My new 316!
Junglistjed
Tue Jul 16, 2013 6:56 pm
Alright lads, just sharing my 316 before anything is done to it, rust free and has definitely been looked after! Share your opinions and advice :)
Interior is in amazing condition, still has the original mats! the only let down is the drivers seat, not sure if im going to replace it altogether or just the fabric!
I will give her a full machine polish when i get myself some new pads, also looking to lower it by 30mm and put a set of BBS on her! Any other ideas and opinions are welcome :)
cheers
TPS
Tue Jul 16, 2013 7:05 pm
Very Nice
Nobby_N
Tue Jul 16, 2013 7:10 pm
Rust free! 8O
Junglistjed
Tue Jul 16, 2013 7:12 pm
Other then the engine cap, the car has had one owner and it was always garaged
Junglistjed
Tue Jul 16, 2013 7:27 pm
Would it be worth replacing the carb with the webar? or doing a whole engine swap?
jimmyspeed
Tue Jul 16, 2013 7:48 pm
depends on what you want , a weber is ideal if you want originality and a bigger engine if you want some descent speed
i was watching it on ebay an i thought it looked a nice early motor
a good buy if it truly is rust free, as the seats and engine are relatively cheap and easy to swap around !
Junglistjed
Tue Jul 16, 2013 7:50 pm
Couldn't believe it mate, all arches rust free, below the carpet in the boot is rust free, what engine would i swap it to mate?
jimmyspeed
Tue Jul 16, 2013 7:55 pm
sounds good, i was tempted but didnt fancy driving to essex
i would put a nice high compression 325i for a weekend car or a m42 if its going to be a daily driver
depends on what you want really have a read here -
http://www.e30zone.net/e30zonewiki/inde ... gine_Swaps
Junglistjed
Tue Jul 16, 2013 8:01 pm
Only 20 minutes from me thank god, shame its one of the most simple models but oh well! well ill be using it 3 times a week (120 miles)
How much does replacing the carb on the m10 improve the engine? can see an engine swap being expensive if i have to replace breaks and suspension!
cheers
Junglistjed
Wed Jul 17, 2013 12:48 pm
keep it simple with the original BMW BBS or but a set with some dish?
JF008
Wed Jul 17, 2013 1:07 pm
keep it simple, I'm doing a m50 conversion and the cost spiralled out of control. Do the sum of all needed parts first.
Once you start changing bits there is no coming back :)
JF008
Wed Jul 17, 2013 1:08 pm
nice car by the way
Junglistjed
Wed Jul 17, 2013 1:10 pm
Well Wheels are a must for this car as the steelies are horrible! im also looking at getting a Weber which will set me back a fair fit!
thanks mate, appreciate it!
Wed Jul 17, 2013 5:43 pm
Junglistjed wrote:Well Wheels are a must for this car as the steelies are horrible! im also looking at getting a Weber which will set me back a fair fit!
If the car runs allright leave it alone ! The Weber is no better from an economy or power perspective IF the original carb works correctly.
Be sure to get your tappets checked and adjusted and your ignition timing set CORRECTLY. Both will undoubtably be incorrect and costing you power and petrol.
Junglistjed
Wed Jul 17, 2013 5:56 pm
Would i get that done at a garage mate? and the car runs fine, i just thought the Weber improves it and makes it run smoother?
TPS
Wed Jul 17, 2013 5:59 pm
+1
Junglistjed
Wed Jul 17, 2013 6:00 pm
Ahh my bad! the posts i read concerning Webers made it seem like they were a must for the m10 engine!
kangman
Wed Jul 17, 2013 8:46 pm
similar colour
Junglistjed
Wed Jul 17, 2013 9:04 pm
beautiful mate, that yours?
kangman
Wed Jul 17, 2013 9:06 pm
Naa not mine, just come across it on fb
verde
Wed Jul 17, 2013 9:14 pm
fellow junglist :D
nice machine. Id deffo whack a webber on it, i used to hate m10s til i got my e21. Pokey as fuck and 30+ mpg is awesome. Plus if you stick a straight end section on they sound wild
Raise hell praise Dale.
TPS
Wed Jul 17, 2013 9:18 pm
kangman wrote:similar colour
Thats Stunning!
Junglistjed
Wed Jul 17, 2013 9:24 pm
Are those windows factory or would i need to buy some? and any idea of what mpg the m10 will give me? haha
Car looks amazing, very low though! i would like to do that but by what people say on here it would cause way too much trouble
sweep
Wed Jul 17, 2013 9:35 pm
m10 engine-old taxi tick, leave it be they run for ever...less is more theme?
Junglistjed
Wed Jul 17, 2013 9:45 pm
Seeing as this is one of the most bog standard models i want to drop it a bit and put some wheels on it to make it stand out, other then that i will get the paintwork up to scratch and maybe do some things like Angel eyes
Junglistjed
Wed Jul 17, 2013 10:24 pm
what size wheels will be best guys?
Wed Jul 17, 2013 10:29 pm
:eek:
Junglistjed
Wed Jul 17, 2013 10:32 pm
:o
Thu Jul 18, 2013 12:08 am
You should easily be able to get 30+ mpg average if it's in a good state of tune.
I rather like the standard steelies, but 15" BBS would look good.
Andy325i
Thu Jul 18, 2013 12:15 am
Waxoyl it, keep it standard, or at least tasteful mods that are easy to put back to standard if you want to at a later date. That said an M52 would be a nice mod :D
Junglistjed
Thu Jul 18, 2013 12:33 am
Waxoyl?
And i only really intended to lower it 30mm and stick another set of wheels on it! But things like angel eyes etc are coming to mind
Andy325i
Thu Jul 18, 2013 1:12 am
E30's can rust well Mmmmm anal eyes :)
Junglistjed
Thu Jul 18, 2013 1:21 am
whats is it, an underseal? and are they worth the upgrade?
nickso
Thu Jul 18, 2013 10:34 am
Junglistjed wrote: maybe do some things like Angel eyes
That will make it stand out for the wrong reasons. Keep the headlights and rear lights standard. Get the car shiny as fook, decent wheels THAT FIT unlike the one above, small suspension drop (I would go 40mm but that's just me)......then leave it alone.
'88 e30 328i M52 track bint.
Junglistjed
Thu Jul 18, 2013 10:37 am
would 40mm still be ok on the original dampers and shocks?
