Was hopeing to keep the finish as it is, maybe even a polish if the machine is working, should be easy enough to do any finish, that crackle paint looks good too, I'll just wait to see how many scratches I have too polish out! Too many and I'm joining you.
Rotrex M42 Build - 285bhp little update
e30_Turbo
- Boost Junkie
Most of the companies I do work for are off till next week, so kinda twiddling thumbs today, will take some work in with me tomorrow
appletree
More progress today on the plenum, got a big hole saw and cut two 55mm holes in the base plate.
The little bit i left at the side of the holes is for a M8 bolt to thread in to the back of the plate of the plenum from the back.
Then joind them up with the slitting disc in the grinder.
the view with the plate cut out, the bolts on the inside will be bolted on first before the plenum bolts over the job lot and lock tighted in place, i might even use longer bolts and even up some nylocks on the bits that poke out.
Next clamped all the way round with mole grips ready to drill the holes and keep everything aligned
Holes drilled and a slight downward pointing bend welded on to the plenum, not that neat as when i weled the two joining halfs of the plenum togeather and must have slightly miss judged how big a half was as its ended up at just over 3".
All trimmed on the edge of the stainless and ally sheet, just need to make a gasket.
Bolted it on to the car which ment i could weld up a boost pipe for the IC to TB leg of the pipework just need to work out were i want to put the dump valve.
need to make up the plate that the TB will bolt to next, got a peice of 10mm stainless flat bar which i will be able to cut out and then grind/polish it to match it to the plenum and the TB as there very slightly different sizes probly 3" and 2 3/4" or maybe even less
Jon_Bmw
- Dangerous when thinking
Looks wicked as ever Matt.
Good job you don't have ABS.
appletree
not sure i'll be saying that when its up and running
hoshy
- E30 Zone Wiki Guru
Loving that dude!
papercutout
Looks fantastic, I'm still watching this project in anticipation of the finished product! Its going to be even better than before, and it was great then!
Turbo-Brown
- Boost Junkie
He heeee, that really does look fantastic!
Actually I though your last kit looked fookin' awesome too!
Oh dear, I fear I might have to go back and re-make some stuff just to keep up!
appletree
LOL
If you do i will
If you do i will
DieselMeister
Simply awesome
"Pass me the wheel before you hurt yourself, mate."
Phill172
Looking fantastic, can i use the same rad as you on the 2.5? Saves so much hassle having the expansion tank on the side!
that setup really is a work of art
i need to be able to tig
appletree
Think it would mount ok as it uses the same mounts but i dont know if it would hold the pressure or hold enough water??? Spose the issue is really the surface area available to disipate the heat.
appletree
turned this up this morning, ready to be welded on to the boost pipe to mount the dump valve.
As i bought the dump valve with the 38mm fitting kit i made a new stub out of 1 1/2" dairy pipe and machined a grove for the grub screws to lock in to
Filed the bottom to make it but up to the boost pipe
Hole sawd the middle out and then welded the pipe on.
Polished up with the dump valve ftted
Next machiuned out the stainless plate to weld to the manifold for the throttle to mount on to, as the throttle was just alittle bit smaller than the 3" bore of the manifold, hopefully it will make it flow well
Welded the plate on along with a small plate to work as a mount for the throttle cable to pull against just need to round off the plate and polish it up
Also welded this plate on to work as the pressure/vacume take off for all the various sensors.
Dump valve
FPR
IVC
MAP sensor
Temp sensor
Boost gauge
an some more i forgot....
Here it is all bolted up and polished, still think i'm going to crackle black it.
Dump valve
FPR
IVC
MAP sensor
Temp sensor
Boost gauge
shalmaneser
Woah! Awesome fabrication there!
Bet she'll go like the proverbial, nice smooth bends, you've clearly given a lot of thought to airflow, great to see such attention to detail!
Good luck - hope she goes as good as she looks!
vinni
Looking good, keep up the good work
cliffybabe
- Powered by Nelly
looks wicked dude
rix313
@Matt: re previous discussion, my radiator is a Nissen's rad
brilliant work,,,nice to see it all on the m42,,this will fly.
+ a yard full of scrap turds
rix313
Matt quick question.
When you put the new engine in that you bought, what did you do with the old one?
GrindCulture
Not in E30s any more
appletree
Thanks grindculture is it you with the same name on the m42 club? id guess it is
Dont under stand rix, this is the origonal engine that the car has always had. i bought a spare one to mock it up on last time and that is now getting built up for this one lower comp and forged.
What do you need? ive got 4 heads and 3 blocks ( 3 complete engines + the one in the car)
rix313
Oh right I thought you built it up on the new one then dropped it all in didn't realise you did that.
I'm after a good new engine.
GrindCulture
Yeah I'm on there every now and again getting my fix and pretending I know what I'm on aboutappletree wrote:Thanks grindculture is it you with the same name on the m42 club? id guess it is
e30_Turbo
- Boost Junkie
appletree
thats going to look the dogs bollox when its done, its quite long isnt it guess its going to get to just past your old dump valve take off judging by the pic in your sig.
And its got to flow better than the 90 bend in the current set up, cant wiat to see it finished
appletree
Bit more progress over the last two weeks or so firstly i finished off making the tesioner, ive used an E36 m43 idler pully which also donated its crank pully to make the charger pully so its should be rated at the same sort of rpm/power.
Trail fitted the inlet manifold today and worked out were the FPR will fit, fingers crossed it wont be need after its mapped and it will run fine on the 3bar reg but it gives me the option to play about if needed.
Made this plate to bolt up to old air box mounts so that i can mount the supercharger oil resivour of it, it right next to the charger so the pipe length to the supercharger oil pump is kept to a minimum which is good.
Made a plate to mount on the old throttle pot bolt holes with the large plug and now fitted the newer smaller throttle pot with the now normal plug on it.
Nothing realy major but i decided to paint the charger bracket silver just to stop it going rusty and looking crap. need to sort out the wiring for the oil temp and pressure sensors to now i can get there.
Somthing that i was never realy happy was the old oil resivour i fitted from the suzuki swift, it did a job but mountd off the strut brace it looked naff and the pipes were in the way.
Found my old origonal one cleaned it and refitted it and replaced the low fluid level switch, always nice to know youve got brakes
Mark, that inlet looks great in the other pics you sent, keep emailing you back but 3 days later i get a Email not sent warning! god knows why. Any more news on it by the way?
Would a 540 throttle be any good to you? its around 82mm, fits over a 3" pipe anyway with alittle to spare.
rix313
I was wondering when the next installment would be looks awsome. Got any of the whole engine bay with it how it is atm?
I've hit my brick wall atm rattled on how the S/C is going to go.
You should recieve the slab of ali tomorrow mate
appletree
Cheers, might get chance to do it tomorrow as ive got the afternoon off, or at least get some of it done.
i'll get a bay shot next time its altogeather although its in bits at the moment as i'm siliconing all up with my new gaskets.
just got the dip stick and the oil cooler to get in place then its near enough ready for a test run, engine only though as the lights and stuff need doing before it can go on the road.
appletree
Just done a little more, got my injectors back from being cleaned at Emerald and fitted them to the inlet manifold.
They were £30 and are from a rover 620i but they are also fitted to other rover trubos like the 220.
Cleaning From emerald with new lilters, tips and o-rings was £15 each
For any one intrested there 440cc at 3bar or 460 at 4bar fuel pressure.
Part numbers on the injectors are
MJY100460
D3184GB
0646
MJY100460
D3184GB
0646
rix313
460 cc blimeymight as well use a pipe lol
You cooling the engine oil?
appletree
Not yet.
A can of carlsberg a minute!
e30_Turbo
- Boost Junkie
Looking good!
Inlets stuck in progress, have been advised I must have a radius on the inlets in the manifold, so I've looked into flaring the runners, no go, so spoke to a machinest who quoted me 50 for 6 mild steel radius tops that will slide over the runners a give me what I need. My only other option is to start again with ali tube and a 20mm thick plate and have the runners radius edge milled in but I find ali is quite aweful to work with, I need more tools!
That TB sounds ideal, 540 you say?
appletree
ya, i'll get some pics for you.
appletree
Few bay shots for you Rich.
Little more progress, got the bracket for the resivour mounted on the plate i made, used some rubber mounts to holed the plate to the airbox mounts so that i can pick up on the other stud to make a flexible mount for the inlet pipe so it can rock with the engine.
Also got these hose tails fitted today, the inlet is now fitted all sealed up and ready to go!
TB pics for you, it mahooosive! think the palte bit could be machined down easy to make it more managable. its actualy two Tb's one normaly open and one normaly closed, is one the traction control? you dont need both for it to work, its a 540 one ya E39
what size trumpets do you need?
appletree
Mark i can get these from work, there very nearly a trumpet shape and would weld streight on to stainless pipe, they come in 1/2" sizes but you could just open them up abit if your runners are a different.
Might be worth a punt.
e30_Turbo
- Boost Junkie
I'd say that was pretty big too, that bend will be awkward to make work, the other looks nice and small, will need to see where the outlet sits in the engine bay before making a decision.
I need trumpets for the 50mm pipe you sent me, was told it wouldn't flare very well.
