The m20 2.8 has been dyno'd yet again!
goosiegander
Zonegoose
Post Fri Jul 17, 2009 12:49 pm
285/285 catcam dude :D
Ant
Retired Team Member
Retired Team Member
Post Fri Jul 17, 2009 12:57 pm
She's a tight one for sure Chris
Be interesting to see what happens after 15K miles.
Can everyone see why there were two runs done now ??
No-one goes from 1K to 7K @ wot from a standing start, so the part load map run shows more of what the delivery is like on the road.
Gunni
Post Fri Jul 17, 2009 2:11 pm
goosiegander wrote:285/285 catcam dude :D
Then you should have plenty in there actually. And peak max power for sure (cirka 6300-6500rpm)
Gunni
@ 2012 VEMS group buy !!
oakey
Post Fri Jul 17, 2009 5:25 pm
That's some of the best numbers I have seen for a homebuilt m20 stroker. Good stuff :cool:
stonesie
Post Fri Jul 17, 2009 5:39 pm
Looking very good there mate :cool: So, so close to cracking 200 on both torque and BHP.
When's the next check-up? 10K?
goosiegander
Zonegoose
Post Fri Jul 17, 2009 8:59 pm
next check up will hopefully happen next leave, will bed in the new chip, put some miles on it and arrange another run :)
ShakeyC
Post Sun Jul 19, 2009 6:01 pm
If you ever change your mind to go turbo or supercharger you would not have to change a thing internally considering your spec and it pull out some very astonishing numbers but in current n/a form it needs more miles to loosen it up and wouldnt be superised to see atleast another +10bhp and torque everywhere.
I would be proud of the those results :cool:
goosiegander
Zonegoose
Post Mon Jul 20, 2009 2:18 pm
Thanks dude, i'm hoping that the new chip and some spirited driving adds a bit and am leaning towards some form of management change.
I truth it feels fast as it is, plus the fact i still need to sort out the brakes its probably a good thing its not much faster lol! :D
goosiegander
Zonegoose
Post Sat Aug 15, 2009 6:05 pm
New chip is in and the arse-dyno says its a noticable improvement,
Many thanks to Ant!
Any speculation on the next dyno run? -perhaps a sweepstake could be started lol! :D
bilun777
Post Sat Aug 15, 2009 7:19 pm
206 bhp/ 196 torque. can't wait to find out. winkeye
If it aint broke don't fix it!
stonesie
Post Sat Aug 15, 2009 7:21 pm
208 bhp about 205 torque 8)
I would be happy to equal your first run with mine.
bilun777
Post Sat Aug 15, 2009 7:35 pm
Got abit carried away there 202bhp, 186 torque :roll:
stonesie
Post Sat Aug 15, 2009 8:11 pm
bilun777 wrote:Got abit carried away there 202bhp, 186 torque :roll:
On the RR graphs above its already pushing out a peak of 195.1 Lb:Ft :D
kimbo
Post Mon Aug 17, 2009 12:03 am
Is it me. or do the above figures not stack up right?
Assuming that the WHP figure is accurate (i.e.measured) and the FHP calculated from this, then either the FHP in run 1 is high, or that in run 2 low.
Or am I missing something?
I know its of no consequence, but I'm intrigued by the discrepancy.
Kim
goosiegander
Zonegoose
Post Wed Aug 26, 2009 12:13 pm
Second dyno run today, bit abortive, first run bhp194@5993rpm lbft185.5@4617
Turns out one of my spark plugs had worked its way loose and caused a misfire, but even with that impediment its doing well,
Development time! :twisted:
stonesie
Post Wed Aug 26, 2009 5:27 pm
What's up first in your development then?
I think it would have nudged 200 if you hadn't had that misfire... Im on 670 miles and counting, just found out a local TVR specialist has a RR and charges £50 for a power run with everything checked, I will be happy to get 195 since im running a less agressive cam and log manifold :)
**BANNED**
Post Wed Aug 26, 2009 5:55 pm
These engines run better and better the more miles they run,my 2.7 at around the 40,000 mile mark feels just nicely run in.. :D
To get more than 200bhp does start to get properly expensive,though,and can easily spoil the low speed running,makeing town driving a chore.
Youth is wasted on the young.
JazzMan
Post Wed Aug 26, 2009 10:57 pm
Very nice, I must get my 2.8 on a dyno at some point :D It's also running and Ant chip :) I had planned to megasquirt it but other stuff keeps getting in the way.
goosiegander
Zonegoose
Post Tue Dec 22, 2009 3:01 pm
More Results:
Definatly needs mapping but still not that bad...
toby
Post Tue Dec 22, 2009 6:41 pm
That's quite a nice large area under that graph! You must be pleased with your engine building!
