Very lucky !ant wrote:Zoners save the day again, how lucky were you Andy !!!
Some things not right with it though as it still wants to put that duff map in the ecu when you make changes.
First thing i did was load the proper map, check the fuel map was the right one and fired up the engine, much to my releif it fired OK !
I then adjusted the rev limit, programed the ecu and checked the fuel map and it had gone back to the duff map
So i reloaded the good map and didn't change any thing, better safe than sorry !
At this point the battery went on the lap top and i didn't have the power lead so i never had the chance to look in to why it was loading the wrong map or get around to changing the flow rates on the ecu so i couldn't fit my new injectors
I'm guessing it's some thing to do with the serial/usb adapter or may be i have down loaded the wrong version of the O/S from the web page ?
I will see if i can get to the bottom of it next time
I'm not sure TBH, i'm not very hands on when it comes to changing the mapping as you knowIs there a similar feature in Emerald peeps ?
