stevetigger
Post
Sat Apr 22, 2006 2:47 pm
Im sure thats two pipes going to the M/C
Post
Sat Apr 22, 2006 2:56 pm
We're both right, Steve. 3 ports, 2 pipes. On an ABS car, one of the fronts is blanked with a plug, a single pipe goes to the ABS unit, and the split occurs there. Non ABS cars have sperate pipes to the m/c.
stevetigger
Post
Sat Apr 22, 2006 2:59 pm
So I can go out and fit my Audi M/C then?
Its just that the end looks fat! The bit that goes into the servo, its like 13mm hole! Im sure my BMW one is like 7mm.
So I can plumb in the two pipes and block the other two, I just need one more blocker?
stevetigger
Post
Sun Apr 23, 2006 3:06 am
The Audi M/C fits like a glove but..................
Now my brake pipes are about three inches to short! What do you guys think I should do??
Im thinking, just buy a roll of brake pipe and make me own!
Post
Sun Apr 23, 2006 10:29 am
you can replace very brake pipe on an E30 with non rust "cunnifer" brake pipe for about a fiver.
You'll probably need to change the pipes at the back of the car in any case.
Post
Sun Apr 23, 2006 10:57 am
About the larger sized thread for the forward most brake pipes Steve, I had the same thing with my master cylinder, I tried to get a set-screw to blank it off but was told that size does not exist in set-screw form. I think it was 12mm with a 1mm pitch, I ended up pulling the chopped piece of pipe out of the union, filling the hole with weld and screwed that back in.
Post
Sun Apr 23, 2006 11:02 am
Brianmoooore wrote:you can replace very brake pipe on an E30 with non rust "cunnifer" brake pipe for about a fiver.
You can buy the genuine lines from the dealers cheap enough, they have the unions on the ends, but you will need a pipe bender as they come straight.
The cunnifer pipe is rust free, but looks horible IMO.
stevetigger
Post
Sun Apr 23, 2006 11:35 am
But my genuine lines arnt long enough
Ive got one hole blanked already and Im going to go to Bmw to by another blanking plug because my M/C had one in it, so BMW must do it!
Post
Sun Apr 23, 2006 11:52 am
??? It looks identical, except for the bronze colour instead of grey.
stevetigger
Post
Sun Apr 23, 2006 12:04 pm
So I just buy a roll of "Cunifer"
Post
Sun Apr 23, 2006 12:45 pm
stevetigger wrote:So I just buy a roll of "Cunifer"
Cunnifer pipe, metric ends, a small tube cutter and the tool to make the flares.
Pipe still seems to come as imperial 3/16", but is the correct size.
stevetigger
Post
Sun Apr 23, 2006 12:49 pm
metric ends, I could just use mine??
Post
Sun Apr 23, 2006 12:52 pm
stevetigger wrote:metric ends, I could just use mine??
They're about 8p each, tightarse!
stevetigger
Post
Sun Apr 23, 2006 12:55 pm
ok ok, where would I buy it? My local motor factors?
Post
Sun Apr 23, 2006 1:00 pm
That's where I get mine.
buster
Post
Sun Apr 23, 2006 1:01 pm
the picture below is the 25mm audi Master cylinder.As you can see the original pipes are too short so i had to make new ones also.
Also you can see in the pic that mine came with the 2 blanking plugs already in the audi M/S.
stevetigger
Post
Sun Apr 23, 2006 1:04 pm
Thats the one, I had one blanking plug! But bmw, do them
part number
34311103475
Post
Sun Apr 23, 2006 1:10 pm
I still got these to reach Steve
stevetigger
Post
Sun Apr 23, 2006 1:12 pm
Just wish the BMW bottle would of gone on the Audi M/C
Post
Sun Apr 23, 2006 1:15 pm
buster
Post
yeah,i bought a new one from rally design but theres probably loads in the scrap yards that could be used.
stevetigger
Post
Sun Apr 23, 2006 1:22 pm
Yep, bought mine....£7 hehe
Post
Sun Apr 23, 2006 2:55 pm
buster wrote:yeah,i bought a new one from rally design but theres probably loads in the scrap yards that could be used.
Stupid new regs mean all the resevoirs in my favourite scrappy now have holes in them!
Post
Sun Apr 23, 2006 2:57 pm
Buster's pic looks like he has used a couple of bleed nipples as blanking plugs.
stevetigger
Post
Sun Apr 23, 2006 3:06 pm
True, mine is like a proper matel screw with a bolt head!
buster
Post
Mon Apr 24, 2006 12:35 pm
thats how mine came with 2 bleed nipples with rubber caps on them.
buster
Post
Mon Apr 24, 2006 12:38 pm
Brianmoooore wrote:buster wrote:yeah,i bought a new one from rally design but theres probably loads in the scrap yards that could be used.
Bugger,i didnt know that.They arent doing that around here mind,not yet anyway.
Post
Mon Apr 24, 2006 1:11 pm
They have to remove all the fluids. Looks like they're using some kind of drill combined with a vacuum pump for the job at my scrappy.
Others may use different methods.
buster
Post
Mon Apr 24, 2006 1:19 pm
Brianmoooore wrote:They have to remove all the fluids. Looks like they're using some kind of drill combined with a vacuum pump for the job at my scrappy.
My local ones arent doing that yet, i was in not long ago and pulled one off a golf and it was still full of fluid !
So do they have to drain all fluids ?? coolant fuel etc ?
stevetigger
Post
Mon Apr 24, 2006 2:47 pm
I just ordered a new stopper for the M/C today from my "BMW" dealer.
64pence
Andy335Touring
Post
Mon Apr 24, 2006 5:59 pm
alexbaby88 wrote:BTW some trawling through Ebay, I understand that the Brake servo from the E30 325iX will do the job and is the solution used in Germany for E30s with M50/S50 engine conversions. From the pics, the iX serco is of a smaller diameter but there seems to be 2 servos piggy backed one behind the other.
So, anyone here tried the iX servo?
Sounds interesting, i found these pictures on ebay.de
O/T but i also saw these adjustable rear TCA mounts, would be cool for a track car
Post
Mon Apr 24, 2006 6:08 pm
Ive seen the ix servo on a few US conversions, more common part over there.
Those adjustable TCA rear mounts would be good for E36 strut swapping!!
jaistanley
Post
Mon Apr 24, 2006 8:05 pm
The onloy problem I can see with the iX stacked servo is that it may push the master cylinder further out, fouling the large rubber 'sock' (on S50 engines, not sure about M50).
Anyone agree?
Jai
Post
Mon Apr 24, 2006 8:18 pm
jaistanley wrote:The onloy problem I can see with the iX stacked servo is that it may push the master cylinder further out, fouling the large rubber 'sock' (on S50 engines, not sure about M50).
Anyone agree?
Jai
Heres what they do in the US
stevetigger
Post
Mon Apr 24, 2006 8:38 pm
That looks crap!
Sorted my "short"brake pipe problem today. I removed the two that are short. Got the longest of the two and put it into the other hole, went to the scrappys and got other brake pipe the same as the above and did the same!
