Before sticking the engine in it's getting a light refurbishment. New belts, water pump, tensioner as well as rocker cover, inlet and sump gaskets.
I've got a few questions so far:
1. In between the water pump and the tensioner I'm told there should be a spring/pin assembly keeping the tension steady - but this is missing on the engine, and wasn't included with the new tensioner. Is it something that was only on facelift cars maybe?
2. The loom. I'd been under the impression that all of the loom right up to the ECU wasn't essential, just from the c101 plug onwards. Seeing as I was taking the engine out in a hurry I chopped the loom at the phantom bettery terminal where it enters the bulkhead to go through to the ECU (I kept the bit from inside the car too though). In retrospect, this seems to have been a bit stupid. Will I have to reconnect all of those wires together again? I looks that way at the moment.... am I missing something?
3. The radiator - it's prefacelift, from a car with AC. Is this going to fit okay in the space where the M40 one is at the moment or will I need diffferent radiator mounts?
4. The slave cylider - the thin metal pipe going into it got damaged and had to be clipped while the engine was coming out - can I replace the whole thing with the slave cylinder from the M40's gearbox?
5. Anything else you think I might be missing? I'll remember to check the additional wire problem from Brrianmoooore's sticky before firing it up.
Thanks in advance
