Front wheel studs breaking
Tinaissshhh
Post Fri Nov 17, 2017 11:31 am
Guys what causes studs to break on a 320i 1988 model
Please assist a˜”
Post Fri Nov 17, 2017 1:12 pm
First point: No E30 I've ever seen has left the factory with wheel studs. Do you mean bolts?
Post Sun Nov 19, 2017 10:12 pm
Many things with a car from Zimbabwe. Is it running original wheels?
Tinaissshhh
Post Tue Nov 21, 2017 6:40 pm
I mean bolts thanx for the correction, I'm using 12 x 1.5 bolts
Post Tue Nov 21, 2017 6:52 pm
Never known a BMW wheel bolt to break, unlike original Mini studs, of which I have broken many.
Does this just happen with one wheel?
Check that the hole hasn't been worn as a result of the bolts working loose at some point. If the bolt head only seats on one side, it'll put a twisting force on the bolt at the base of the head.
