another S50 swap! now TURBO
bigpimpin
Post Wed Apr 11, 2007 9:10 pm
Ahhh, those pics bring back fond(? :mad: ) memories !
Gaz, I have a 3.25:1 M3 LSD sitting in my garage. It locked up due to lack of oil but I think the actual LSD bitty is interchangeble between diffs. It doesn't look damaged when I took the rear cover off so I presume its that LSD bit thats buggered.
www.m3touring.com
ian332isport
Post Wed Apr 11, 2007 10:12 pm
Gaz,
I've done your charts 8)
If you let me have an email address, I'll send them over.
Ian.
gazatron
Post Wed Apr 11, 2007 10:42 pm
cheers ian i have pm`d you my email.
Yeh im BMW through and through so yeh it is jap wrongness, but it goes like stink dyno`d at 304 bhp and in a egg carton also 4x4!! :D
been down the unit tonight didnt really do to much except give the car a good coat of looking at. but i have got a few questions if any one is feeling knowledgeable.
what gear box set up have you guys used i.e cross memeber, selector rod etc.
ive gone with e36 crossmember, e36 shifting arm, e30 selector. and e36 shift lever. it all fits well but the shift lever sits slightly to the right in the
car rather than central just wondered befor i have a tinker?
buster
Post Thu Apr 12, 2007 10:22 am
Hmm.strange actually as mine sits slightly to the right ( 6 speed ) .
It sat more to the right with the e30 gear lever but when i used the original evo one it put it more to centre,but like i said, still slightly to the right.
Do you want a picture ?
gazatron
Post Thu Apr 12, 2007 2:17 pm
yeh mate do a pic, it changes gear fine just 5th sits very close to the center console
doing some more tonight a few bits came today so ill put up some pics where im upto, going to finish the wiring to thanks to ian :cool:
buster
Post Thu Apr 12, 2007 8:28 pm
5th gear is ok on mine,not close to console.Infact in the extremes ,reverse and 5/6 th it seems centred.
Pics speak a 1000 words.
Natural/relaxed not in gear :
Reverse :
5th gear :
There you go,
cheers,
andy
gazatron
Post Thu Apr 12, 2007 11:19 pm
cheers mate, im going to have to play around with the linkage mine seems a bit more over than that, any sugestions any one?
i have a few questions with pics if thats ok guys?
lambda probes and reverse switch, right?
relays, mass meter plug and red eyelet and black eyelet, where do the eyelets go?
diagnostic plug, one black eyelet and two red ones one fatter than other where do these eyelets go?
expansion tank, the two smaller outlets near the cap, one goes to the rad, the other???
cheers people!
old_skool
Post Thu Apr 12, 2007 11:22 pm
Vent pipe, goes down through the inner wing.
gazatron
Post Fri Apr 13, 2007 12:19 am
ok thats easy solved, any one else got any sugestions for the others?
gazatron
Post Fri Apr 13, 2007 6:27 pm
i think i may have sussed them out now if any one can just tell me if this sounds right?
the pic of the two wires with the relays, the red one is the live for the fuse box not needed of the e30 one is in place. and the black one an earth?
the two red with the diagnostic plug fat n thin go to the bat + terminal on the bulkhead, and the black is an earth?
sorry to mider but want to get this right for obvious reasons, "whats that smoke!!!!!"
jmc330i
Post Fri Apr 13, 2007 7:09 pm
gazatron wrote: lambda probes and reverse switch, right?
Yup, reverse lead isnt needed as you use the E30 one.
Both are live - if you peel back the black sleeving you should see the wire is red. I think both connect in the fusebox (Im sure thats what Ive done). I removed the E30 fusebox live and used the E36 one as it looked neater.
James
'91 325i Sport
'93 318i touring 16v
jmc330i
Post Fri Apr 13, 2007 7:16 pm
gazatron wrote: diagnostic plug, one black eyelet and two red ones one fatter than other where do these eyelets go?
Black should be the earth, cant remember where I fixed it to the body - probably inner wing on drivers side (where the M20 coil was).
2 reds to the battery +ve terminal - smaller one can go to the smaller wire on the +ve terminal which is fused IIRC.
James
'91 325i Sport
jason90m
Post Fri Apr 13, 2007 8:30 pm
yep, lambda probes. also wanted to mention that they are numbered. #1 and #2 with the plastic yellow rings near connector. lambda probes are also numbered. #1 goes to cyl. 1-2-3 and #2 goes to 4-5-6. dont mix them up, car will not run correctly. cheers, jason
e30Alex
Post Fri Apr 13, 2007 9:25 pm
hey gaz, you based in southport by any chance?Alex
Im a two car man. Shame my bike gets used more.Damn the MOT!
MR_SAZ
Post Tue Apr 17, 2007 1:19 pm
i just just my intake manifold lastnight....far out if only i saw this thread b4 hand.... :( i still may move it over before wielding up again... i dont want to lose BHP's...looking good guys!!!
bigpimpin
Post Tue Apr 17, 2007 4:25 pm
Yeah, what he said, I found out eventually !
:mad:
www.m3touring.com
gazatron
Post Sat May 05, 2007 7:50 pm
alrite guys sorry for the lack of posts not been doing too much on the car recently, its pritty much finished except for last few bits mainly waiting for the exhausts to be made on the 15th of may othwise it would be done!!
we have had it running in the car but with no exhaust, manifold back, its far too noisey to do anything with.... ill get some pics up. its getting painted this week so if not before it goes when its nice and shiney when it returns!
has any one uprated their calipers, thinking four or six pots, did you have to change the servo again from the audi one?
and any comments on a nice black to paint the car while its having a full hit?
Post Sat May 05, 2007 8:22 pm
what about one of the blacks from the e46/e60?!
Video of it running without manifolds? Where you getting them done?!
gazatron
Post Sun May 06, 2007 1:32 am
yeh they are nice blacks but they scratch so easy, i dont think i have seen one without swirl mark scratches in it! the manifolds are on now and bolted up, a lad we know modified our original one, only took him a few hours or so over a couple of nights. but its still very loud and the lamda probes are just dangling there!
changing the subject slightly been offered a diff off a zm roadster (or coupe cant remember which one) cheap enough is it more the ratio that is needed over the 325 lsd thats on now, plus it has the cooling fins which look cool :cool:
Post Sun May 06, 2007 7:53 am
worth getting for the backplate maybe.. Its a different style of LSD tho, but does fit
Assault
Post Mon May 07, 2007 12:32 pm
I've put a ZM roadster diff in ours but we used the ZM trailing arms/brakes and half shalfs/axles. It bolted up to the E30 subframe, prop shaft and rear diff mount no problem. the ratio is 3.2:1 I believe but to fit the m325 half shafts/axles you'll need different drive flanges as the ZM flanges are larger than the end of the E30 shaft. I dont know if the standard 325 flanges will fit into the ZM diff, anyone?
jason90m
Post Mon May 07, 2007 10:17 pm
Assault wrote:. I dont know if the standard 325 flanges will fit into the ZM diff, anyone?
yep. the 325 diff output flanges will pop into the mz diff. im using the mz diff with the 325 output flanges and 325 half shafts. cheers, jason
gazatron
Post Tue Apr 01, 2008 10:49 pm
re opening an old thread, this is where im upto with the car at the moment. the car was on the road as an s50 see the first two pics. since then ive taken it off the road for a turbo conversion and had lots of the engine chromed and some coilovers :D , this is where im upto so far............. any idea where i can get some acl type bearings for the bottom end also some arp bolts??
Image[/img]
isTURBO
Post Wed Apr 02, 2008 1:42 am
Hi mate
Great thread :D
For the arp bolts try Mark ( Fozzymonster ).
I got a set off him. :cool:
Heres one of his threads, you can PM him.
HTH
Rivaaj
Imageselling more bunnies to pay for my conversion
GraniteE30
Post Thu Apr 03, 2008 11:14 pm
Hi mate,
That looking great so far, fair play to you! Thats gonna shift when its finished! :cool:
What sort of BHP you aiming for?
curryp
Formerly cuzz1510
Post Fri Apr 04, 2008 10:41 am
what sort of exhaust and fannymould are you using? :cool:
orr
Post Sat Apr 05, 2008 11:30 pm
can anyone tell me what that servo is off it looks nice and small
ed325i
Post Sun Apr 06, 2008 3:38 pm
[quote="old_skool_2002"]This may be of some help:
Golf MkII 1.3 servo (ATE item) moved over 57mm on my car
Did you put that bracket on ?
Mine hasnt got it.
orr
Post Sun Apr 06, 2008 7:06 pm
thanks i have a golf gti one fitted,it must just look smaller in that photo
gazatron
Post Mon Feb 09, 2009 10:36 pm
little upp date if any one is interested, ran the car as a turbo for a while on standard comp ratio, cracked a ring land in the end so went for the whole hog rebuild. spec-
s50b30
je forged pistons 8.5.1 ratio slight oversize
forged con rods
crank polished and balanced
nearly all internal parts renewed
gt30 turbo
vanos removed
kms stand alonew with map sensor and wideband
rc injetors
steel headgasket
light weight flywheel and padle clutch
apexi avcr boost controller
mocal catch tank
sard fuel regulator
ally rad with spal fan
mocal oil cooler
fk coil overs
k sport 8 pot 330 disk kit front
k sport 6 pot 330 kit rear
h and r anti roll bars all round
polly bushed
tilton pedal assembly with bias adjustment
arp head, main and rod kits
and more i have forgot, hoping to get it running this week and then mapped :)
does anyone know of any other RHD e30 s50b30 turbos????
Image[/url]
mattm
Post Mon Feb 09, 2009 10:40 pm
Christ on a bike!!! That looks crazy!!! :cool:
Top work mate. My hat goes off to you!
Post Mon Feb 09, 2009 11:05 pm
:eek: Hats off to you sir!
Post Mon Feb 09, 2009 11:27 pm
Christ on a bike! Bet that will shift.. :eek:
Post Mon Feb 09, 2009 11:48 pm
Out of interest, do you get fuel stavtion problems when cornering with less than half a tank? Also what fuel pump and tank are you using?
I ask as i have this problem with my S50B30.
gazatron
Post Tue Feb 10, 2009 12:00 am
dont really get starvation never run below 1/4 of a tank if it can be helped, got a walbro 255 as low in the tank as possible. When we go past the 550ish bhp with a bigger turbo going to get a swirl pot and a bigger pump maybe a inline one too.
edited with spec i have remembered!
yeh it will shift i hope! i was just curious if there was any other rhd ones as i havent seen one, only lhd`s?
