These are the pics on ebay which shows the door being the wrong colour to the rest of the car
I had always assumed that the door had been replaced and sprayed this way by a blind/cheap bodyshop as a temp fix. However, when I was cleaning the inside I noticed that the inside of the door was the correct colour to the rest of the car and the paintwork on the inside was in fairly good nick.
After some pondering I grabbed the bottle of t-cut and thought I'd give it a going over to see what happened.
After a few coats on the lower half of the door I had started to make some progress
That was after about 20 coats of t-cut on and off, so I began to get tired and thought more drastic measures were needed for the top half of the door, enter 120grit sandpaper, you can see the top half of the door where has been sanded and where hasnt
After a few more coats of t-cut it began to cloud over and I was tired and needed a can, so I gave it a couple of coats of wax to seal it and left it half way, but I'm quite pleased with how the progress is coming from where it was to hoiw its standing now
The bottom half of the door
and the full door,
still a way to go with the top but least i dont have to replace the door which I thoguht I did
