ventured out for a short test drive, set the AFR to 12:1 so its rich as hell but safe as houses, only tickled the loud pedal , no higher than 3K rpms.
verdict ?
well, grunt like a 750i
found the boost comes in @ 1.8K with load, I got some very strange looks from a group O lads @ a bus stop, dunno what they actually said but it sure looked like " dump valve , WTF !!!!?? ** , those aint turbo"
next step is test drive with co pilot so I can tune the VE tables, then I'm upping the boost to 7 psi
Gas bench agrees with the on board 02 so @ least I know I'm sound there.
Mark....... you're next buddy
