i'd been wanting to do it for ages but seeing as im banned at the moment there seems no time like the present.
bought the metal primer and couple cans of satin black paint.
already had the sand paper and block and some wire wool
started of without degreaser as i dint have the money at the time and was bored so got some elbow grease on it with some wire wool.
it was unbelievably greasy underneath i dont think its ever been taken off and the top had oil over it anyway.
pics below
before underneath you can see where iwiped some of the grease and it was shiny underneath
then after cleaning that bit up and starting in the grooves
you can see where the black bits are on the other half how dirty it was and what a difference it makes
here is the top before. it was filthy but camera decided to play up so i sanded it a bit and got the oil and shit off then it worked again.
i used degraser to get everything off and used it on the underside on the other half to get every bit of grease out.
haf way thru degreasing
then primered and sprayed black
got a few blemished underneath and its not perfect but its only for now and looks 100 times better than it did.
and then with the bmw section sanded
and a couple finally fitted on the car
opinions welcome.
now i just gotta get the inlet manifold off and do the same had a quick look but looks a bit of a bastard to get off as the nuts are in stupid places.
cheers eun
