Cheers guys
This one is a very nice car to drive, power is awesome and the noise is incredible on boost, we'd better not mention fuel consumption though, part throttle is no worse than a stock 325i, on boost- well its pretty juicy
but hey, cant have it all...
Spec wise its a TD crank 2.7 lowered comp( 7.4:1), welded and mildly ported head, CatCam turbo grind, log manifold, tial 44mm Ext W/gate and the HX40 is on a 19cm housing
Boost is set to 1 bar on the spring, it will run more boost once the engine has losened up a little more, its done 1.6K miles since the build and is still tight.
Management is MS V3.0 , Wasted spark and 42# injectors.@ 87% duty cycle.
As long as Gary is happy I'm happy
BTW, Fowlers car runs more boost
1.6Bar
