Post
Wed Feb 28, 2007 11:55 pm
If it was a proper lowrider wires would be acceptable. But why bother with an e30, the chassis wont stand up to hopping, not even a small 3 wheel or side to side without twisting. Front to back and all up/down is f*cking lame, if you just want a low car that can get over speedbumps use airbags like the rest of the max power massssseeev.
And if you dont plan on fitting hydraulics, dont put wires on. If you do plan on building a lowrider, dont use cheap chrome plate wheels like those, within 3 months the chrome will be peeling off and they wont shine properly. If you want the wire wheel look on a 'modern' car (yes an e30 is modern in the lowrider stakes) use 144 spoke front laced daytons. if you cant afford daytons, you cant afford a lowrider.
duke wrote:
I could throw a spastic round a corner with better precision
