Smug of York
Beemerlad's M52 Chromie
£173 to my door (more than the damn car cost me)
Smug of York
Smug of York
more pics and effort pls ya lazy fecker
www.oldskoolfantasy.co.uk
been under the car today with a can of waxoyl, god it's messy stuff. Don't yet know if it is going to come off my hands lol, but the underside of the car looks brand new again. It wasn't bad anyway and there was still plenty of the factory sealant to be seen after I attacked it with the pressure washer a few weeks back. Went to take some pics but every damn camera in the house has flat batteries.
I ordered the wrong engine mounts (E36 instead of E34) so the donk won't be going in for a few more days yet.
not a chance for Gaydon, but am aiming for pod in Sept.
Still no news on the manifold i'm afraid dude
- **BANNED**
Lee,those ARB's.Can you measure and post up the length of the rear one,the part that has the two holes for the droplink,please? Just want to compare to standard....
Youth is wasted on the young.
I'll try to do that tonight Malcolm.daimlerman wrote:Lee,those ARB's.Can you measure and post up the length of the rear one,the part that has the two holes for the droplink,please? Just want to compare to standard....
OK, so I measured from the end of the ARB where the drop links mount, to the far side of the bend (using an imaginary square edge on the outside of the curve) and it's 22cm.
Does that description make sense?
Good work Lee, its looking good
- **BANNED**
Bloody French ruler!! Expect you mean about eight and a half inches...now I have been under my car,I can see the difference,it did not hit me yesterday... standard bar has a second bend to slot into the droplink,do those ajustable one's come with a modified link?E30BeemerLad wrote:OK, so I measured from the end of the ARB where the drop links mount, to the far side of the bend (using an imaginary square edge on the outside of the curve) and it's 22cm.
i will see you there then my good man (he hopesE30BeemerLad wrote:am aiming for pod in Sept.
we should race up the strip! i know you have had practice runs....in an auto but your m50 tourer vs my m30 tourer
sounds liek your having fun with the ARB's
I will se3e if I can take some pics Malcolmdaimlerman wrote:Bloody French ruler!! Expect you mean about eight and a half inches...now I have been under my car,I can see the difference,it did not hit me yesterday... standard bar has a second bend to slot into the droplink,do those ajustable one's come with a modified link?E30BeemerLad wrote:OK, so I measured from the end of the ARB where the drop links mount, to the far side of the bend (using an imaginary square edge on the outside of the curve) and it's 22cm.
i am planning on using standard drop links to start with
Ric - you've got yourself a race Mr!
(subject to the turd being done in time)
non vanos rightness
Will do rather nicely when there's a turbo hanging off the rear end of it in due course too
OK Malcolm, here's a pic of the measurement of the rear bar, in old money
close up of the drop link mounting points
Front bar, standard v council dynamics
front drop link mount points
Mmmmmm, oxblood
Mmmmmm, oxblood
I'll ring him tomorrow Carl and let you know, if he's about I may be able to pick it up tomorrow after work.
E30BeemerLad wrote: Ric - you've got yourself a race Mr!![]()
thats the worry
you only got it in there cause you aint got a rad got a rad yet!jaffro wrote:even got viscous fan in there![]()
- **BANNED**
Thanks,Lee, how are you going to mount the standard rear droplink to that rear ARB? The standard item has a futher 90 degree bend,where yours has the holes...to enter the bush on the link end...looks to me like a rose-jointed link similar to the front one will be needed.
i will probably hunt down a rose jointed link from someone like
http://www.fastroadandtrack.co.uk/frat/ ... ?adid=2528
- **BANNED**
OK Carl, I've just spoken to the dude about the manifold.
He said he wants to keep hold of the old one just until he has finished welding mine up just so he can check mine hasn't distorted after welding etc etc.
He said he hopes to get mine welded up on Saturday and back to me, so it's gonna be early next week at the earliest I'm afraid, will let know know at the weekend if I get them back.
Sorry it's dragging on, i'd be doing my nut if my engine was in and running
Ordered my E28 M5 engine mounts today from Zimmer, should be here tomorrow, so with a bit of luck and dry weather i may have the mill fitted by the weekend.
naah, it was way too hot to do anything
Sorry, no news on the manifold yet, I had hoped to have it back from him by now but he's avoiding me at the minute, grrr
naah, it was way too hot to do anything Mad
lol to hot to cold to wet this country is crap for the weather
dont worry bout mani ive still got bits to do yet just wired my ews so i can use the immobilisor on it
E30BeemerLad wrote:naah, it was way too hot to do anything![]()
As in the one where we ripped out a M40 and 'slotted' in a M50 etc?
Cheeky buggerE30BeemerLad wrote:sorry to hear of this Tony, hey maybe I will have mine working before OB's
Got stuck in and made a bit of progress with the swap today.
The old engine mounts were a bit of a mo-fo to get undone, one of them eventually snapped the thread, which made life easier. The gearbox mount was also a pain in the arse.
this is the lump dangling precariously before the fun started
If only i knew the grief ahead of me
and the problem I ended up with, passenger side on the mount
driver side a good inch away
will try spinning the mounts around and see if that cures the problem
