318i to 325i...Complete, Still a problem tho!
Lee_Coupe
BEWARE Zone Thief
Post Wed Jul 12, 2006 11:04 am
:mad: Really confused now! lol.
Part 3 on that link kinda looks like the thing Ive got, But...
So that should be there then?
As the other prop Ive got hasnt got one.
Thanks again
jmc330i
Post Wed Jul 12, 2006 11:21 am
My 318i prop didint have one (part No.3) either.
This is my 325i prop - the top one in the pic....
It sounds like youre talking about the prop centre bearing - you 100% need that.
'Part No.3' is the vibration damper and is right up by the gearbox, under the gear linkage.
James
'91 325i Sport
'93 318i touring 16v
Lee_Coupe
BEWARE Zone Thief
Post Wed Jul 12, 2006 12:41 pm
Ive fitted thw 2.5 one... the one at the top of the picture, Huum changed over all the linkages aswell so find it odd that it would be catching.
The rubber donut thing at the very top of the picture I fitted aswell, would that be causing it? :mad:
jmc330i
Post Wed Jul 12, 2006 8:39 pm
Lee_Coupe wrote: The rubber donut thing at the very top of the picture I fitted aswell, would that be causing it? :mad:
You need that as that connects prop to gearbox. It could be catching, might be worth checking, but I think you said the noise goes away when you depress the clutch pedal - if so, then I doubt its that because it will rub the linkage whenever the car is moving, no matter what the clutch is doing.
The M20 gearbox is known to make a rubbing/grating noise, its just one of those things and not really anything to worry about. Even a gearbox rebuild doesnt always sort it.
James
'91 325i Sport
Lee_Coupe
BEWARE Zone Thief
Post Thu Jul 13, 2006 1:26 am
Huum it's a little more than just a noise mate, the whole car shakes and judders 8O
Post Thu Jul 13, 2006 8:56 am
Part 3 can be left off with no ill effects. The bit in the middle is the support for the centre bearing, and must be intact and in good condition.
Have you slackened off the sleeve nut on the sliding part of the prop and set its length correctly?
Lee_Coupe
BEWARE Zone Thief
Post Thu Jul 13, 2006 12:41 pm
Brianmoooore wrote:Part 3 can be left off with no ill effects. The bit in the middle is the support for the centre bearing, and must be intact and in good condition.
The sleeve nut was slackened yes, how would I know if its set at the correct length?
Lee_Coupe
BEWARE Zone Thief
Post Thu Jul 13, 2006 2:37 pm
right just got the car in the air,
I grabbed the spare gearlinkage off the old 1.8 engine, and matched them up. the 1.8 one is longer than the 2.5? correct? it looks like the prop is catching on the linkage and needs to be moved up! Would I be ok just bending it as done on the z3 lever change?
How will this affect the gear selection?
Thanks again
