hi guys,
i've had enough of the 320i auto! i cannot get the gearbox to engage with engine!!
i have now decided to do a swap and install a 325i block and manual box!
all i know i will need is a pedal box for the clutch pedal!
what else will i need? and is there any guides where i can get some guidance!
i do appologise if this has been asked before!!!
any advice much appreciated!
320i auto to 325i manual
You need:
Clutch pedal box
Clutch resevoir
Clutch pipe (across bulkhead)
Manual Propshaft
M20 Clutch and Flywheel
Slave cylinder and release bearing
M20 Manual Gear box with linkages
You will need to do a small wiring mod I believe, and possibly change the ECU but not 100% sure on that part
I have everything for sale apart from the gear box for £100 + post (I need a big box for the clutch pipe!)
Clutch pedal box
Clutch resevoir
Manual Propshaft
Duke137 wrote:You need:
Clutch pedal box
Clutch resevoir
Manual Propshaft
this ^^ and you will need to change the diff,
the wiring mod is simple
- hmuminovic
im looking at buying a 325 engine and gearbox together! with taht hopefully soon to be purchased, what of those bits will i need then, and how much will they cost me?
All but the gear box and linkages I guess
Already gave you the price above mateDuke137 wrote: I have everything for sale apart from the gear box for £100 + post (I need a big box for the clutch pipe!)
- hmuminovic
how much am i looking for then for those parts?
and how complictaed would this task be!
i don't have the greatest knowledge and experience with stuff like this, but i've learnt a substantial amount myself and this would be a learning step for me!!!
The engine and box? I don't know, depends on the engine in question I guess, I have seen engines go for £100 and £200 depends on the condition and history and whether they are sold with all their ancilliaries etc etc, gear box I would say anything between £30 - £75 with the same theory for history/mileage.
A worth while mod to convert from 320i Auto to 325i Manual by the way
- hmuminovic
yeah im sick and tired of the auto!!!
im on my 2nd box and it still isnt working!
so i've decided to spend my next pay wisely and put a 325 lump and convertt it to a real mans car (manual)!!!
i just hope the weather will be gud, as this weekend i've been soaked way tooo much for my liking!
- Brianmoooore
If you want reversing lights, you'll need the small loom to the switch as well.
There's a bracket to fit to the underside of the transmission tunnel to support the rear of the gear linkage, and don't forget to remove the small bracket from the centre console that the gear selector brush plate currently bolts to, as it will shred your gear lever gaiter if left in place.
The existing radiator will be OK - just disconnect the gearbox fluid pipes and drain the oil. The ports can be left open.
