, 2009 11:44 pm
leeparkes wrote:
blackcountrybimmerman wrote:On some of the later engines, are some of the parts standardized? Are you able to interchange between engines?
what do you mean? manifolds
Not just manifolds.
Cloud is using an M52 crank. Onto an M20 engine?
It doesn't look like it does in my sig pic anymore
Cloud
Mmmmmm Donuts!
Post Sun Jan 25, 2009 11:50 pm
blackcountrybimmerman wrote: Not just manifolds.
Yep.
It's a fairly straightforward fit. Head, block, and pistons are M20. Conrods are M20 from a two litre engine. Crank is M52. It needs a custom fabricated oil seal for the crank shaft, but I got "some bloke" to knock me one up for about £30.
leeparkes
Post Sun Jan 25, 2009 11:52 pm
Cloud wrote:
Yep.
It's a fairly straightforward fit. Head, block, and pistons are M20. Conrods are M20 from a two litre engine. Crank is M52. It needs a custom fabricated oil seal for the crank shaft, but I got "some bloke" to knock me one up for about £30.[/quote]
what head are you using?
Cloud
Mmmmmm Donuts!
Post Sun Jan 25, 2009 11:54 pm
leeparkes wrote:what head are you using?
325i
It's the only one that'll accept the funny shape 325i pistons.
leeparkes
Post Sun Jan 25, 2009 11:58 pm
325i
so the combination is
325i block
325i pistons
325i head
M52/b28 crank
what con rods?
what power would this put out (no other mods)
Cloud
Mmmmmm Donuts!
Post Mon Jan 26, 2009 12:05 am
M20B20 conrods (because the crank stroke is longer, it'll send the pistons up into the head and jam the engine. B20 rods are shorter, and are surprisingly perfect for compression ratio) and power output for just that is... 200 or so. 2.7s are good for 185 to 190.
Post Mon Jan 26, 2009 12:09 am
All of these parts are easy to source?
leeparkes
Post Mon Jan 26, 2009 12:10 am
Cloud wrote:M20B20 conrods (because the crank stroke is longer, it'll send the pistons up into the head and jam the engine. B20 rods are shorter, and are surprisingly perfect for compression ratio) and power output for just that is... 200 or so. 2.7s are good for 185 to 190.
ive realised i have all the bits lying about,(bar the crank) to build one of these!
i asked about the head as i also have a 731 2.0 head doing nothing and i know this can be used in the 2.7 build
mmm...
Post Mon Jan 26, 2009 12:12 am
mmm...
Bloody Hell Lee,
How big is your shed?.....lol
Last edited by blackcountrybimmerman on Mon Jan 26, 2009 12:15 am, edited 2 times in total.
Cloud
Mmmmmm Donuts!
Post Mon Jan 26, 2009 12:13 am
blackcountrybimmerman wrote:All of these parts are easy to source?
Nope.
You'll probably have an effa of a job trying to get an M52 crank.
You may also have trouble finding someone to make the oil seal.
leeparkes
Post Mon Jan 26, 2009 12:15 am
Bloody Hell Lee,
mmm...
lol
its been worse
Cloud
Mmmmmm Donuts!
Post Mon Jan 26, 2009 12:23 am
I've just noticed, Lee and Alan, you're from the same place.
leeparkes
Post Mon Jan 26, 2009 12:25 am
Cloud wrote:I've just noticed, Lee and Alan, you're from the same place.
we live about a mile away from each other!
Cloud
Mmmmmm Donuts!
Post Mon Jan 26, 2009 12:27 am
leeparkes wrote: we live about a mile away from each other!
That's a 30 second drive in an M30 powered E30.
Post Mon Jan 26, 2009 12:52 am
B20 head won't work with a 2.8 conversion, it'll be like trying to put the B20 head on a B25, which is a no go
reggid
Post Mon Jan 26, 2009 12:55 am
S50B32 (as opposed to S52 which essentially is M50B32) would be my choice as IMO it's BMW best allround engine (torque, power, response, economy, looks hot) that commonly finds its way into a E30 so the knowledge on how to do it is already there.
E30 325is with M20B31
Cloud
Mmmmmm Donuts!
Post Mon Jan 26, 2009 12:56 am
Jhonno wrote:B20 head won't work with a 2.8 conversion, it'll be like trying to put the B20 head on a B25, which is a no go
Unless you use B20 pistons.
Cloud
Mmmmmm Donuts!
Post Mon Jan 26, 2009 12:57 am
reggid wrote:S50B32 (as opposed to S52 which essentially is M50B32) would be my choice as IMO it's BMW best allround engine (torque, power, response, economy, looks hot) that commonly finds its way into a E30 so the knowledge on how to do it is already there.
How did you get 261BHP from a 3.1 M20? Magic?
Post Mon Jan 26, 2009 1:07 am
In which case you wont have a B28..
Cloud
Mmmmmm Donuts!
Post Mon Jan 26, 2009 1:15 am
The difference between pistons is minimal, it's only a matter of about 17cc if you use B20 ones to B25 ones. There's not much point building a 2.8 with a B20 head though. The valves are small, and the valve springs are gentle, and the engine management is more relaxed. It'd be more torquey than a standard B25, but not much more power.
Post Mon Jan 26, 2009 1:26 am
Cloud wrote:The difference between pistons is minimal, it's only a matter of about 17cc if you use B20 ones to B25 ones. There's not much point building a 2.8 with a B20 head though. The valves are small, and the valve springs are gentle, and the engine management is more relaxed. It'd be more torquey than a standard B25, but not much more power.
Actually it is a lot more than 17cc..
3.14 x r^2 x stroke x 6
Bore = 80mm using B20 pistons, 84mm using B25 pistons..
Cloud
Mmmmmm Donuts!
Post Mon Jan 26, 2009 1:30 am
Well if the bore is different, the pistons wont fit anyway..?
Post Mon Jan 26, 2009 1:32 am
Yes, but ideally you would start with a B20 block for nice fresh bores..
Anyway, regardless of whether they would fit or not, I was just correcting your inaccuracy
Cloud
Mmmmmm Donuts!
Post Mon Jan 26, 2009 1:35 am
Right. So what's best for me to do, then?
I have a B20 block, should I put the B25 head onto that, rather than using the B25 block?
(in short, I have two complete engines, from a 320i and from a 325i)
Post Mon Jan 26, 2009 1:40 am
If you use a B20 block you need to get it bored to 84mm, this is where my nice fresh bore comment came in, guaranteed straight etc.. This is the best option imo
Cloud
Mmmmmm Donuts!
Post Mon Jan 26, 2009 1:43 am
Jhonno wrote:If you use a B20 block you need to get it bored to 84mm, this is where my nice fresh bore comment came in, guaranteed straight etc.. This is the best option imo
Aaah, right! I see.
Thanks, I'll look into this. Since I'm going mad with tuning, I want and need the block to be the best it can be. It's not something I'd considered, or even knew was possible. Thanks.
reggid
Post Mon Jan 26, 2009 4:54 am
using the usual techniques.
Bigger capacity, 11:1 compression, Bigger cam, Tuned exhaust manifold, Free flowing exhaust, Custom remap, BBTB, Ported cylinder head.
http://www.e30zone.net/modules.php?name ... 83#1056183
Post Mon Jan 26, 2009 8:35 pm
This has all got very technical...
I'm not into engine re-builds and such like, I just don't have the room to do it.
So a 3.5l engine out of an old 7 series (218 bhp) would make my E30 pretty nippy?
leeparkes
Post Mon Jan 26, 2009 8:42 pm
blackcountrybimmerman wrote:This has all got very technical...
3.5 engine (m30) would make the E30 hit 60 in about 6.5 seconds (with the right diff)
Cloud
Mmmmmm Donuts!
Post Mon Jan 26, 2009 8:44 pm
Alpina used an M30 in the B6. Very tasty performance in that.
It'd be my engine of choice, if I weren't tuning my M20.
[youtube][/youtube]
Post Mon Jan 26, 2009 8:45 pm
I still don't know if mine has an LSD. I haven't had time to mess about with it.
6.5 seconds is pretty nippy aint it.
Even as standard we're looking on the right side of 8 seconds though aren't we...
Not bad from a marque that is nearly 30 years old.
Post Mon Jan 26, 2009 8:47 pm
I'm liking all those YouTube clips.
leeparkes
Post Mon Jan 26, 2009 8:52 pm
this might be interesting for you alan
http://www.e30.de/
click on 335,then english version!
Post Mon Jan 26, 2009 9:12 pm
leeparkes wrote:this might be interesting for you alan
http://www.e30.de/
Nice one Lee. :thumb:
