My Turbo Conversion Updates!!!
ShakeyC
Post Thu Nov 06, 2008 2:41 pm
As Fozzymonster said
Top in
Bottom out
The oil feeds should be vertical, if the oil pressure feed is high you can get away with mounting it above the height of the head but its not a good idea, same with the return should not be lower than the sump itself it does cause cavitation issues; think of it as syphoning effect from petrol tank more it does it on its own less chance of failure.
If its at 45 degrees now its a good idea to clock the turbo housings round so there as verticle as possible.
Phill172
Post Thu Nov 06, 2008 2:56 pm
Well iv got a date with the car tomorow night as its the only day im not working! Hopefully ill be able to turn the compressor housing, iv got to take the head back off anyway so at least it will give me room to play
Thanks for the input mate
:x
Phill172
Post Mon Nov 10, 2008 9:38 am
Right then i did some work over the weekend! And finally I have a built cylinder head (although i took the photos not finished!)
Im just waiting on the vernier pully and spray bar to arrive and then it can be bolted down.
Thanks fozzy, i got the turbo repoistioned where i wanted it!
I think tonight I will be making up a support for the turbo hopefully if I get time.
I was pretty chuffed with myself, being the first proper cylinder head iv built! I think Vw beetle engines dont count!
Question though. I was looking into where to mount my intercooler last night, aslong as I cut away the body work behind the intercooler, Is it ok to have the ic pretty much infront of all the rad? Or will I have issues?
Thanks!
and photos!
oakey
Post Mon Nov 10, 2008 11:13 am
Good work man!
I want a turbo m20 badly
Phill172
Post Mon Nov 10, 2008 12:42 pm
thanks very much mate!
another question, where can i get the oil feed fittings, for the turbo?
Gunni
Post Mon Nov 10, 2008 5:50 pm
local hydraulics shop
Gunni
@ 2012 VEMS group buy !!
e30_Turbo
Boost Junkie
Post Mon Nov 10, 2008 6:02 pm
Take everything too them and let them work out what you need, trying to do this without the parts to hand can be a PITA!
Mine are all areoquip braided, cost a bit but no hassles at all with them. I had the restricter made up so it could be broken down at the last 12 inches, meant when I changed turbo's I only had to have the top bit made, saved a few pounds there.
Turbo-Brown
Boost Junkie
Post Mon Nov 10, 2008 6:28 pm
What sized restrictor did you use Mark, out of interest? Don't know what all this -6AN etc means, all I wanna know is how big the hole needs to be :lol:
e30_Turbo
Boost Junkie
Post Mon Nov 10, 2008 6:57 pm
I need to ask Ant, he was on errand duty that day, I was busy doing something....lol
IIRC 4 something... lol, I'll measure the ID/OD for you, might even get a pic, see how flash works in complete darkness :mad:
Phill172
Post Sun Nov 16, 2008 11:44 am
Right then, i did some more work on the car this weekend, rebuilt the cylinder head once again, this time I think I have done it all correctly.
So everything is on the cylinder head apart from a few bits i need to order, new thermo housing/water elbow and cam cover, the vernier pulley will be here next month.
Fitting the injector rail on in a minute, i trial fitted the throttle bodies apart from the bolts i bought are to long, but i had three of the originals bolts so at least i can see how it all lines up. They are absoulte porn! (need a clean first!) Sitting in my mind all weekend, I wonder how cheap I can pick up a 325 for, I really want to slap those throttle bodies on a 2.5 engine, bottem end all lightend and balanced, bit of a lairy cam and those tb sat on top would make me a happy man! But i do have a spare block so im thinking i may build that one up so at least if this blows i can swap them over whilst i build yet another engine!
But anyway the task in hand! Ill get the head on the block as soon as the parts arrive, but im now going to make up the ic mounts, at least i need to get the engine bay tidy as its a state! I have also started working on other areas of the car, started replacing trackrod ends and control arms, bushes and fitting the new front suspension, nothing fancy just new top mounts, I think it has KYB shocks but im unsure, will change at a later date though!
The good old sunday morning right up!
Albinojay
Post Sun Nov 16, 2008 12:15 pm
porn.
Baz666
Post Sun Nov 16, 2008 1:20 pm
thats nice work there fella :cool:
Phill172
Post Sun Nov 16, 2008 6:56 pm
thanks very much!
law
Post Sun Nov 16, 2008 10:01 pm
8O
Mint!
Turbo-Brown
Boost Junkie
Post Mon Nov 17, 2008 1:59 pm
Can't wait to see this running Phil!....and for you to come round and take me out for a spin :D
Phill172
Post Tue Nov 18, 2008 9:42 am
Course mate! Im itching to get it running but im always limited by when my next pay check comes in!
I think a spin (litterely) will be happening haha. But course will do and will involve stopping and buying you a pint too i think!
oi_oi_savaloy
Post Tue Nov 18, 2008 10:45 pm
Loving your work on the kitchen table! I take it you're either single or you have the perfect wife!
(Jealous as hell fella!). If I walked into the kitchen and announced I was going to build a turbo beemer and it might be there for weeks I'd have divorce papers filed before I could say 'pass me the monkey wrench love.....!'
Phill172
Post Wed Nov 19, 2008 9:37 am
Haha, the joys of being 'to' young to move out!
Still living with rents at the moment, It took some persusasion, but my mums used to it as when i grew up it was parts of my dads car on the table all the time apart from we ate round them!
Phill172
Post Thu Nov 20, 2008 9:35 am
So i did some more work last night, just need to pick up a few more bolts bits on the cylinder head and then thats good to go back on for last time (until it blows up)
But anyway, I did a bit of cutting last night and managed to prov fit the intercooler. Need to again get some new bolts for the mounts but hey its coming along now!
Subtle enough? I know I could get it to sit back further, but to be fair I really cant be buggered! As im not really aiming for looks!
Although the sleeper look goes out the window haha
Let me know what you think
O boost piping is going to run out where the inner headlights used to be!
1an
Post Thu Nov 20, 2008 11:16 am
just a quick thing, why not move the intercooler down and behind the front valence where alot of people mount them? or is it to big to go in there?
Phill172
Post Thu Nov 20, 2008 11:23 am
I would...but i think the last guy has nudged a lampost, just the valence is bent quite a bit, but also it would be mean cutting the supports of valance (so its only held by the wing mounts). haha so long sentence shortend, it is slightly to big!
Also making the mounts litterly took a minute as im using existing holes where the bonnet mech used to be.
Im not really going for looks, as if you have seen the rest of the car you would understand why!
si-
Post Thu Nov 20, 2008 1:22 pm
you not worried about that blocking up the rad a touch??
appletree
Post Thu Nov 20, 2008 1:42 pm
What do you do about lights when its MOT time then??? Just wondered as my pipe s might run near the back of the head light to :D
Very subtle! from behind anyway :mad: great work!
Jon_Bmw
Dangerous when thinking
Post Thu Nov 20, 2008 1:51 pm
appletree wrote:What do you do about lights when its MOT time then??? Just wondered as my pipe s might run near the back of the head light to :D
Get a £20 note out :)
Phill172
Post Thu Nov 20, 2008 1:55 pm
haha, well i was just going to modify the lights so the main beam is in the outers too? sure that can be done seen a few!
Like on the red and white turbod 325 in pbmw a while ago........
finally getting my arse into gear on this! ill have the head on and ic fully in by this weekend!
e30_Turbo
Boost Junkie
Post Thu Nov 20, 2008 5:57 pm
si- wrote:you not worried about that blocking up the rad a touch??
It'll be fine, with the increased flow you'll not notice the IC being there.
Phil, I'd flip it upside down and mount it behind the valence, just cut out above the vent to the bumper. Tidy, secure and as stealthy as you can go really.
I'll try find an old pic for you how I used to have my small one.
Fozz.
e30_Turbo
Boost Junkie
Post Thu Nov 20, 2008 5:59 pm
I bolted some mk2 golf full beams to the bumper and wired them in, worked a treat, looked a cooont!
Phill172
Post Fri Nov 21, 2008 9:38 am
would it be alright with the mounts for the valence cut out? iv mainly got it where i have as im being lazy about mounts! what did you do with your ones on your existing ic?
Fozzy im still dying to see your car mate!
o yea another question, sorry being at work i cant check, going down the local bolt and tool in a minute, what thread are the engine mounts? top side......
thanks for all the comments guys
e30_Turbo
Boost Junkie
Post Fri Nov 21, 2008 5:52 pm
Phill172 wrote:would it be alright with the mounts for the valence cut out? iv mainly got it where i have as im being lazy about mounts! what did you do with your ones on your existing ic?
The valence mounts are either side of the foglights, so you have plenty to play with.
The current IC is resting on the buper irons, I've made a fitted a bracket for it but it's fine as is, whem I flip it I'll need to make two extebsions to the bracket.
no idea on mounts thread, gotta be 14 or 16mm tho.
Phill172
Post Fri Nov 21, 2008 7:14 pm
thanks mate, yea i think that our ic's are pretty much idenitcal, im whipping the angle grinder out tomorow and start hacking it up a bit!
tbf i could proberly mount straight to the bit where iv already mounted too,
iv got to stop being lazy!
thanks for the info once again!
e30_Turbo
Boost Junkie
Post Fri Nov 21, 2008 9:45 pm
Phill172
Post Fri Nov 21, 2008 11:17 pm
So i decided tonight to finish work early and get on with some of the jobs in hand....
The cylinder head is now on, with the throttle bodies and fuel rail fitted too
Bit of a basted getting the gaskets to stay behind the tb's so used a tiny tiny tiny bit of almost spray glue just to hold them in place whilst I got the bolts in....
Managed to realise the wiring is a piddle of pee, well certain bits, so at least i can get the main harness on and tidyed ready and much to Ants relief I would imagine!
So anyway here we are just before the fuel rail went on.....
And heres the fuel rail fitted, just need to sort in plenum before that goes on, the linkage is so amazing, i actually bum it haha :o:
Next jobs, well as you can see, i wrote a list...........! As theres a few things i know i would forget about!
Really need to get cracking on this bloody oil system for the turbo and the rest of the car, also getting the oil cooler done too....
Ill put a picture up of it with the bonnet on too, looks 100 times better!
But anyway thoughts, bitchings, slaps let me know what you think!
Phill172
Post Sat Nov 22, 2008 12:27 pm
So id thought i drag it out the garage and clear up the garage before i get any further!
So here are some pictures of it so far.....
and a shameless picture of my other braveian brute :D
Phill172
Post Tue Nov 25, 2008 9:26 am
mmm done it again, the heads coming off again, I have ARP's on their way from the states......
with studs is it simply a case of nut and normal washer?
And again 30nm, 90d 90d?
Turbo-Brown
Boost Junkie
Post Tue Nov 25, 2008 1:33 pm
Pretty sure you just torque in stages, run it, then torque again in the old fashioned way as the studs aren't stretch types.
The ARPs should come with washers and bi-hex nuts too if they're anything like the ones I've got :D
