Power Roof
quimshaver
Post Sun Dec 10, 2006 5:55 pm
People,
I've got a e30 BMWwith a manual roof, I'd like a power roof, but not sure if:
A, it's a good idea
B, where to get it from and installed.
Any suggestions?
Regards
chinchilla
Post Sun Dec 10, 2006 6:05 pm
i would loke to know about this aswell!
this should be in technical i think..
blingsta
Boost Junkie
Post Sun Dec 10, 2006 6:11 pm
i personally wouldnt, unreliability reasons
shafman
Post Sun Dec 10, 2006 8:26 pm
stick with what you have.
DaveD
E30Zone Wiki Specialist
Post Sun Dec 10, 2006 8:39 pm
power roofs are delicate things and i suppose that it is possible to do...Jason in Walsall is your man to do it but it would cost a bomb ...you would even need a new cloth top to do it properly and most people want to do it the other way!
either go out and buy one with a power roof ...that works.. or live with it would be my recommendation
Nelly
Gumbo
Gumbo
Post Sun Dec 10, 2006 11:00 pm
Ooo - just think of all the micro switches you'd have to fit into the new loom - ouch, my head is hurting now lol - keep it manual 8) less worry.
Neil.
"I F**KING LOVE YOU GUMBO"
chinchilla
Post Sun Dec 10, 2006 11:41 pm
hairy muff..
randomdave325
Random E30 Nutta
Post Mon Dec 11, 2006 12:01 am
easy m8. in my experience power roofs are really reliable (if maintained!). if they fail u can wind them with the cranked allen key in the toolkit. whereas when the handle snaps on a manual roof!! grr. :x
the mechanism is exactly the same. the only parts u need is the pipework that goes under the black panel/ headlining. best place to get it with the motor, switch, wiringloom, and the blackpanel is a breakers.
slide roof back, remove spoiler. close roof then tilt it, slide headlining trim back (unclip from front),
remove the roof panel (6 torx), undo 2 screws under to remove black panel, slide roof back, remove motor, take off the screws down the side trim, slide the side brackets out of the runners and remove with cables,, undo the 7 7 mm nuts holding the tubes/motor bracket (2 screws from top) once you've got it all, remove yours the same way, replace with the new parts.
the wiring is all contained in the roof and is one loom. if u get it all complete. u only have to run 1 wire down to the distribution block behind the glovebox where it plugs in. green/something from memory. the only thing to do when all fitted is set the motor when removed from the mechanism. run it with the switch and you'll work out what position is what. i usually set them tilted. and just keep an eye on it the first time u use it!
i've done a few of these now so am making it sound easy. but it should all make sense when you get the donor one in bits :thumb:
this should be in technical really winkeye
The current fleet!
1990 318iS
1984 528ise
1987 325i sport
1990 325i cabrio
1987 m3 s50b30
'Turning money into noise' :)
