A few hours in the sun and we have.....*** WITH VID ***
e30_Turbo
Boost Junkie
Fri Jul 21, 2006 8:33 pm
The day started well as I managed to strip out the old exhaust and see what was what....turns out I have a 2.5 inch gap to fit a 3 inch pipe....so the usual really.
After some thoughts the down pipe we decided to beat into shape to get the best cleareance past the steering. It was tack welded and checked for fitment, all was well so this is what we came up with...
The lower half was lengthed due to no space for a clamp as it was too close to the steering and after some tea and a break from the sun we ended up with this tidy arrangement, clearing all body parts and sitting bang on into the exhaust channel.
And this is the 95% finished system, add the wb boss and wrap 50% before it goes on for good.
BIG thanks again to Ant for his help, it was another great day in the sun playing with cars!!
maxfield
Fri Jul 21, 2006 8:43 pm
Looks great :cool: :wink:
jaistanley
Fri Jul 21, 2006 9:04 pm
Awesome work.. Are you concerned by the lack of flexible coupling?
Are your engine mount pretty tough? If the engine flexes too much the pipe/welds could crack..
Just a thought..
Jai
Jon_Bmw
Dangerous when thinking
Fri Jul 21, 2006 9:18 pm
jaistanley wrote:Awesome work.. Are you concerned by the lack of flexible coupling?
Just a thought..
Jai
But there is no flexible coupling on a standard system, other than the flex in the rubber exhaust mounts so i wouldn't have thought it was a problem at all.
Looks real good to me mark, 3inch you lucky devil :wink:
Fri Jul 21, 2006 10:55 pm
In line engined cars don't need flexi coulplings - the whole system can rotate with the engine. It's only transverse mounted wrongness that needs flexis.
Silverfang
Sat Jul 22, 2006 12:40 am
Brianmoooore wrote:It's only transverse mounted wrongness that needs flexis.
:lol: So so so true
BMW and Opel, both RWD, both german, both good fun
http://www.clockservicing.co.uk/ For any clock repairs try here.
Toby_Unna
Boost Junkie
Sat Jul 22, 2006 9:35 am
it doesn't need a flexi coupling don't worry about that
looking fab mark :cool:
getting it installed today then? winkeye
e30_Turbo
Boost Junkie
Sat Jul 22, 2006 10:29 am
I'm just making the main gearbox hanger and then the far box hanger needs welding to the back box, then paste, clamps and I'll see how it sounds :D
Got me a 512mb ram card for the camera so I'll get a vid soon enough :D
Toby_Unna
Boost Junkie
Sat Jul 22, 2006 10:43 am
i've still not done a decent one mark :cry:
if the sliding joints look ok try it without paste, much easier to separate. mine is together without a drop and doesn't blow.
it's gonna sound great dude!
what boost you running? i picked up a little prezzie from Ant last week, so with a couple of jubilee clips, the bigger spring installed and some MS tweaks it's going to be 10psi for me shortly :twisted: :twisted: :twisted:
e30_Turbo
Boost Junkie
Sat Jul 22, 2006 10:51 am
Here's the g'box hanger, should be fine, may tidy it but then again poss not....
My WG is set @ 8.7psi but that's only till I wire up boost control and fit the solonoid then ....... we'll see how much a low comp well bolted down 2.5 can take!
I just wonder if you have hit the sweet spot on your turbo yet, mines not until OVER 1 bar.....
Have you done a flow check against a compressor map?
e30_Turbo
Boost Junkie
Sat Jul 22, 2006 10:57 am
Toby_Unna wrote:i picked up a little prezzie from Ant last week, so with a couple of jubilee clips, the bigger spring installed and some MS tweaks it's going to be 10psi for me shortly :twisted: :twisted: :twisted:
Ant and I chatted about that yesterday, which one have you got on at the mo? the std or a 2.5 one?
I also have the same one in my garage, still chrome too :D but it's never been fitted, secret toy for when I need more :twisted:
lentec
Boost Junkie
Sat Jul 22, 2006 8:35 pm
Good work guys :cool:
Andy335Touring
Sat Jul 22, 2006 8:46 pm
Looking good mate, did you get it finished today ?
CraigG
Sat Jul 22, 2006 9:05 pm
that turbo looks OLD skool, wtf is it?
CraigG
Sat Jul 22, 2006 9:07 pm
and ffs, that exhaust is just silly :D
fuzzy
He who sleeps with "Gingers"
Sat Jul 22, 2006 9:17 pm
nice one mate,i wish i had the know how and the facilitys to do more to mine myself,it seems to be the only way to gaurantee a jobs done right winkeye
maxfield
Sat Jul 22, 2006 9:18 pm
CraigG wrote:that turbo looks OLD skool, wtf is it?
It's a holset hc-1 its in his sig adn its from a train iirc
Jon_Bmw
Sun Jul 23, 2006 11:02 am
from a train iirc
Everytime I read that it makes to crack up. So big that it belongs on a train, fcuking quality
e30_Turbo
Boost Junkie
Mon Jul 24, 2006 8:52 am
Andy335Touring wrote:Looking good mate, did you get it finished today ?
Just need the 3 inch exhaust clamps now to fix the final position of it, plenty of play in the system and it needs it as it's pretty tight to the steering. Under the rear beam is gonna be fun too but I have hammer if it needs adjusting :D
I had to fab another hanger as I got the angles wrong on the first one, so hopefully I'll be able to fit it and test it tonight.
Then just the WB to install and wrap it all up.
I'll post some pics when it's on and a sound clip too :D
Mark.
Turbo-Brown
Boost Junkie
Mon Jul 24, 2006 1:36 pm
Bloody hell!
That's massive! :cool:
Any luck with the solenoid yet too? :)
e30_Turbo
Boost Junkie
Mon Jul 24, 2006 2:11 pm
Turbo-Brown wrote:Bloody hell!
Alex, I have made the bracket for the solonoid up and am ready to install it but I'm still awaiting my FET's and some other parts to make up the curcuit, while I'm there I'm adding water injection too as the systems are the same, just what they control is different.
Been out this morning to pick up some clamps and ordered some more exhaust wrap and VHT paint so it'll look nice a tidy when finished.
Am hopeing to fit and test it tonight so a vid will follow shortly after....
Although there is a little worry that it may be a little too loud for most :twisted:
oscar300
Location: scunthorpe/grimsby/hull way on...know what I mean?
Mon Jul 24, 2006 2:17 pm
fowler
Boost Junkie
Mon Jul 24, 2006 2:25 pm
looks the tits mark i will be joining the wrongness soon :D
EX A-Tech Workshop bitch !!!
gone but not forgotten
Toby_Unna
Boost Junkie
Tue Jul 25, 2006 12:44 am
i have that problem, had a couple of people moaning about the loudness of my car already. lucky for them it isn't my daily driver :D
water injection :cool: no messing about eh mark?
e30_Turbo
Boost Junkie
Tue Jul 25, 2006 8:58 am
Water injection will be only for when it's needed, be nice to have ready to use and an extra safety feature for when the weather is like we have at the mo.
Found last night the 3 inch clamps are too small, I need the 3 1/8 inch clamps so have to pick them up today, so just downpipes fitted still, I resisted the urge to fire it up there. Wrap and paint is on order so not long now.
Mark.
jaistanley
Tue Jul 25, 2006 1:38 pm
Sure you're not tempted to fire it up and see if it's all gas sealed before you do the wrapping and painting? Now I wouldn't doubt your welding skills but its easier to measure twice, cut once!.
Jai
Turbo-Brown
Boost Junkie
Tue Jul 25, 2006 2:01 pm
BAH!
Where's your sense of adventure?! :) (said Alex who's exhaust blows until it's warm)
e30_Turbo
Boost Junkie
Tue Jul 25, 2006 2:19 pm
It'll be run as is to check for leaks etc before it gets wrapped up and painted, I'm no welder but I am getting better each time :D
Atleast this one can be removed and welded off the car, the last one had to be welded on the car and it just wasn't possible to weld it all, ever. Also was a complete B I T C H to get off and I made myself feel better by belting the crap outta it during removal.
Picked up another four 83mm exhaust clamps today, WB is in with a local engineering company for them to wave their majic hammer over it, wrap and paint will be here tomorrow so all is looking good!
Just £88 to spend on windscreen and whatever MOT man wants in his pocket :D
d6dph
Tue Jul 25, 2006 7:44 pm
Sounds like my MOT man.... Wheres the car... oh there, have a ticket :lol:
Its getting there, cant wait to see the video of this beast. :cool:
jonbuoy
Tue Jul 25, 2006 11:02 pm
Look's fecking excellent mate, will you be at the Lakeside meet? Can't wait to hear it! :cool:
e30_Turbo
Boost Junkie
Wed Jul 26, 2006 8:44 am
jonbuoy wrote:Look's fecking excellent mate, will you be at the Lakeside meet? Can't wait to hear it! :cool:
I hope so, got the exhaust on last night, need to make a rear hanger as it sags a little under it's own weight.
Should have that sorted tonight along with painting it all and wrapping the downpipes.
Just waiting on my WB to come back from the engineering company before I can weld the boss in and fit that.
Then windscreen, MOT & Tax and I'm there :D
e30_Turbo
Boost Junkie
Wed Jul 26, 2006 7:27 pm
bmwe30mtech
Wed Jul 26, 2006 7:32 pm
Sounding good, is it not hesitating a bit though, im guessing it was just a cold start. Was that you at the end!?
e30_Turbo
Boost Junkie
Wed Jul 26, 2006 7:34 pm
bmwe30mtech wrote:Sounding good, is it not hesitating a bit though, im guessing it was just a cold start. Was that you at the end!?
First fire up in two or three weeks...
and yes, ugly aint I! lol
