My 1st BMW 325I Sport M-Tech 1!! In For Its Overhaul...
MPOWERCRAZY
Post Wed Dec 07, 2016 10:57 am
Hi All,
Well As Some Of You May Now Ive Sold My 325i Cab & Now My Touring. I Wasn't Planning On Buying Another BUT A 325i Sport Came Along & I Had To Have It :D :D
Its From BMW-MAD, Good Mates Of Mine. They've Recently Done A lot Of Engine Work To It Such As :
1) Engine Service
2) Timing Belt, Water Pump & Coolant
3) Fan Belts
4) Diff & Gearbox Oil
5) Sump Gasket
6) Cam Seal
7) Diff Gasket
8) New Accelerator Cable
My Plans Are.....
1) Full Detail ( 2BM Wash, Clay Bar, 3 Stage Polish, Protect & Wax)
2) Interior Deep Clean ( Will Remove All Seats & Door Cards)
3) Refresh Shadow Line
4) Refresh Grills
5) Refurbish Wheels
6) Replace Centre Badges
7) Replace Bonnet & Boot Badge
8) Fit HLWW
9) Source A 13 OBC
10) Clean All Wheel Wells, Paint Brake Callipers & Struts
11) Source A New Exhaust
12) Source An Un-Cracked Dash
13) Maybe Swop Suspension For A Brand New One...
14) Get Front Struts Powder Coated In The Near Future
15) Rear End Subframe & Arb's Powder Coated In The Near Future
16) Front Suspension Overhaul - Lower Arms, Lolipops & Drop Links
17) Refurb Gearknob
18) Source Genuine BMW Mats
Maybe More Down The Line....
Some Pictures Of How She Is....
UPDATE 14/12/16
Collected The Sport Over The Weekend, Well Chuffed With It. Got It Back Home & Gave It A Much Needed Clean, Inside Came Out A Treat, Will Remove The Front Seats At A Later Date To Clean The Carpet, I Didn't Have Enough Time To Wash It Myself So I Had To Get It Done, I Was Stunned By The Results Of Just A WASH! I Haven't Even Polished It, Its Had A Good Respray In Its Past..... Here Are Some Pictures Below From The Weekend....
The Day I Collected It With My Good Mate....
Before I Cleaned The Inside....
After I Cleaned The Inside....
Outside....
I Then Removed The Mud Flaps The Next Day!!
I Then Got Around To Refreshing The Grills/Handles & HLWW....
Before
After....
Chrome Grill Before.....
Chrome Grill After....
I Have Now Replaced All The Front Suspension Including - Lower Arms, Lolipops, Inner & Outer Track Rods & Drop Links....
Day I Collected It Back From BMW-MAD
Ive Purchased A Powdercoated Rear End In Gloss Black, Small Tech 1 Steering Wheel, Brand New Eibach Springs, Brand New Rear Backing Plates, New Rear ARB & Subframe Bushes, Brembo Pads & Discs...Some Pictures Of The Parts.....
Outing Over The Weekend.....
Finally Had Time To Update It!!!
Update 8/2/17
More Parts Arriving, Just Need To Purchase Some Brembo Discs, Front Bearings & Top Mounts
Rear Headrests...
New Rear Bearings...
New Rear Trailing Arm Bushes...
New Rear Brake Shoes...
New Fuel Pump...
New Shock Covers For The Front...
Brembo Pads...
New Rear Top Mounts...
Small Tech 1 Wheel...
New Crack Free Dash...
Thats All The Parts For Now Till I Have Saved Up More :(
In The Mean Time Here Are Some Pics From The Recent Weekend With My New E30 Cab....
Thats All For Now....
Update 18/3/17
Car Developed A Problem Recently Where It Didn't Have Any Spark! So Was Dropped To BMW-MAD, Fault Was The Wiring Loom So Upgraded To The Motronic 1.3 ECU System, Also Fuel Pump Was Replaced And Wiring Sorted, Alternator Bushes Were Also Knackered So These Were Replaced Too, Also The Guys Fitted The Power Steering Pulleys...Some Pics Below....
Old Wiring Loom Set Up
New Wiring Loom Set Up
Some Powering Steering Elements Fitted
Collected Car, Washed & Polished As You Do...Went & Seen The Guys...
Update 28/5/17
So After A Few Months I Have Finally Collected All The New Bits For My Suspension Overhaul. The Parts List Consists Of...
1) New Backing Plates
2) Brembo Discs & Pads
3) New Bushes
4) Braided Hoses
5) New Shackles
6) New Front Calipers
7) Various New Bolts/Nuts
8) New Steering Gaitors
9) Powder Coated Struts & Rear End
10) New Meyle Bearings
11) New Heater Blower
12) Virtually New Pirelli P6000 205/55/15
13) Hartge Wheels With New Caps
14) Scorpion Le Mans
15) New Spring Pads
& A lot More Lol!! Some Pictures Below...
Its Recent Wash & Polish
Parts....
Steering Gaitor & Wear Sensors
New Bearings, New Cups & Protective Cover
New Top Mounts With New Bolts
E90 Drop Hats
New Backing Plates
New Calipers
Various Bits From Dealers
New Spring Pads
Shackle Rebuild
New Power Steering Reservoir Bracket
Powder Coated Parts
Struts Before
Struts After
Inlets & Rocker Before
Inlets & Rocker After
New Brakes & Hoses
New Fanbelts For Its Power Steering Conversion
New Bushes
Hartge Wheels
Scorpion
Working HLWW
New Heater Blower Motor
Pirelli P6000 Tyres
Dropped Off Ready For Its Overhaul...
Update 4/6/17
Update From The Garage, Wheels Removed & Dropped For Refurb, Old Front End Stripped Out, New Front Subframe Fitted With Power Steering Rack, Front ARB Painted, New Rear Trailing Arm Brake Lines Arrived, New Scorpion Hangers, New Old Stock Gearbox Exhaust Brackets, New Bolt For Driveshafts, Diff, Steering Rack, New Washers For Subframe, Re-Painted Front Drop Link Mounts, New Rear Subframe Plates.
Car On The Ramp.....
Old Looking Parts..
New Parts...
Front ARB Before & After
Front New Cradle Mounted Up....
Back Again From The Darkside Of Doing E36'S :mad:
Back With 2 E30 Projects :cool:
steve_k
Post Wed Dec 07, 2016 12:10 pm
looks good, looking forward to the updates.
bab-91
Post Wed Dec 07, 2016 1:26 pm
I'd replace the front seats. Leather bolsters & houndstooth fabric is hard on the eye :(
Best of luck with the turd! :D
IG - bab91
Post Wed Dec 07, 2016 1:36 pm
i have a very nice rear seat with factory headrests and armrest for sale .
MPOWERCRAZY
Post Wed Dec 07, 2016 1:45 pm
steve_k wrote:looks good, looking forward to the updates.
Thanks Mate...
MPOWERCRAZY
Post Wed Dec 07, 2016 1:46 pm
bab-91 wrote:I'd replace the front seats. Leather bolsters & houndstooth fabric is hard on the eye :(
Lol, Thanks. I Do Quite Like It! But If I Come Across A Mint Black Leather Interior Ill Snap It Up :D
MPOWERCRAZY
magpie wrote:i have a very nice rear seat with factory headrests and armrest for sale .
How Much?
Post Wed Dec 07, 2016 4:36 pm
http://www.ebay.co.uk/itm/172432713483? ... 1555.l2649
upper and lower bench complete £200 + courier or £150 + courier for the top half with headrests and arm rest fitted .
Captain_Birdseye
Post Wed Dec 07, 2016 4:59 pm
Nice
Gert_8
Post Wed Dec 07, 2016 5:11 pm
I loved your touring. I'm sure this will be equally as nice when you're done with it! :D
bmw-mad
Post Wed Dec 07, 2016 9:23 pm
Nice car Famzz winkeye
MPOWERCRAZY
Post Thu Dec 08, 2016 1:11 am
Captain_Birdseye wrote:Nice
Thanks Mate
MPOWERCRAZY
Post Thu Dec 08, 2016 1:12 am
Gert_8 wrote:I loved your touring. I'm sure this will be equally as nice when you're done with it! :D
Cheers Mate! :D
MPOWERCRAZY
bmw-mad wrote:Nice car Famzz winkeye
Nice One Lads
MrGCC
Post Thu Dec 08, 2016 10:55 pm
Car looks really good! I would say keep it as it is, doesn't really need much at all.
MPOWERCRAZY
Post Thu Dec 08, 2016 11:24 pm
MrGCC wrote:Car looks really good! I would say keep it as it is, doesn't really need much at all.
Thanks Mate, It Doesnt Need Much Just A Few Minor Cosmetic Touches
MPOWERCRAZY
Post Wed Dec 14, 2016 9:56 am
UPDATED :D
Post Sun Jan 29, 2017 9:12 pm
Pic's not working ?
Gert_8
Post Mon Jan 30, 2017 11:41 am
Yes, it's a shame your pics are not showing... :(
Cypriotgeeza
Post Mon Jan 30, 2017 12:02 pm
Pics not showing bro but I know you neglect this site now! :roll:
Love the car!
Check my M30 build threads:
MPOWERCRAZY
Post Mon Jan 30, 2017 2:21 pm
Cypriotgeeza wrote:Pics not showing bro but I know you neglect this site now! :roll:
Love the car!
Didn't Know That Had Happened, Maybe Cause I Created A Folder On Photbucket For This Project After I Uploaded Them? Will Sort Out Soon...
MPOWERCRAZY
Post Tue Jan 31, 2017 1:47 pm
Picture Issue Sorted & Thread Updated!! :D
Gert_8
Post Tue Jan 31, 2017 2:07 pm
looking very nice!
MPOWERCRAZY
Post Tue Jan 31, 2017 3:08 pm
Gert_8 wrote:looking very nice!
Thanks Mate
Cypriotgeeza
Post Tue Jan 31, 2017 6:46 pm
Gorgeous car man! :drool:
MUCH better without the mudflaps! :thumb:
MPOWERCRAZY
Post Wed Feb 08, 2017 7:30 pm
Another Update In The Thread :D
ah
Post Wed Feb 08, 2017 10:24 pm
That's a fine tech 1,BUT PLEASE CHANGE THOSE WHEEL ROUNDELS.
tha881
Post Thu Feb 09, 2017 8:37 am
Lovely car looks like a great start. The wheel badges will probably be the best 20 quid you could spend! It's worth saying that if you are using eibach springs you may need the m-tech bump stops, or perhaps just cut down the ones you have. Looking forward to more pics!
MPOWERCRAZY
Post Thu Feb 09, 2017 10:02 am
ah wrote:That's a fine tech 1,BUT PLEASE CHANGE THOSE WHEEL ROUNDELS.
Tyres Have Been Ordered & Will Be Fitted Once The Wheels Have Been Refurbed.
MPOWERCRAZY
Post Thu Feb 09, 2017 10:03 am
tha881 wrote:Lovely car looks like a great start. The wheel badges will probably be the best 20 quid you could spend! It's worth saying that if you are using eibach springs you may need the m-tech bump stops, or perhaps just cut down the ones you have. Looking forward to more pics!
Thanks, I Have Ordered All New Badges, Still Waiting For Them, I Couldn't Find The M-Tech Bump Stops, These Were The Only Ones I Could Find??
tristan325
Post Fri Mar 17, 2017 9:18 pm
Love the Tech 1. REALLY wish I hadn't sold mine :x
MPOWERCRAZY
Post Sat Mar 18, 2017 7:23 pm
tristan325 wrote:Love the Tech 1. REALLY wish I hadn't sold mine :x
Thank You Mate, Was Tempted To Sell Mine But Not Sure Now.
MPOWERCRAZY
Thread Updated :D
Cypriotgeeza
Post Mon Mar 20, 2017 9:53 am
Glad to hear its all good again! 8)
MPOWERCRAZY
Post Sun May 28, 2017 3:09 pm
Update After A While!
