My 325 sport
170sport
serial askhole
Sun Jan 01, 2012 5:30 pm
this is my 325 sport which im trying to save from the scrap yard full pics on my blog, ive got 300 ish so bare with me :roll:
on second thoughts its eaiser to get the pics up on here so ill update as and when....keep watching winkeye
Image[/img]
Image[/img]
as you can see the drivers wing will be replaced but the passenger wing can be repaired, afew clips are required for the body kit, and a pair of new rear inner arches will be required......keep watching people :mad: [/img]
passenger rear arch welding in place and underseled, now to attack the drivers inner arch. the plan was to use the excess from the passenger rear arch to complete the drivers side, but after i removed the fuel filler neck and evap canister, it was abit more worse for wear. but luckily enough, bmw still supply panels so it was just a case of cutting that one out aswell.......awesome
http://i1104.photobucket.com/albums/h32 ... 9517_n.jpg[/IMG]
Image[/img]
drivers rear arch repaired, and floor plan plug repaired. new drivers front wing fitted
M-Sport
Sun Jan 01, 2012 5:42 pm
Looks a nice original example :cool:
Whats your plans for it?
170sport
serial askhole
Sun Jan 01, 2012 6:16 pm
thanks, plans are to put it back to how it was originally but with very minor modernization alternatives, ive got a set of american indicators which have the orange marker lights incorperated but ive altered them to represpent daytime running lights, it'll look smart i think as people fit these retro kits these days but they look nasty, but these are obviously part of the light, ive got an awesome new interior which i got from a chap in twickenham which are in amazing original condition (if your reading this, its graham i cant remember your name im afraid but i bought the seats off you from ebay). it will have xenons also.
its all ready been lowered but apart from that its staying the same mate really, keeping the wheels, keeping the body kit, no turbo conversions, no exhaust mods, no intake mods. it will be completly re-sprayed in original paint.
i just want to put it back to how people remember them really. :)
rix313
Sun Jan 01, 2012 6:20 pm
Looking forward to seeing some pics :)
There's a car just like this I've seen in a driveway localy with flat tyres, dead tempedt to knock on their door and see if they's sell it.
170sport
serial askhole
Sun Jan 01, 2012 6:37 pm
do it mate !! they certainly are a appreciating classic, if not for value then certainly for presance and image. alot of people do say the e30's are the face of bmw. even if they dont like to admit it :P
Sun Jan 01, 2012 6:41 pm
Well done for saving a Sport from being broken for parts! :cool:
170sport
serial askhole
Sun Jan 01, 2012 7:05 pm
i know tell me about it, this one has had abit of neglect :crutch: but i will return it to its glory :drive:
lyricalnut02
Sun Jan 01, 2012 7:07 pm
looking foward to seeing this being restored :cool:
325i Sport Tech 1 - R.I.P
E30 addict.
Sun Jan 01, 2012 7:23 pm
Get the carpet out and look inside the roof where the sunroof panel slides into.
Check both the roof and the floor pan and bulkhead for rot.
170sport
serial askhole
Sun Jan 01, 2012 7:36 pm
funny enough im just on the sunroof now, ive treated the roof from what i could see. the passenger side rail is fine but the drivers side rail could do with abit of treatment right at the back but how do you get to it? it looks like a sealed panel welded to roof? but more importantly how do i get the overhead lining off without stretching it?
Sun Jan 01, 2012 7:57 pm
The head lining comes out ok and doesn't stretch but all the glass needs to come out as does ever part of the sunroof.
The sunroof "tray" is bonded to the outer roof skin and also has a couple of brackets spot welded on mid way along the roof.
The "tray" is available new and separate from the roof skin so if your's is rust then a new one is the best course to take.
The original one rots because of poor protection with minimal paint, mostly primer and no cavity wax. When replacing a rusty one for a new one, this can all be remedied.
Tom_Maverick
Sun Jan 01, 2012 9:09 pm
Nice work.. I look forward to seeing it back to its former glory! nice to see someone trying to keep it on the road rather than fraggng it (which is financially a bonus but I always think it's a bit sad..)
csl
Mon Jan 02, 2012 12:03 am
Good man! 8)
Looking forward to some updates.
170sport
serial askhole
Sat Jan 14, 2012 6:14 pm
in this set of pics there is prob about 3 weeks work rebuilding the engine, i needed to change the sump gasket, and i read you can ''sort of'' do it in situe without lowering the subframe but this wasnt working for me. so i took the engine out.
its had new cambelt and tensioner, water pump, cam seals, rear main oil seal, dizzy cap, rotor arm, inlet manifold gasket, exhaust manifold gaskets, upon removal you'll see i took a picture of one of the exhaust outlets, and you'll see its abit oily :(
so needless to say i pulled the head off and removed all the valves and replaced all the valve guide seals. good job too as the state of the valve seats were....well take a look at the before and after valve pictures. lol
then the engine is rebuild back in the car. bonnet is replaced and the front bumpers are refitted with my DRL incorperated indicators. with the xenon headlights.
Image[/img]
Image[/img]
[/img]Image
[/img]Image
[/img]Image
stayed tuned for rear axle developments coming up soon plus small interior re-vamps starting to take place.
e301988325i
Sat Jan 14, 2012 6:22 pm
170sport wrote:
Looks like you're making good progress.
Your engine mounts look quite tired, if you've not replaced them already then I'd suggest replacing them with FP292's for a modest ammount from:
http://www.burtonpower.com/fp292.html
I said:
e30topless said:
lock the wife in there
170sport
serial askhole
Sat Jan 14, 2012 6:33 pm
ok thanks i'll look into it, do they make much difference to these engines fitting new ones?
e301988325i
Sat Jan 14, 2012 7:12 pm
1) Helps to stop the fan eating the radiator when the mounts finally fail.
2) Keeps the driveline in line
3) Check the gearbox mounts whilst you're there.
HTH Alex
I said:
170sport
serial askhole
Sat Jan 14, 2012 7:32 pm
Nice ok, thanks for the info I'll add it to the list.
tonybtonyb
Fri Jan 20, 2012 1:03 am
Well done mate for saving another :cool: :cool:
mani
Fri Jan 20, 2012 10:00 am
looking good looking forward for updates
170sport
serial askhole
Sat Jan 21, 2012 8:23 pm
cheers guys, i'll get some more up v soon :D
170sport
serial askhole
Sat Jan 21, 2012 8:53 pm
in this set of pics you can see the first set of seats which are the one which came out of the car, i since sold them and got a very very good set of second seats which will be fitted.
also is the parcel shelf before and after pics, needles to say which are which. just need to cut out for the rear speakers.
and finally a pic of the diff which is being re-build with new genuine seals.
pics of under the car with new brake lines etc are still to come.....
[/img]Image
[/img]Image
[/img]Image
Image[/img]
170sport
serial askhole
Wed Feb 22, 2012 9:44 am
Progress report... Diff rebuild and re-installed. Drive shafts re-installed, trailing arms re-installed with new bushes and wheel bearings. New brakes and brake pipes fitted, all thats needed now is to order a new exhaust system and refit the the prop shaft and heat shields etc...
Next week I've got afew days off so I'm gonna attack it hard to hopefully be at the stage where I need to start fairing off the bodywork ready for original paint respray. pics to come !!! :D
SHAZ325iSPORT
Wed Feb 22, 2012 10:00 am
Good progress mate,keep up the hard work
Subscribed!
suchy
True Zone Relic
Wed Feb 22, 2012 11:04 am
Nice work saving another Sport from China!! 8)
Wed Feb 22, 2012 4:39 pm
Excellent work :cool:
170sport
serial askhole
Fri Mar 02, 2012 10:20 pm
quick update, here we have the new exhaust system fitted, it was a 'good' fit but i still had to make afew welding modifications to get it to fit perfectly, also with new brake pipes both solid and flexi pipes, new shoes, and new discs and pads to go wen shes just about to roll, other wise they will start to rust up.
rear bumper re-fitted with new mounts welded in. all work and pics taken on 2/3/2012
170sport
serial askhole
Sat Mar 03, 2012 8:12 pm
here im startin the body 8O however im just filling in the big obvious bits, the body shop will do the rest.
oomz1975
Sat Mar 03, 2012 8:33 pm
Getting stuck right in, love threads like this.
Well done for saving this one.
170sport
serial askhole
Sat Mar 03, 2012 8:59 pm
Cheers dude, I got a video of the engine running and exhaust sound, but still trying to figure out how to up load it. :roll:
170sport
serial askhole
Thu Mar 08, 2012 9:54 pm
This is a quick video of the exhaust running. Makes an "interesting" noise I think.
170sport
serial askhole
Thu Mar 08, 2012 10:00 pm
More vids and pics to come, that was just a quick run. Got some idle speed control issues to sort first. Hopefully be back on all fours this weekend. :-)
170sport
serial askhole
Sun Mar 11, 2012 7:27 pm
ok in these pics, ive moved it from the car port / tent which has upheld againt the weather very well to a hard ground, this is where the bodywork prep will start.
its the first time its moved and seen daylight in 7 months solid. as you can see from the previous pictures the drivers rear quater was very poorly painted in the past sometime, this will now need to be scrated back back by the painters to almost bare metal, as who ever painted it before didnt let the base coat go off correctly which then caused the top coat to crack and move as the the car moved around, i believe they call it 'pavestoning effect'.
the rest of the paint will be scratched back by me, to g600 then moved over to the painters.
ive started the bonnet as you can see...
scott180gtb
Tue Mar 13, 2012 8:38 am
Got to love a black tech two.
Subscribed.
Cars
2007 VW Caravelle 2.5 TDI 250 bhp 550 NM
1989 325i Sport Gone :(
2003 E46 320d Touring
1998 E36 M3 EVO Track Toy
1996 E36 328i Sport welder-up project
e30325itourer
Mon Mar 19, 2012 10:55 pm
Some balls right there well done.
THE ULTIMATE DRIVING MACHINE
