how to check a starter motors external wiring for volt drop
aaronsmart
Sun Sep 26, 2010 3:04 pm
a breif explination would help from any mechanics out there?!
Mon Sep 27, 2010 10:09 pm
Connect a volt meter across the two ends of the cable you want to check.
Mon Sep 27, 2010 10:17 pm
Most starter motors have a separate solenoid (effectively a large relay), with a thick permanent live feed (+12V) from the battery, a smaller terminal coming from the ignition switch (switched +12V when you turn the key) and another large terminal going from the solenoid into the starter motor.
So, when you turn the key, the starter solenoid closes the terminals which switches the main feed to the starter motor.
GeoffBob
Forced Induction Specialist
Tue Sep 28, 2010 8:15 am
Given the magnitude of the current your starter draws, a 0.5V to 1.0V drop along your positive supply (the big fat red wire from the battery to the starter) would be considered quite normal.
Furthermore, check the earth strap that connects your engine to "chassis" and ultimately back to the negative terminal of the battery. If your earth strap is loose/faulty your starter-motor will not be able to draw the required current to crank your motor properly.
Lastly, measure your battery voltage while cranking the starter. Shouldn't drop below 9V on a reasonably healthy/charged battery (dependent upon current draw) during cranking. If it does, it likely indicates a flat or dead battery.
Tue Sep 28, 2010 8:39 am
OP hasn't actually claimed to have a problem!
GeoffBob
Tue Sep 28, 2010 9:19 am
All useful information that the OP can do with as he wishes Brian. And quite frankly, when it comes to my posts, MYOB.
Tue Sep 28, 2010 1:44 pm
As a team member on here, ALL posts are my business!
So far I'm the only one that has answered the OP's question.
GeoffBob
Tue Sep 28, 2010 3:41 pm
Brianmoooore wrote:As a team member on here, ALL posts are my business!
Good for you Brian.
Why the fact that I offered a little pre-emptive information should get up your nose I do not know. I was only trying to be helpful.
