E30 Adjustable Top Mounts!
SHAZ325iSPORT
Tue Aug 11, 2009 12:10 pm
guys where can i get these from?
jmc330i
Tue Aug 11, 2009 12:14 pm
Eibach do them for about £250 IIRC, and Kmac I think.
Are you gunna try and sort the camber on your car so you can keep the 328i struts?
James
'91 325i Sport
'93 318i touring 16v
SHAZ325iSPORT
Tue Aug 11, 2009 12:22 pm
nah im going for E36 M3 Evo Hubs,M3 struts
jmc330i
Tue Aug 11, 2009 1:09 pm
Cool. Just thought you might be looking at it as an option.
Im going to speak to Dave at Fritz about the possibilities - Ive seen some cars in Germany with the non-M struts, so there must be some way around it. It just depends which is cheaper/more practical.
James
'91 325i Sport
UweM3
Tue Aug 11, 2009 4:05 pm
working on these at the moment. One prototype is already running for a while and similar design is in my car for 2 years+ with plenty of track day miles and Nuerburgring miles
note how far strut centre is on negative camber
-- price will be less than any other comparable mount.
-- MORE negative camber than any other comparable mount (with coil over springs only)
-- correct HEIGHT as a 1:1 replacment for the BMW rubber mount
-- can be set back to stock camber WITHOUT laser alignment
-- No rubber for direct steering feel
-- and NO they are not going to clonk after a while like onter solid mounts
sorry can't post more pictures, want to keep a lid on it till I can supply. I have spend a fair amout of time to get that far and don't want to see a "groupbuy" somewhere else....
Tue Aug 11, 2009 6:27 pm
How far can a standard strut be moved over?
UweM3
Tue Aug 11, 2009 7:29 pm
DanThe wrote:How far can a standard strut be moved over?
not even to 3 degrees total camber before the spring hits the turret inside. I make some adjustable rubber mounts as well and they measured 2.6 deg on my car but others have reported 3 deg with these.
From my calculations/guess work I think that I can achieve 4 deg with the solid mount on coilovers.
that's a picture of my adjustable rubber mount with stock suspension. Note where the strut centre is. Maybe a little bit more is possible but the spring may rub on full lock etc.
Basically they offer the same (or a little bit more) negative camber as the BMW "crash" mounts but they are adjustable and can be set back to stock after a track day without alignment gear.
Saves a lot of tyre in the long run and you can have negative camber on track. Takes 5 mins to adjust (while changing your tyres to track rubber)
quite an easy solution and very cost effective. (cheaper than BMW crash mounts). If there is enough demand I might do another run. Was focussing on the solid mount lately and didn't spend much time on "old" designs winkeye
what are your "camber adjustment plates" in your sig? Front or rear?
pilt
Tue Aug 11, 2009 8:14 pm
Hi,
I had a question about your top mounts. I have just had my car lazer aligned and the front camber is -2.08 and -1.96 respectiverly and was wondering if your top mounts will allow me to go back to stock. Is it bad for me to run this much camber on the road?
Dan
UweM3
Tue Aug 11, 2009 8:25 pm
pilt wrote:Hi,
Dan
ALL the mounts I am offering are to ADD more camber. I have been asked for a version to reduce camber, but there was not a lot of demand, so I never made one.
Top of my head I would say it's not too much trouble for me to modify a mount to have positive camber adjustment. But without measuring it properly up I won't commit.
You can buy the BMW "crash mounts" to adjust camber in positive. But they will only get 0.5 deg or a little bit more off. How much is your car lowered?
pilt
Tue Aug 11, 2009 8:38 pm
Its lowered 35mm all round. But i am not sure if it may have some accident damage as well since my sparco strut brace will not fit! I got the chassis measurements off 300.de and the lower rails are the correct distance apart, its just the centre of the top mounts are 10mm closer then the spec. However setback was only 1mm so im not sure if its just bad manufacture....
But if i could use your negative only version i could set them both to -2.1 but is this too much for the road? Or will i be shredding tyres!
UweM3
Tue Aug 11, 2009 8:59 pm
pilt wrote:Its lowered 35mm all round. But i am not sure if it may have some accident damage as well since my sparco strut brace will not fit! I got the chassis measurements off 300.de and the lower rails are the correct distance apart, its just the centre of the top mounts are 10mm closer then the spec. However setback was only 1mm so im not sure if its just bad manufacture....
To be honest, I wouldn't bother with 0.1 deg difference!
mattrs
Tue Aug 11, 2009 9:14 pm
UweM3 wrote:working on these at the moment. One prototype is already running for a while and similar design is in my car for 2 years+ with plenty of track day miles and Nuerburgring miles
I need some of these! Any idea how long? and how much?
UweM3
Tue Aug 11, 2009 9:27 pm
Are you running coil overs or stock type springs?
Will take at least another 4 weeks I am afraid.
appletree
Tue Aug 11, 2009 10:12 pm
Uwe are these for coil overs just for the spring clearence or are they coil over specific for a different reason?
What i realy mean is could you run them on standard springs if you checked for clearence on the springs with less degrees of camber? say untill i/some one upgraded to coil overs?
Just thinking it could be a bigger market for you.... :D
mattrs
Tue Aug 11, 2009 10:58 pm
Standardish, ebiachs, but there are the same size (width wise that is). I am looking to upgrade to coilovers soon anyway.
Let me know when there good to go.
Also, how much, any idea yet?
UweM3
Tue Aug 11, 2009 11:10 pm
appletree wrote:Uwe are these for coil overs just for the spring clearence or are they coil over specific for a different reason?
They are an direct 1:1 replacement for the OEM rubber mount.
regardless of suspension used. The OEM type spring will only limit the amount of negative camber you can adjust as the spring hits the sheet metal. So it's a universal mount and can be used for all type of suspension.
SHAZ325iSPORT
Tue Aug 11, 2009 11:13 pm
uwe im dedfinately intrested mate,please get back to me as soon as your ready.
UweM3
Thu Aug 13, 2009 4:44 pm
SHAZ325iSPORT wrote:uwe im dedfinately intrested mate,please get back to me as soon as your ready.
working on it dude. Just found out that there is an option to have them BLACK instead of silver zinc. But more £££. Have to work out a final price and see if it's worth.
What would you prefer? Silver zinc (as pictured), gold zinc or black zinc (looks like sprayed satin black)
Dan318-is
Thu Aug 13, 2009 4:55 pm
Uwe they look fantastic, look forward to seeing the finished product :)
UweM3
Thu Aug 13, 2009 6:15 pm
Dan318-is wrote:Uwe they look fantastic, look forward to seeing the finished product :)
thanks dude, you didn't pick a colour :-)
Cook318IS
Thu Aug 13, 2009 6:20 pm
This looks like one hell of a quality product. I'd probably be interested too pending price.
UweM3
Thu Aug 13, 2009 6:25 pm
Cook318IS wrote:This looks like one hell of a quality product. I'd probably be interested too pending price.
thank you for your comment.
I am working hard to stay below the £200 +shipping mark for the set. Don't know how much below yet. Depends on colour as well. The black is 3 times as much as the silver/gold but I just like the look of it :-)
Cook318IS
Thu Aug 13, 2009 6:35 pm
That sounds like a very fair price imo. I presume that we would be able to choose our own colours? I wouldnt be able to afford the black ones (the joys of being an apprentice :roll)
UweM3
Thu Aug 13, 2009 6:55 pm
unfortunately no choice in colour once they are done. They will be all in one colour. I prefer silver over gold.
mattrs
Thu Aug 13, 2009 7:02 pm
I prefer silver too, but not really fussy.
Cook318IS
Thu Aug 13, 2009 7:39 pm
Then silver or gold it is then :D silver gets my overall vote too.
Dan318-is
Thu Aug 13, 2009 10:48 pm
Silver Uwe :cool:
jmc330i
Fri Aug 14, 2009 12:17 am
Great work once again Uwe :thumb:
UweM3 wrote: I am working hard to stay below the £200 +shipping mark for the set. Don't know how much below yet.
Is that for the solid mounts?
Looks like something I may need in the not so distant future winkeye
James
'91 325i Sport
jaistanley
Fri Aug 14, 2009 12:44 am
I've seen and been in the prototype car and they're very good. I was expecting a harsh ride, but they're fantastic. I have Uwe's other design of camber adjuster plates that use the BMW rubber top mounts installed on my car and I was very impressed when installing them. I have no doubt they'll be perfect in service..
Jai.
UweM3
Fri Aug 14, 2009 7:51 am
jaistanley wrote:I've seen and been in the prototype car and they're very good. I was expecting a harsh ride, but they're fantastic. I have Uwe's other design of camber adjuster plates that use the BMW rubber top mounts installed on my car and I was very impressed when installing them. I have no doubt they'll be perfect in service..
Jai.
thanks for your kind words Jai. Both mount types are a result of my own needs. First the quick adjustable rubber version I wanted when my car was more road than track (to avoid tyre wear in daily driving) and now the solid mount for max negative camber and precise steering feel.
I have a solid mount on my car running for 2 years+ now and it tourned out that it is very "streetable" with no side effects.
I doubt people would spot the difference when driving a car with the solid version in a blind folded test (in terms of harshness).
All the parts I offer are tested both street and track , I am not like many other sellers who design something and then make and sell 20 straight away to recover costs. NONE of the parts I ever made/sold were returned to me.
I design my stuff pure for functionality and low price, so no fancy engravings or logos or bright annodised colours, sorry
UweM3
Fri Aug 14, 2009 7:52 am
jmc330i wrote:Great work once again Uwe :thumb:
yes it's a SOLID mount. No rubber invovled winkeye
SHAZ325iSPORT
Fri Aug 14, 2009 2:46 pm
silver
jmc330i
Fri Aug 14, 2009 6:36 pm
UweM3 wrote: yes it's a SOLID mount. No rubber invovled winkeye
Well there goes my rubber fetish 8O :o:
Keep us updated how you get on, I will be interested in the solid mounts :thumb:
James
'91 325i Sport
benjy
Mon Oct 05, 2009 11:21 pm
I'm very interested in these for when I go 5 stud ;)
Any news on timeline/pricing yet??
Cheers, Ben
Gaffa tape is like "the force" - it has a light side, a dark side, and it holds the universe together.
There's nothing that shouts "Poor Workmanship" more than wrinkles in the Gaffer tap
Mon Oct 05, 2009 11:31 pm
Come on Uwe, could do with a pair of these soon! :D
