e30 vert 3.0 diesel
mat_91
Wed Apr 08, 2015 8:01 pm
Heres my 330d 8)
Ive fitted a Merceded e300 24v 3.0 turbo diesel mated to a 6 speed Mercedes gearbox
With help of some great friends over at Sump-scuffers we custom made a 6 point rollcage
Who needs gussets when your cage fits properly :twisted:
Also running a Wilwood pedal box, ready for future upgrades
Current spec
Up front
E46 lower arms
shortened e30 struts with mk1 golf inserts and weld on coilovers
E36 m3evo steering rack with 4mm lock spacers
Out rear
Med case diff with 3.64 ratio Welded needs alot taller
E36 double wing diff cover with custom mounts
Suframe and diff mounts are solid steel and aluminium respectily which also lift the subframe removing the need for adjustment tabs
Hybrid Mercedes/ Bmw propshaft
Custom engine and gearbox mounts for the usual engine swop
Lots more but i thinm thats enough for one post
Nobby_N
Wed Apr 08, 2015 8:08 pm
Wow someone went full retard on that fooker! :eek:
steve_k
Wed Apr 08, 2015 8:09 pm
looks good, :cool:
one thing bugs me though, why a merc derv lump?? surely a bmw one would be just as good if not better??
looking forward to more updates though winkeye
macas
Wed Apr 08, 2015 8:14 pm
Looks ok!
But "sump scuffers???"....class!!!! :D
mat_91
Wed Apr 08, 2015 8:25 pm
The merceds lump because its a million miles better than any Bmw diesel out there, sorry if that hurts you but its the truth
Its multivavle chain driven / easily converted to full manual injection pump
Stupidly reliable / currently returning 45mpg with my rather heavy foot
Is good for 500hp and 800nm with just lots of boost and fuel / revs over 6k rpm
6 speed gearbox and clutch kit bolt straight together all stock merc parts
And they are stupidly cheap this engine actally made me money after breaking the donor car
There not even that heavy around 245kg for a dressed engine
So why woudnt you haha
Nobby_N
Wed Apr 08, 2015 8:28 pm
No 300d merc engine has ever done 45mpg!
mat_91
Wed Apr 08, 2015 8:33 pm
Well thats what im getting full tank to full tank, speedo is spot on as well
Remeber its only pulling 1400kg of bmw with a manual instead of 1800kg with a auto
Im also running a smaller injection pump thats running less fuel which will be saving the mpgs as well
Nobby_N
Wed Apr 08, 2015 8:35 pm
Is it for drifting or driving, i dont understand the cage ect
mat_91
Wed Apr 08, 2015 8:38 pm
Drifting / track days / Daily use and generall hooning
I didnt go out my way for vert shell, i was looking for another coupe but this turned up on my doorstep at the right money as bascilly a bare shell and when arent verts cooler haha
sweep
Wed Apr 08, 2015 9:03 pm
Nobby you are so negative
Nobby_N
Wed Apr 08, 2015 9:04 pm
sweep wrote:Nobby you are so negative
Only positive i see is the weight of the cage when it goes on the bridge! :D
Wed Apr 08, 2015 9:13 pm
i have to stay this thread is full of strange
steve_k
Wed Apr 08, 2015 9:27 pm
got a link to sump scuffers? also how much was the cage??
just realized it looks a lot like the chizfab e36 m3 cabbie.
steve_k
Wed Apr 08, 2015 9:32 pm
Simon13 wrote:i have to stay this thread is full of strange
think that strange? have you seen the bmw derv powered mk2 escort van the doing the rounds on facebook??
or even the bmw derv powewred triumph that was in practical performance car last year??
mat_91
Wed Apr 08, 2015 9:34 pm
Haha I thought i might find the purists fans on here oh well
Guess you wouldnt like my last e30 as well
Or what about my truck, look its not stock as well winkeye
Why are my photos coming out so small, does this forum have a size limit or something, other forums are fine
Wed Apr 08, 2015 9:40 pm
Any ink pics ? :)
Andyboy
Alpina Colada
mat_91 wrote:Haha I thought i might find the purists fans on here oh well
You must be so proud. Do you have any body art and Jason Statham DVD's?
mat_91
Wed Apr 08, 2015 9:41 pm
steve_k wrote:got a link to sump scuffers? also how much was the cage??
Heres his facebook page can contact him through there
Awesome work and great prices cant recommend anybody else
https://m.facebook.com/SumpScuffers
mat_91
Wed Apr 08, 2015 10:02 pm
[URL=http://s483.photobucket.com/user/mat-91 ... a.jpg.html]Image[/U
[URL=http://s483.photobucket.com/user/mat-91 ... z.jpg.html]Image[/UR
Must resist come back, ive been told you get banned far to easily on here
Andyboy
Alpina Colada
Wed Apr 08, 2015 10:05 pm
Sorry, the Statham gag was cheap.
Vin Diesel or The Rock? :D
sweep
Wed Apr 08, 2015 10:09 pm
What hubs does that e30 have on?
Andyboy
Alpina Colada
Wed Apr 08, 2015 10:12 pm
Mark 3 Cavalier?
mat_91
Wed Apr 08, 2015 10:14 pm
They both run standard e30 hubs, I made adapters to take that out to 6x139.7 as theres lots of cheap awesome looking wheels out there for jap trucks, the set above cost £42
JF008
Wed Apr 08, 2015 10:31 pm
I'm suscribing, interesting work on the 330d :thumb: shame about the blurry pics :)
Thu Apr 09, 2015 12:43 am
making a car look scrap is majorly gay, thats about all there is to say.
I'm no purist
bab-91
Thu Apr 09, 2015 1:30 am
Mercedes Derv lumps are superior... :o:
Fatmangolf made me say that...
IG - bab91
martinpallot
Thu Apr 09, 2015 10:18 pm
This looks interesting - would like to know what gearbox and clutch/flywheel you used and if you have it running on the standard ecu and drive by wire setup?
jasso
Thu Apr 09, 2015 10:39 pm
What Merc derv lump is that from? Turbo or non turbo?
Fri Apr 10, 2015 9:21 am
jasso wrote:What Merc derv lump is that from? Turbo or non turbo?
Early 210 chassis 300 turbo diesel. They are Ca 175 bhp stock.
jasso
Fri Apr 10, 2015 4:09 pm
The BMW 3.0litre dervs are the best on the market and most powerful, reliability has never been a issue except for the swirl flap issue which can be resolved with delete kit. I can only imagine that the wiring isn't as complex as the Bmw dervs, after having mine wired I can say it's not a task for the faint hearted.
Andyboy
Alpina Colada
Fri Apr 10, 2015 4:55 pm
The actual M57 diesel is very good - it's what's bolted to it that causes issues. The Merc 300D engine is a very good one and capable of 500'000 miles - ask any taxi driver.
mat_91
Fri Apr 10, 2015 8:54 pm
The engine is out a 1998 e300 and is turbocharged stock power is 198hp and 350nm, im currently running the stock tiny turbo which is mounted very low down, ive fitted a older om603 injection pump which is fully manual one lever to go and one lever to turn it off, unfortantly it doesnt put out as much fuel reducing power to around the 160hp mark im told,
there is a total of 3 wires to start the engine, one for glowplugs and 2 for the startermotor nothing to keep it running, clearly ive immobilised it by other means
I am a mechanic/ auto electrician and repair wiring/electrical faults on a daily basis and anything with a ecu is trouble, i see far to many problems due to wiring ecus faults
Another reason for building this, aswell my truck is also a mechanical diesel, i think im subconsciously a dooms day prepper
Ive currently got a c220cdi 6 speed gearbox fitted and a merc sprinter solid mass conversion flywheel kit
Im told over on STD forum that the gearbox is good for 400hp behind a 606
The clutch certaintly wont, as its currently on the limit it begins to smell when beating on it
RetroAde
Sat Apr 11, 2015 10:07 am
I'm in on this, I like the leftfield approach to this build, I like the knuckle duster welded into the cage and I especially like the fact that if nuclear armageddon comes you'll have the only working E30 in the country, presuming the fireballs and shock waves don't get it first. The Merc lump, the cage, it's just so wrong it's right.
aze30
Sat Apr 11, 2015 11:48 pm
mat_91 wrote:The merceds lump because its a million miles better than any Bmw diesel out there, sorry if that hurts you but its the truth
i have to say i prefer merc derv engines to bmw derv engines!
talking from experience of running both brands in the family the mercs engines are quieter rev much more freely and feel much gruntier even at lower revs (e320cdi vs 530d)
we have been running mercs and bmw derv engined vehicles side by side since early 90s even back then although the merc engine prob wasnt as powerful but it was much more reliable! (im talking 12v 300d engine here)
Taz
Sat Apr 11, 2015 11:58 pm
that thing is hideous! im lost for words :cry:
