ILL PROB OVERKILL THE WHOLE THING!!!
I was thinking of using the same RSJ i used in my house when we knocked the wall down. That should hold it
How much more power is that poor engine going to have to produce to counteract the weight???g57yle wrote:Yes Guys! Thats the first thing ill be doing LOL
I was thinking of puttiing another engine in the boot to add the extra power and using more RSJs for drive shafts LOLgortour wrote:How much more power is that poor engine going to have to produce to counteract the weight???g57yle wrote:Yes Guys! Thats the first thing ill be doing LOL
I was thinking of using the same RSJ i used in my house when we knocked the wall down. That should hold it![]()
Second turbo going back on???
All i know is everything happens for a reason.gortour wrote:Love it. can't WAIT to see THAT...![]()
Glad you still have a sense of humour, I'd have been well upset if that had happened to my car...
E39 diff in my workshop has a rear cover with two mounts, but I'm sure I've seen pics of a diff in an E30 with a two bush rear cover. Don't recall whether it was an E30 type medium case diff with a different rear cover, or a totally different BMW diff grafted in. Either way, the body mount for the two bushes had been fabricated from scratch and welded on to the shell.g57yle wrote:Brianmoooore wrote:Isn't there a rear cover that fits the diff that has twin mounts?
Hi ant, I know anything can be done, and i know ill do that on my next chassis but i think ive put this one through way too much, and id live to have a compleatly mint one now, Thanks for the positive feedback though, its actually the largest type of garrett GT35R im using, they are rated at 600hp by garrett but are well known for producing 700hp on a variaty of motorsAnt wrote:assuming the shell is rot free( looks OK in pix) why not rear half the car dude ?
then you could use the rollcage as the structural memeber in the back, and carry the diff directly on the cage and triagulate back to the strut tops and chassis rail.
2 birds, one stone ?
I have been involved a in a fair few hotrod builds and this is normal for those guys.
Hell, slap a 9" in the back with a locker, job jobbed
Good project BTW![]()
Super T60 snail ? cant quite see in the pix
Really?kam325itouring wrote:yo dude seen this around phat car, i live bout 2 minutes from you....... im sure it can be reinforced and welded back rather than reshellin???? im looking to do somyhing to my tourer, but dunno what yet..
Just about what I was thinking! I don't know of too many twin cam, belt driven BMW motorsJon_Bmw wrote:I'm being a bit dim today, but that isn't a bmw lump that i've come across. Supra lump?
Hi Fuzzy, to tell you the truth i never really knew what i was doing to my car, and i dont like saying something and never comeing through, so at least i can say I DID ITfuzzy wrote:thats a mighty fine looking project youve got there mate ,you kept this quiet,never heard of this one beforepitty about the mishap but im sure itll come good in the end.
you weren't wrong there JonJon_Bmw wrote:
Beemerlad is going to wet himself in excitement
E30BeemerLad wrote:wooaaaah! Can't believe I missed this thread!!!![]()
Been having willy coughs for some time thinking about some german/jap infusion.I'm too pikey to stretch to a 2JZ with 6 speed box, so I am planning on using the 7M-GTE out of the MK3 UK Supra as they are buttons for a MOT failure car.
Does the 2JZ drop straight on the E30 mounts then? Had you already done the big single conversion before you put it in the car or did you still have the twin snails on there? Reason I ask is that the twins will be in a similar place to the standard mounted CT26 blower on the 7M lump and I'm curious as to how much clearance probs there may be with the steering column.
My car is going to be a rat look sleeper, maybe even a 4 dr, gonna probably keep it an auto too with the supra box so can brake boost it for good drag launches.
Good work with the rear end dude.![]()
Have a look at these threads from an aussie forum and you can see the work the guy has done with the rear end.
There are good pictures of the fabrication he has done to this exact area. If the rest of your shell is OK then I would repair what you have.
http://forums.eurocca.net/showthread.php?t=13398
http://www.cardomain.com/ride/720651
Right, I'm off to knock one out
yeh, i thought the rubber mount would help my rear end!BristolBulldog wrote:Just wondering. you are running rubber diff mounts. that won't help the amount of movement you were getting. I suppose you could argue it reduced the "thud" of a nasty bit of right foot!?
i would have gone poly all around, or even solid on that kind of power. and 500! i heard the e30 rear was good for 350 reliably (i know many do more).
good point. it seems like the rear beam mount bushes would have had to have failed prior to this happening? or the four moutng bolts tear from the rear subframe. This mounting point is more a stabiliser than a torsion control point.DanThe wrote:Thats just the bush mounting.
Its the 4 bolts holding the diff to the rear beam that im interested in, would like to see what happened there.
i think the entire diff/subframe assembly has rotated around the subframe bush mount points, i.e. the rear of the assembly has been forced down on a hard launch, and pulled the rear diff mount down with it?DanThe wrote:Thats just the bush mounting.
sounds right.Toby_Unna wrote:i think the entire diff/subframe assembly has rotated around the subframe bush mount points, i.e. the rear of the assembly has been forced down on a hard launch, and pulled the rear diff mount down with it?DanThe wrote:Thats just the bush mounting.
Interesting,BristolBulldog wrote:sounds right.Toby_Unna wrote:i think the entire diff/subframe assembly has rotated around the subframe bush mount points, i.e. the rear of the assembly has been forced down on a hard launch, and pulled the rear diff mount down with it?DanThe wrote:Thats just the bush mounting.
I wreckon he has rubber rear beam bushes. the torque (and wear and tear) has torn one out one end, and allowed all the torque straight through to the diff mount, which was only ever supposed to be a stabiliser.
The car could have easily re-seated itself back on the bush after, and he never knew?
I would drop the subframe, put all new poly bushes in. whilst its off weld the diff mount backup (as you did), and then put some extra plating on it as well. one think 1" wide plate 1/4" thick will go directly through the space between the two mounts. weld this in all along, seam welded. then plate either side.
you will need to check you havnt bent the subframe or chassis though. Quite possible you tore a beam mount as well, especially given the amount of movement, adn subsequent leverage you would have put through it.
