Thank you everyone!
I wish I had vids.
Maybe next time my friend brings his camera we'll try some!
OOjoeE30 wrote:Looks good
Is the motor built or stock internals? Specs
Are you part of Castro? have seen some of there builds on bimmer forums they have some awesome cars.
Is interesting how tunning methods differ whether it relates to petrol prices, steering wheel being on the other side, we seem to be a bit behind in some respects.
Yes, I'm Castro's good friend! He definitely does good work/fabrication. No more than 30 miles out from his shop.
I wouldn't say you're behind to be honest. There are many people in the states who envy your cars.
The motor is essentially stock with a completely OEM rebuilt bottom end.
All the bearings
Race Piston rings
ARP connecting rod bolts
ARP main bolts
ARP head bolts
O-Ringed the block
Stock sized Goetze headgasket
Head is untouched, though a rebuilt head with HD rocker arms is going in.
Garrett t3/t4 Hybrid turbo .60/.63 v-band
CXracing manifold; cut off the 2-bolt flange and welded a v-band for the wastegate
42lb injectors
HKS bov
TiAL 44mm mvr wastegate
For tuning, using a 3.5" Miller MAF (draw-through setup) and the stock 173 ECU.
Excuse the crappy pictures.
