[img]http://
what size wheels and profile tyres do you have?DemonDaz wrote:Very NIce! Mine is currently 40/35 drop and I grounded it badly today just turning into the golf club. Dropped anymore and it is unmanagable!
Do cab's sit lower than coupe's then???DemonDaz wrote:16" wheels 205/50's causes problems on all speedbumps.
Cheers aceraf,aceraf wrote: Do cab's sit lower than coupe's then???
coz my car is miles of the ground at the moment....
I can't see how 60mm can fill this gapfunkdocta wrote:Cheers aceraf,aceraf wrote: Do cab's sit lower than coupe's then???
I think the cabriolets come with Mtec suspension which is 150mm lower than norm, but the cabriolets weigh more so the springs need to be a bit tougher to make up for this - hense the front of my now lowered cab sitting slightly lower than a 60mm drop on a cab should be.
I believe if you lower a cabriolet with 60mm cabriolet springs, and lower a coupe with 60mm coupe springs they'd be the same ride hight.
hope so....fingers crossed, should be coming soonfunkdocta wrote:Yeah it would mate, mine was already 1.5cm lower in the first pics coz of the Mtec spring hight, so really it's dropped about 5cm front (coz they're coupe springs on the front) and 2.5cm on the rear.
Yours wouldn't be quite as low at the front but not far off - only about 1cm difference I recon. You'd be suprised!
