My S50 swap.. Progress and questions
d6dph
Care to enlighten us on who it was Dan?
eko
- Old timer
Ah what a bast4rd!Gutted for you mate.
I know someone who is very well knowledged on these engines/vanos and has loads in bits etc.
If you want his number im sure he wont mind chatting,maybe a source of secondhand bits?
PM me if you need it
Also,you could sell me your 36 for a bag `O sand
- Homo Hair
Tony PM on its way...
Dave, to be fair i dont think he ever had it running himself, he bought it from a specialist in the midlands area iirc. But for some odd reason the timing was out
He was obviously a bit 'special' to do that to an S50. Find out who it was mate.
Anyone who sells an engine that isnt timed up and doesnt tell the buyer needs naming/shaming IMO
maxfield
Sorry to hear this dude.
Good luck with it getting sorted!
eko
- Old timer
If this was/is the case and you werent informed then he needs namingDanThe wrote:
- Homo Hair
hmmm.. as i said, i dont think he would have known, i'd be looking toward who he bought it off.. tho that is 2 engines ive had off him, both um not at their best (Dan31is knows v intimately bout the other one i believe) plus he doesnt use the forum anymore so wouldnt be any point
Demlotcrew
Its not Jonb is it?
Karan
just had a read whats going on dude.... and just to let u know ive just fitted a new servo on my car which is smaller than the e30 one and is an unknown vw one. tthe brakes do require harder pushing which i dont think is very good.... i also saw a polo one there which was even smaller and had three bolts to jooin the bulkhead... i left this though as it looks like the bit that goes inside the car and joins the brake bar did not look like it could be removed from the shaft that goes in the servo....
i wouldnt go too small if i were u,,,, with my experience from my silvia setup and this car..... fit a big a servo as u possibly can!!!
I was going to say Chaos, but you have received the engine
bigpimpin
Gutted to hear this Jhonno, and I know exactly what it feels like.
Its a right kick in the bollox when the project is almost finished.
ricey46
Jhonno, Gutted for ya mate.... As soon as i saw "I think my timing's out" and you had been cranking it I thought oh bugger!!
Hope you get things sorted ok mate!!
Put it this way...more time to get things perfect!!
Paul.
325i sport Tech1
335i Chromie - Sold
2001 E46 M3-Sold
1999 E39 M5
325i sport Tech1
335i Chromie - Sold
2001 E46 M3-Sold
1999 E39 M5
ste
Quite a few of us now that have been sold shonky motors.
Well worth buyng a whole running car and selling the bits you don't need. Not only do you get to see/hear the engine running, you can also sell all the other bits and you'll probably end up with a free engine and maybe even a few extra quid in your pocket.
- Homo Hair
My thinking atm is i cant be assed with the head swap, so wondering about just buying another heard running lump, and sell mine off as spares.. Could work out about the same £Â£ and less hassle
Karan
yeh thats what id do....
- Homo Hair
found one.. so we'll see. i think with a new lump it would be driving in less than 2days..
How much do you guys think i could get for the 'broken' lump? ~90k, cams good, oil changed often looking at lack of staining, few ancillaries to go with it etc..
ste
I'd have thought you'd get more if you sell it in bits - i.e. strip the oil filter housing off and sell that, head off, remove the bent valves and sell the bare head, sell the block, crank etc seperately.
bigpimpin
I got decent money for the throttle bodies and cylinder head but it was complete.
Head went to Lithuania, Throttle bodies went to Malaysia and the Inlet Plenum went to Florida!
- Homo Hair
well head is nearly off.. Will hopefully have the camshaft removal tool tonight and it'll be off.. Having spoken to a few people tho i think the engine was fooked when i bought it.. Bit of a shitter. But hey.. If bottom end looks ok, might just swap the head, its not been 'that' bad to get pulled to bits this far..
Only thing is.. it seems too easy to jump teeth rotating it the wrong way. I know they are known for it, but would have thought they'd give bit moe resistance than it does..
anyone got a diagram of the chain setup so i can see what might be the issue..?
- Homo Hair
right kids, head is off aaaaaaaand.... all the inlet valves are v. banana shaped.. Ouch..
Some impact marks on the pistons but they should be cool
Good news it bottom end is mint, no wear on the bores, and still got the nice factory honing marks. So should be new head and away we go..
laptop doesnt want to talk to my phone atm.. so i'll put pics up later..
ian332isport
Dan,Jhonno wrote:right kids, head is off aaaaaaaand.... all the inlet valves are v. banana shaped.. Ouch..Some impact marks on the pistons but they should be cool
Good news it bottom end is mint, no wear on the bores, and still got the nice factory honing marks. So should be new head and away we go..![]()
Sorry to hear the top end is trashed, but glad to hear you finally know why it doesn't run.
Regarding the pistons, you need to make sure that any marks that are there don't have any sharp edges, or it will cause the engine to pink/detonate. These engines run with a very high CR, so it won't take much to set it off. I appreciate the knock sensors will pick it up and back the timing off, but you will loose power.
Cheers,
Ian.
- Homo Hair
here is the damage..
Doesnt show the full extent of the bent valves..
One of the marks on the piston.. Is it ok to run a fine sandpaper over any sharp marks if there are any?
- Homo Hair
the wetness is where i put oil down the bores as the bottom end will be sat for a couple of weeks now exposed..
maxfield
Ouch, that head looks a little sorry for itself.
I can't see a bit of sandpaper being a problem.
- Homo Hair
3.2 head sorted.. hopefully be here Wed
ricey46
Glad to hear your getting back on track Jhonno!!
Is the head cheaper than getting a set of valves??
Paul.
325i sport Tech1
335i Chromie - Sold
2001 E46 M3-Sold
1999 E39 M5
325i sport Tech1
335i Chromie - Sold
2001 E46 M3-Sold
1999 E39 M5
- Homo Hair
inlet valves are £40+vat each.. thats assuming exhaust valves are ok they are £75+vat each.. plus getting them cut in etc. Plus 3.2 head has bigger ports and inlet valves, also 1mm thinner inlet valve 'waist' be rude not too imo
is it worth getting this new head faced or anything?
Well would you rather find out now if its cracked/warped or afterJhonno wrote:inlet valves are £40+vat each.. thats assuming exhaust valves are ok they are £75+vat each.. plus getting them cut in etc. Plus 3.2 head has bigger ports and inlet valves, also 1mm thinner inlet valve 'waist' be rude not too imo
Pressure test/reface before fitting is a must mate, also have the oil seals changed if they have gone hard
- Homo Hair
um.... im gonna go with before i fit it
right.. now where to get it done in brighton or essex areas?
jaistanley
So you're fitting a 3.2 head to a 3.0? Does it fit on OK? What about the VANOS? Will you be able to fit the 3.0 single VANOS or will the 3.0 ECU you have run the 3.2 dual VANOS OK?
Fine wet and dry will be fine to use on the piston crowns. The smoother you make them, the better.
Also: do the 3.0 throttle bodies mate OK to the head or are you going to re-shape them slightly to match the ports?
All good on the progress, hope you didn't get stung on the head too much, bummer about the head damage you had.
Are you in Colchester at the moment? I'm down in Coggeshall fiddling with my project at the moment.. Would be good to pop over and see how its going dude.
Jai
Jai
- Homo Hair
yup 3.2 head, with 3.0 cam housing and cams and vanos.. will use 3.0 tb's and enlarge them to match the 3.2 ports. Will use 3.0 ecu etc
im not in colchester atm, but will be for a couple of weeks from 9th Sept if you're about then.
d6dph
Ooh, Mini meet at Dans house
Dan, Would Roberts on magdalen st in colchester not be any good for the skim/test?
I can always run it up there if you need me too.
- Homo Hair
Gonna steal my mates Touring n take the head up to QEP in Burgess Hill when it arrives..
ste
Pop in and say hello when you do.
- Homo Hair
Was gonna give you a bell as i dropped the head up today ste.. Only thing is i managed to leave my phone at my house
Well the 3.2 head arrived today.. I kinda just glanced at it, took it up there, and then had a closer look at it with the guy whilst discussing work to be done aaaand No. 6 has bent inlets!! FFCS!!!
This is starting to be not funny anymore.. Its gonna have valves lapped back in, clean, pressure test, skim (apparently its pretty straight, one good point i guess..), new oil seals.. Providing the rest of the head is ok..
On a side note my mates Touring is pretty fun.. Its a shed, needs a fair bit of work (mainly bushes tbh) but it does go well.. Supposedly a 2.7 conversion, and runs a truely council Scorpian system (but i like it
) One of them new celica thingies was shown the way..
