Mapping problems! Please help!
Ant
- Retired Team Member
Jon you are correct apart from when the TPS is falling in value the fuel is cut, not reduced, the AFR drops to 18:1 and lower but the WB02 is outa range @ that point
the key to understanding the log is what is what, and what relationship each measured value has to the next.
TPS, RPM, MAP, MAT, and AFR are the real relevant ones to look at, the Pulsewidth and duty cycles are less of an issue for me and Mark as we specced large injectors from the outset.
Good stuff innit !
Good stuff innit !
Email FTW
Jon_Bmw
- Dangerous when thinking
Oh yeah of course it is, i'm an idiotant wrote:Jon you are correct apart from when the TPS is falling in value the fuel is cut, not reduced, the AFR drops to 18:1 and lower but the WB02 is outa range @ that point
When i first looked at those maps it scared the be jesus out of me but the more you look at them the more obvious relationships you can pick up on and understand. Patience with my slow brain is the key i think.
lentec
- Boost Junkie
Think ive poped it guys
After trying the original vr6 ignition map with my fuel map
just to see what it went like! first time i gave it boost over 3k it knocked like fcuk!
Then felt like it was running on 4 pos 5 cyl
So stoped to have a look just to realise i had no tools or spares onboard!
Called out the brakedown service (friend with a van) pulled the plugs out cyl 5 & 6 looked black n wet?!
Limped it home!
Prety sure the head gaskets poped between the cylinders gonna have a look in the daylight.
Limped it home!
Ant
might be lucky and just fouled the plugs if they blew out under boost Len, any smoke when she went POP ?
Keep us all updated dude !!
Email FTW
e30_Turbo
- Boost Junkie
Jon_Bmw
Oh bugger Len, as Ant said was there any large quantities of smoke as that is usually a good indication followed sometimes by the good old mayo.
Hope it isn't though, good luck chap.
Jon
Jon
lentec
- Boost Junkie
Na no smoke! exhaust did sound funy tho.
Done a compression test today cyl 5 & 6 no compression at all
think the gaskets blown between the cylinders! as when the needle jumped on the cylinder being tested it was hissing on the one next to it!
Prob explains the pulsing from the exhaust. no water in oil as i sealed it all with wellseal.
Will be good time to give the head a once over!
Jon_Bmw
Opps! but at least you don't seem too pissed off with it, to be fair you are probably getting bloody quick at taking the head on and off these days. Respect.lentec wrote:Na no smoke! exhaust did sound funy tho.
Done a compression test today cyl 5 & 6.
Andy335Touring
Sorry to hear about your problems Len
I hope its an easy(ish) fix for you ?
Turbo-Brown
- Boost Junkie
Oh Lame!
Hope you can get it fixed soon Len!
How much more advanced was the VR6 map than yours? Or was it just not retarding under boost?
Don't suppose anyone knows how to test a MAP sensor do they? Don't think mine's working. Also, do they need to be mounted on something metal?
Toby_Unna
- Boost Junkie
my mr2 did the same thing, blew an inch long hole between 2 cylinders without going near the water or oil.
and i suspect it'll happen to the e30 eventually!
Alex, what ecu is it, emerald? will they help you troubleshoot?
Turbo-Brown
- Boost Junkie
Tis an Emerald yaa.
It's an external MAP sensor though. Seems to give the same reading all the time though
Toby_Unna
- Boost Junkie
aha gotcha
only said it cos i've just soldered mine onto the MS board!
lentec
- Boost Junkie
Think by now i can change the head gasket in about 2 hours in the dark on my own! so not realy a problem just a minor setback
Alex i had problems with the map sensor it was giving the same reading all the time! turned out to be wired up wrong. i would check that first.
Turbo-Brown
- Boost Junkie
Yeah will have to have a look at the wiring, but I tested the MAP sensor off the car with a multimeter and the readings never changed then either, despite having almost 1bar of vacuum applied!
lentec
- Boost Junkie
Thats odd
What type of map sensor is it?
chip-3door
If the map sensor value isnt changing, then you are utterly wasting your time trying to map it.
No way you will get it to work in that circumstance.
What map sensor are you using?
If you ask on passionford there is probably someone local with a 2 bar one you can have for pennies as they arent much use on a cossie as everyone goes over a 1 bar of boost as soon as they tune them.
Obivously only any good if you arent going over a bar yourself though!
Turbo-Brown
- Boost Junkie
It's the one in the piccie below (on the right of the picture with little blue hose going to it)
Only planning to run 7psi or so so a 2bar (which it is at the moment) would be fine.
Will have to borrow a mates to see if that works!
Cheers chaps
Cheers chaps
chip-3door
Looks like a bosch one, same style as cossies use.
glenn
- Engine Transplant Services
len,
i have got a std 2bar map sensor out of a cossie, here.
give us a shout if you need it
Turbo-Brown
- Boost Junkie
Aah sorry, see what you mean!
It's a Magnetti Marelli (sp?) one.
It was supposed to be brand new, but was an ebay purchase months and months ago so there's no real comeback now.
Oh well, will test the system with another one this weekend (if it passes the MOT) and take it from there!
lentec
- Boost Junkie
Im running a 2bar sensor from a GT4 they are very small compaired to others!
Glenn thnx all the same but i have no problems with map sensor think you ment alex?
Turbo-Brown
- Boost Junkie
Len, I had a look at the ignition map from the VR6 yesterday and it looks to be pretty much the same as the map I'm using.
Think I'm gonna go through and knock a load out of the values tonight before I drive it again!
Turbo-Brown
- Boost Junkie
Sweeeeeeet
I have an MOT!
It also drives miles better than it did, although still not great.
Feels kinda reluctant to pull.
Probably to do with the extra fuel I dialled in all over the map and the fact that the fuel pressure's gone up too
I have an MOT!
miamistu
You'll have to change your sig now!
Toby_Unna
- Boost Junkie
Well done Alex
so i take it you went to a post office on the way home then
early bird gets the worm and all that... now you've got all day to play with it!
Ant
Wohoooo !
on the road and legal, a good day for ol brown indeed
Alex, yeah I'll lend a hand, I'll try and swop the emerald software from my desktop to lappy and sort a date for getting to you and we'll go from there
Defo need the ciggy lighter socket operational though, thats where the logger gets its juice
Toby, get that paperweight off your desk
Email FTW
Turbo-Brown
- Boost Junkie
Just had the tracking done with much pointing and laughing at the ICs from the mechanics. Little do they know eh?
Gonna go out and set up the TBs so that they're all syncronised with Andy's air flow gizmo (at last, sorry Andy!)
Whilst it's much better than it was, it's still really reluctant to accelerate! It kind of gently gets up to speed. Doesn't seem to cough or splutter, just takes a while.
Didn't really wanna give it full berries either for fear of melting something.
Cheers Ant, you're a legend mate!
If I get time I'll weld a lambda boss onto a down pipe.
Would one of them be enough d'ya reckon?
Cheers!
Ant
Email FTW
glenn
well done alex!
another project car hits the street.
"love it when a plan comes together"
Turbo-Brown
- Boost Junkie
Hooray!
Fairly productive day today:
I've got a Lambda sensor boss
What a satisfying job, take off a down pipe, cut boss from old M3 exhaust, weld boss onto down pipe, fit it all back up again
Might as well figure out how to connect a normal sensor up to the ECU now it's there too I guess.
Turbo-Brown
- Boost Junkie
Ooh!
Dad's managed to get the port on his laptop to talk to the Emerald so I've not got a computer that's mobile!
Also, wired up a narrow band lambda sensor.
It works, but it really is just a switch! just idling, you have a rich mix, tap out '1' on the fuel and it plumets to lean!
Also figured out how to get the data logger to work so about to go and have a play on the road
Ant
Email replied to Alex
Dont not attempt to tune with NB !! it will all end in tears !
I'll get down to you nextweek and we'll do it properly
Email FTW
