Assault wrote:Are you moving the Servo so that it clears the Plenum without modification?
I've got a golf MkII 1.3 servo and audi 25mm master cylinder, will I need to move it over to clear the plenum? If so, how far does it need to be moved?
Buster has fitted the Golf servo over approx 25mm, iirc. He still had to cut the plenum on his. From the discussions we have had (read above) I guessed that moving the servo over 57mm would be plenty and still retain some tolerance for engine movement.
Meanwhile..
The issue with the pull rod is finally solved.
I got the E34 pushrod PN 35211156454 last week but didn't have time to do anything with it. I have considered all other options but wanted to do something that didn't involve cutting and welding the bar. There would be tears over the cornflakes if it ever broke away
So, here it is. I cut the E34 rod down by 35mm on the pedal box end - Do not cut the servo end as it is reverse threaded! The E30 linkages look identical to the new ones supplied with the E34 rod but they are not. The slots in the E30 links are 7.2mm, 9.2mm for the E34. So chuck the new ones away and use the E30 items - see pic:
Incidentally, the standard VW linkage on the Golf servo is also 9.2mm so swap that for the E30 item as well.
The I just ran a M10x1.5 die down the bar until it nearly touched the crushed adjuster parts:
Closer:
As you can see the thread isn't very steep, that's because the rod decreases in diameter in it's main length. It is however enough to cut and hold a reasonable thread. The E34 rod comes with a locknut fitted, I used this on my E30 rod for extra security. (E30 doesn't have one as standard)
Next job is to drill the linkage through and fit a roll pin for extra security.
Hopefullt this weekend I can get the brakes parts refitted and start piping it all in
