284/272 cam can HP be had over 6000 RPM?
Jon_Bmw
Dangerous when thinking
Post Mon Feb 26, 2007 12:13 am
handpaper wrote:
Jhonno wrote:288 works without pocketing the pistons.. anything over that and your looking at contact issues
Nice, but whose 288? Cams from different manufacturers will vary; lift and duration both need watching.
Simon13 wrote:288/288 = emissions problems
MoT for non-cat cars doesn't seem to include an emissions test anymore :)
I'd be more worried about getting the thing to idle properly without fitting ITBs. Then again, it's a marvellous excuse :twisted:
MOT's did check the last few cars I have put through an MOT, nothing a little vaccum leak can't sort out though :D
Post Mon Feb 26, 2007 2:37 am
ive heard of ppl 'losing' a cylinder to make US emissions.. :lol:
Handpaper.. My bad, generalising.. Shrick
Turbo-Brown
Boost Junkie
Post Mon Feb 26, 2007 8:14 am
Hmmm, both my car and my friend's Pug needed to pass emissions when they went through the MOT.
Another example of the broad variance in the test!
handpaper
Post Mon Feb 26, 2007 11:10 am
Turbo-Brown wrote:Hmmm, both my car and my friend's Pug needed to pass emissions when they went through the MOT.
Strange, that. I had to ask my tester to check my emissions (I had the ticket in my hand at that point, I just wanted to know if the engine was behaving itself). Maybe they just have faith in Bosch EFI?
Besides, it's not that hard to get CO below 3.5% - even carb engines can do it!
Jhonno wrote:Handpaper.. My bad, generalising.. Shrick
I made a worse mistake - forgot to mention timing. Get that wrong and you'll bash pistons with the standard cam :eek:
Post Mon Feb 26, 2007 7:40 pm
Very true!
ed325i
Post Fri Jun 22, 2007 3:19 pm
So would a schrick 302 cam have contact issues ?
e30_Turbo
Boost Junkie
Post Fri Jun 22, 2007 3:41 pm
My last MOT, about three weeks ago required a emissions test.
Ended up spending 30mins with the analyser up her while I fiddled and he watched the monitor for pass readings. I thought something had gone wrong when the tester jumped across the ramp and hit the print button!
But he returned to show me the readings were ok, so he hit the button before I tweeked it anymore.
Proper PITA tho and pointless as the min I passed we retuned the idle and just to see we stuffed the probe back in, all I'm saying is my car isn't very green :eek:
Mark.
Post Fri Jun 22, 2007 4:33 pm
yes i think it would..
You can pocket the standard pistons a little i believe tho (i know you're doin a complete 2.8 build)
Ant
Retired Team Member
Retired Team Member
Post Fri Jun 22, 2007 7:38 pm
but pocketing the pistons will drop the CR and negate any gain for the ludicrous camshaft profile.
Avoid Ed, one for Tb's and 4K plus driving.
ed325i
Post Fri Jun 22, 2007 8:36 pm
I am going to avoid it Ant :)
