Purchased in August 2009, a 318is with 143k on BK reps and Tech II kit. I had never heard of the zone, just always fancied owning an old E30. I knew nothing about these cars, I just wanted one so off I went to Leeds and picked this up. It seemed in good nick and to all intents and purposes it was/is.
Here it is after I stuck some 15”a BBS on end of last winter.
Took off the road April 2011 with 156k and 20 odd months hassle free motoring, due to going down to one car as my girlfriend went on maternity leave. Always fancied a 24v swap so thought I would upgrade this car as a worthy donor. I had found my way around an E30 mechanically by buying a breaker in the meantime and learning as I went along
I bought a few bits for it, had some Borbets then changed my mind, swapped them for some Hartge wheels, found a cheap M50b25 and set about buying all the necessary parts for the M50b25 conversion.
Then I got massively side tracked with another heap of shyte I bought for about £200, some might remember it but after many hours of practicing welding and working in the rain (all summer) I gave up with it as it was just too far to gone. Here is how it ended up:
Spent some time getting used to farther hood after messing with that and learned a valuable lesson not to get side tracked LOL
Skip forward to a couple of weeks ago and I finally get round to getting this car stripped down. I knew it wanted some attention and to be honest what I got is what I expected and being a non-sunroof car it has no roof/scuttle rot, and more importantly no bulkhead rot from what I can see. The dash will be out very soon so can confirm that ASAP, but where the wiring loom comes through looks all good.
Before it was touched, covered in unloved green sh1t and cobwebs
Kit off:
Interior and carpet out (looks like it had already had a floor bung this side)
So far:
Both front wings scrap
Drivers door scrap
Front valance scrap
Got good replacemements already so that’s them sorted.
This the story inside the boot:
Tail panel is coming away from the boot floor with rot, it is also crusty above the number plate under the seal
NSR inner arch, Not gone through yet but you know as well as I do that its fooked.
OSR arch, to be honest if I ignored this I would be stupid
Drivers footwell:
Accelerator pedal mount came off with the carpet! Plenty of brown and holes here:
Passenger footwell, previously ”arepaired”a (using the term loosly)
So already got 2 new inner arches on order and a tail panel, just need to order up my outer arches and get stuck in.... Easy
