The only thing the M54 (3.0L) is good for is the crank! at 89.6mm stroke you can use it for a 3.0 or 3.1L M20.
The rods are 135mm, probably light but don't sound too strong.
To use M52 rods or not to use M52 rods, that is the question
march109
Turbo-Brown
- Boost Junkie
Bugger! Sorry dude, completely forgot to bank your cheque today!
march109
I'm not in a major hurry don't worry. Skint again till payday anyway so can't afford to start the rebuild till next month now anyway. and Custom pistons are still about 6 weeks away.
Turbo-Brown
- Boost Junkie
Ooh, you ordered a set then?
march109
Yup, went for the same as you, however I did make up a little spec sheet for myself and consider an 86mm bore for an extra 70cc but felt it was too much of a risk going for a larger bore.
Also considered selling the 2 M52 cranks I have and the ETA engine for a M54 crank and go for 3.1L on a 85mm bore. Which would still work with the pistons I ordered.
Went for the same spec as you, though I was qouted 8 weeks because of the ceramic coating.
reggid
the bigend bearings are larger iirc......... the ones that work are the US ones S50b30 US and S52B32.jaistanley wrote:Are the S50B30 and the S50B32 rods the same then?
Arrow rods from VAC
http://store.nexternal.com/shared/Store ... oducts.asp
These Verdi ones from PPF in 130mm, 135mm or 140mm will do the job
http://www.pure-pf.com/webshop/ppf_webs ... cts_id=316
ARP rod bolts are a must
