E30 CABRIO V12
S38B38
Post Sun Jul 20, 2014 6:17 pm
Small update....
I finally found a soulution for a single belt drive ,, to get as much grip on the vibration damper
Custom made ,, Guibo end to the gearbox.......... 110mm ((beat that)) made out of solid steel and turned by a lathe
overhauled diff ......... 3.46 LSD
some kind of strenght frame ......... E30 cabrio.......... ONLY i think
clean heatshield
the rarest brakefluid expansion tank ,,EVER in Iceland .. E34 540 touring 6g,, 1@499 worldwide made
Stainless steel rear muffler,,, designed by my idea,, have the dimension as oem 325 muffler,, got it tigwelded ,, and bended hollow stainless plate for pipe through the muffler
I will use 2 x 63 mm stainless pipes for exhaust
Sveinbjörn Hrafnsson
E30 CABRIO M70B50 V12 5lug
ALPINA B10 BITURBO 346@507
550 V12 JML Motorsport
mcspike
Post Mon Jul 21, 2014 12:23 am
You certainly don't f**k around...
Until you f**k around.
Ryan
S38B38
Post Fri Aug 08, 2014 12:43 am
Well,,,,,,,, the exhaust is finally done....... at a hefty price ouich
it was narrow but my man did it well,,, stainless all the way from oem manifold to the end.....
from manifold,, 2 x 42.4mm tubes and bends were used ,, and then in to 63.5mm
4 flange 8mm 316ss were made,, an X-PIPE and just 1 rear muffler + lots of bending and many meters of pipes
tight... right side of the car.. some mods because of the engine mounts
also on the right side,, developed..or designed in that way the starter can be taken out
drivers side.. the steering was the main factor of design
This explain it self 2 x 2 -->2,,,,,,,
and then in to X-PIPE...........
X-PIPE..
WIDEBAND,,,,,,,,
rear silencer
in front of silencer
M70B50,,, V12 oem exhaust tips
And the car on its way to the garage :hihi:
E30-Addict
Post Fri Aug 08, 2014 1:08 am
Hi Mate
Just saw this thread. I have to say you deserve applause for this hard work
You made me realize how strong these two words now (Custom & Modification)
Through these two words all most anything is f****** possible
After seeing this, I wont be surprised if i see a Ferrari engine in BMW E30
Keep up the hard work and looking forward to see this beauty doing its first burnout
going to buy some speakers now...
Sam
I know a lot about cars. I can look at a car's headlights and tell you exactly which way it's coming
S38B38
Post Mon Sep 22, 2014 12:11 am
E30-Addict wrote:Hi Mate
Sam
Thank you very much :D
S38B38
Post Mon Sep 22, 2014 12:12 am
E30-Addict
Post Mon Sep 22, 2014 1:05 am
:mad: :mad: :mad: :mad:
S38B38
Post Fri Oct 24, 2014 9:06 pm
Car is running........ final map.. roadmap tomorrow
but i am positive that i need a bigger radiator :P
S38B38
Post Mon Oct 27, 2014 7:30 pm
The pull is stunning,,,,,,,,,,,,,, really really great
and the sound also ...
but as said,, i must change the radiator,, as soon as possible
FormerMember
Post Sat Nov 29, 2014 8:16 pm
Now waiting for the summer then! :)
Sadly I can't hear any sound on your youtube videos - is it only me or is there something wrong? :-/
E30 Cabrio M-Tech, powered by V8
E34 M5 3.8 x 2
Alpina D10 Touring #33/93
E46 318i Touring
Toyota Hiace 4wd
S38B38
Post Sat Nov 29, 2014 10:01 pm
Hi Jonathan,,,
i dont know about,,, the video,, but the sound is STUNNING
and on full throttle, YES it sound like a fullblood Prancing Horse V12............ 8)
S38B38
Post Sat May 09, 2015 9:48 pm
Well after some tests with different radiators i finally have got the watertemp on an average results..
got a custom radiator ,, put in front of the frame.. 59cm in wide and 49cm in height,, the in and out is on the same size for most effective cooling,,
will post pictures later ,,,
ps,, still the same FANTASTIC torque feeling and stunning sound 8) 8) 8) 8)
S38B38
Post Mon May 16, 2016 8:15 pm
Well ,,, quite a bit since i posted some info about the car,,
small upgrade,,,
I was worry about the cooling temp,, the engine generates a lot of heat,,, 12 cylinder , lot of friction ,, so i had a custom radiator made for me... payed a fortune,, but the best solution so far i think,,, the temp on water is ok,, but IMO the oiltemp is way to high
oil temp is around 100°c ---- 210°f in normal driving,,, so i will buy me a V8/12 oilhousing with oilcooler output,,,,,,, so the temp can at least go down to 90°c --190°f
C´est la guerre
the radiator goes down to the bottom of the IS lip
And then i bought some hood louvres,,out of STEEL on ebay
http://www.ebay.com/itm/1-Pair-Angled-L ... 1407102274
we cutted a hole in the hood,, i stanced the outer ring so the metal plate was flush.. and then point welded it,,,,,,, damned ,,,,lots of force in such a thin metal,, the hood went like bananas,, but the result is impressive ,, even if i say so myself,,, very clean and looks like semi original
V12 auspuff
Regards
Kos
Post Mon May 16, 2016 11:51 pm
Constantly improving the car, lots of thought and detail going into it.
This is what makes an engine conversation, a good conversion
Post Tue May 17, 2016 8:00 am
You NEED to do a drive by video with good sound quality! :D :D
S38B38
Post Tue May 17, 2016 8:18 am
Thanksguys,, yes i ill do a video asap
