E30 M3 + S50B30
pony2
Post Tue Nov 17, 2009 1:26 pm
Mine clicked like that when the battery died.
Post Tue Nov 17, 2009 1:29 pm
Ah.. Clicking sounds deffo like battery!
taper
Post Tue Nov 17, 2009 2:17 pm
Many thanks Jhonno :wink:
Today I buy one bew battery to try to start the engine
taper
Post Tue Nov 17, 2009 10:37 pm
fuc*ing battery
[youtube][/youtube]
[youtube][/youtube]
RoadHazard
Post Wed Nov 18, 2009 2:21 am
UweM3 wrote: maybe seized up, doesn't sound good. can you spin engine by hand?
Spinning engine by hand. Should I be able to do it with all belts attached to ancillaries? Where exactly should I grab on in order to turn it? And should it move freely indefinitely or should it stop after a number of turns? Thanks.
/// KAMI
Post Wed Nov 18, 2009 3:16 am
Good job it started..... 8)
THE ULTIMATE DRIVING MACHINE
Post Wed Nov 18, 2009 10:04 am
No..
Why should it stop? There is a point which stiffens where you open some more valves though..
RoadHazard
Post Wed Nov 18, 2009 1:36 pm
Jhonno wrote:
RoadHazard wrote: Spinning engine by hand. Should I be able to do it with all belts attached to ancillaries? Where exactly should I grab on in order to turn it? And should it move freely indefinitely or should it stop after a number of turns? Thanks.
No..
I didn't think so either but when I tried turning the engine yesterday, I couldn't keep going at one point and I went uh-oh. Turned out the belts were in very bad shape and stuck to the pulleys preventing the engine to turn pass one point. All okay now after they were removed. :D
rix313
Post Wed Nov 18, 2009 3:44 pm
When turning the engine by hand it should get quite hard and then release as you're obviously compressin the air then as you turn it the exhaust opens on that particular cylinder releasing pressure making it easy to turn again until the next cylinder is compressing and so on and so forth.
taper
Post Fri Nov 20, 2009 11:36 am
more troubles with my swap
this is that I found in the intake :cry:
and this in the cylinder head
take a look the colour of the oil
:evil:
Post Fri Nov 20, 2009 1:07 pm
I wouldn't worry.. The engine has been sat for a long time!!
Just run it for 100miles and put some fresh oil in!
taper
Post Wed Dec 02, 2009 10:01 pm
taper
Post Wed Dec 02, 2009 10:06 pm
I have a question about clutch.
What's the correct combination of clutch control?
A - M3 e30 input cylinder and output cylinder
B - M3 e30 input cylinder and M3 e36 output cylinder
C - M3 e36 input and output cylinder
Post Thu Dec 03, 2009 1:10 pm
B..
taper
Post Wed Feb 03, 2010 10:41 pm
many thanks :wink:
