Are we talking M50 non-vanos cams here or across the board?Jhonno wrote:M50 cams are mildly better than B28
m52/m50 hybrid??
IIRC NV cams had 1mm more lift.
Gaffa tape is like "the force" - it has a light side, a dark side, and it holds the universe together.
There's nothing that shouts "Poor Workmanship" more than wrinkles in the Gaffer tap
- bulletproofbob
oh it gets better and better!!!
I could possibly have a NV head for sale shortly..........
- bulletproofbob
i've not looked into the chip aspect yet as my car is meant for the £999 event next year again.... what price are we talking??
the M52 has come with some nice lookin tubular exhaust manifolds, will these be better than the M50's cast items?!?
- Homo Hair
- Contact:
Chips aren't expensivebulletproofbob wrote:i've not looked into the chip aspect yet as my car is meant for the £999 event next year again.... what price are we talking??
Just 328i manifolds are much better
- Homo Hair
- Contact:
Both.. Non vanos ones are the peakiest, but even the 2.5 vanos ones are betterE30BeemerLad wrote:Are we talking M50 non-vanos cams here or across the board?Jhonno wrote:M50 cams are mildly better than B28
- eta
- Contact:
The M52 2.3 was actually a B25 with the intake used by the B28 detuning it. At least thats what I understand the 323i/523i to be. I'm sure there were other differences but as I am aware the intake manifold was one of the major ones.
- Rorty-corty
- Contact:
Hmm, I am thinking of doing this to mine aswell now. Then again, I suppose the longer stroke will make the engine slightly less inclined to rev and as the car is supposed to be a track day screamer (in a 5 series?!) I might just leave it as the shorter stroke 2.5.
I'm sure that the 328 and 323 use the 2.0ltr manifold. If you see them side by side you can see the differenceeta wrote:The M52 2.3 was actually a B25 with the intake used by the B28 detuning it. At least thats what I understand the 323i/523i to be. I'm sure there were other differences but as I am aware the intake manifold was one of the major ones.
I'm sure I was looking at a 2.0 M50 today in a breaker and the inlet manifold looked very similar to the 2.5, certainly larger than the crap I took off my 2.8
Is there any market for the 2.8 manifold & tb I took off the M52 Dan, or should I just chuck it in the skip?
- bulletproofbob
so what chip for the M50B28 then, and from where???Jhonno wrote:Chips aren't expensivebulletproofbob wrote:i've not looked into the chip aspect yet as my car is meant for the £999 event next year again.... what price are we talking??
- bulletproofbob
i'll only replace if they are badly worn...sharp3r wrote:can you use m50b25non vanos piston rings on a m52b28 piston? take it you are replacing yours?
Sorry to dig this old thread up, but I've bought a cheap 323 lump. I understand it has 2500ish cc. I understand the Alloy blocked M52s were detuned units.
If I were to fit an M52 Vanos inlet (inc injectors), throttle body and ECU would I see decent power, or should I get M50b25 cams too?
Thanks chaps.
Thanks chaps.
Be a man for once in your life and sh!t in that boot!- Wilfred.
They are detuned with the inlet manfold, put an M50 inlet on to open it up.
Here's a thread that will help you
- bulletproofbob
seeing as it got a bump.... i'm still building the lump but its now going into an e30 instead of the e36 i have!! dropped on a track day e30 needing minor tlc off the mighty zone for sale section, and it was only about 5 miles away!!!!!!!
how much better than the m20 is an m50/52 though? i know its a common swap but is it a truely worthy swap?? this a track/ring trip car!!!!!
I've had the M20B25 in a techII and now have the M50B28 (in one of my chromies), which I assume you are still intending to build...bulletproofbob wrote: how much better than the m20 is an m50/52 though? i know its a common swap but is it a truely worthy swap?? this a track/ring trip car!!!!!
You will notice a bit of a difference, I'll say that much
